231 Speedo Gear and Housing - FOUND - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 19th, 2012, 08:59 AM   #1
jbsjunk
Little Member
jbsjunk's Avatar
Default 231 Speedo Gear and Housing - FOUND
I need a speedo gear preferably 37-38 tooth, housing and hold down. It is obviously cable style. You can see the example below. It's said that CJ's would be the same in the early 80's era.
Thanks!
I've seen gear charts that said 33-34 tooth would be right for me.
Here's another angle.
jbsjunk is offline
Old August 20th, 2012, 05:38 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
Still looking.
jbsjunk is offline
Old August 20th, 2012, 07:48 PM   #3
gearedfather
Default 231j speedo
if you still need the 231 speedo gear give a call i have 3 16 gallon drums full of transfer case speedo gears and housings...612-309-3999
gearedfather is offline
Old August 23rd, 2012, 07:22 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
Found them.
jbsjunk is offline
Old August 24th, 2012, 08:46 AM   #5
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Originally Posted by jbsjunk View Post
Found them.
Did geared father have what you needed? I need one with 41 teeth.
Thanks
41 tooth speedo gear - Great Lakes 4x4. The largest offroad forum in the Midwest
RIP FULLSIZE4LIFE
SHARPMACHINE is offline
Old August 24th, 2012, 04:37 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
I got everything thru Ebay. The housing and the 35 tooth gear was $24 shipped. At least with this gear I can figure out how far it may be off and swap to a smaller or bigger gear.
jbsjunk is offline
Page generated in 0.36700 seconds with 42 queries
