Thread Tools
Old August 18th, 2012, 09:24 PM   #1
Little Dave
Little Dave's Avatar
Help figure out block I'd
SBC 350 ci.
Casting # 3970010
Build # Fo71ockl ( the o are letters)
F0710ckl ( the 0 are numbers) I don't know how to read them.
Build number or I think that is what it is.
# fo71ockl ( again the o's are letters)
And then the block vin number.
13131062
So far I found that the casting # shows 69-79 302/350 car truck 2+4 bolt most common.
I would love to know what year,car/truck my motor was is. It will make getting parts easier. Of course it's now in an 1984 cj7,I still like watching the part store guys give the look when I ask for parts.
Little Dave is offline   Reply With Quote
Old August 18th, 2012, 09:33 PM   #2
skife
skife's Avatar
its a small block, probably carburated, 2 peice rear main seal, probably HEI ignition.
parts are easy to get for it. what do you need?
Old August 18th, 2012, 09:43 PM   #3
Little Dave
Smile
Small block yes, carb check, 2 bolt main NOPE, hei yes.
Parts store guy piss me off. If I I could tell them year car,motor,etc it will be a lot easier.
That and I didn't put the motor in my toy so I would love to know where what it came from
Old August 18th, 2012, 10:14 PM   #4
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
0010 casting is usually Chevy truck C-K series 350 4 bolt main. Carb'ed 2 piece rear main, 168 tooth flywheel, High torque starter.
zook94 is offline   Reply With Quote
Old August 18th, 2012, 10:24 PM   #5
Little Dave
Ok have a link to that info? That what I'm after finding out what the motor came in from the factory.
Old August 18th, 2012, 10:54 PM   #6
cannaert
screw it.
cannaert's Avatar
I will have to go dig my book out with all the info on Chevy Small Blocks.
Old August 18th, 2012, 10:57 PM   #7
Little Dave
Anything you can find would be great.
Old August 19th, 2012, 10:00 AM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you don't need to know what it came in. All 350 cid small block chevy parts are interchangeable between 67-86. hell you can interchange some things between displacements no matter the year. you can put 400 heads on a 350 block, you can run a 400 crank in a 350 block. you can run 98 cylinder heads on a 67 block. thats the marvel of the SBC.
"I don't have pet peeves, i have major psychotic fucking hatreds" -George Carlin
Old August 19th, 2012, 11:22 AM   #9
joe_jeep
welfare wheeler
joe_jeep's Avatar
tell the parts dummy its from a 79 c10.
joe_jeep is online now   Reply With Quote
Old August 19th, 2012, 03:25 PM   #10
dragginwagon406
Adrenaline Junkie
dragginwagon406's Avatar
Originally Posted by Kodiak450r View Post
...hell you can interchange some things between displacements no matter the year. you can put 400 heads on a 350 block, you can run a 400 crank in a 350 block. you can run 98 cylinder heads on a 67 block. thats the marvel of the SBC.
With some caveats...
dragginwagon406 is offline   Reply With Quote
Old August 26th, 2012, 09:19 PM   #11
HPandThrottle
have fun or die trying
HPandThrottle's Avatar
f=flint engine plant 07=July 10=tenth day of the month ckl=1973 350 or a 1975 262 this all came off the nasty z28 website the 3970010 comes up as a 69-79 185hp low power to 370hp high power 350 car truck or vette so pick your model of 1973 chevy and add what ever options you want to tell them and you will be good i have to do this also whit the same bone heads you get to deal with and it works well
HPandThrottle is offline   Reply With Quote
Old September 7th, 2012, 08:24 AM   #12
Never_Evil
An 86 corvette doesn't share much with a 73 k20 except for some gaskets.
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.13374 seconds with 34 queries
