"The Predator" another YJ build. - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 30th, 2012, 06:41 PM   #121
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Old December 30th, 2012, 06:44 PM   #122
Grassman
2jz specialist
Grassman's Avatar
I thought you were going 6.0?
Old December 30th, 2012, 06:46 PM   #123
jhnyquest
goof ball
jhnyquest's Avatar
Looks good
Old December 30th, 2012, 06:48 PM   #124
big86inthestixx
big86inthestixx's Avatar
Gotta fix this one up nice..for a sale.
not enough $$$to just swap one now. Hoping i can sell this one when i get the motor in and running, or before. The top end will be all freshened up.
Sent from my SPH-D710 using Tapatalk 2
Old December 30th, 2012, 06:51 PM   #125
big86inthestixx
Thanks Greg...hope to sell my.motor quickly..but i dont know what i could sell it for $$$wise.. Need to do some looki round..
Old December 30th, 2012, 07:28 PM   #126
Bruster
What motor?
Old December 30th, 2012, 08:01 PM   #127
big86inthestixx
Wanna put a 5.3/6.0 in place of my
Chevy, 360 (350 +060) 4 bolt main, nodular iron crank, h beams, flat tops, world products motown 220 heads (220 intake runners 2.08 intake valve 1.95 exh), chromoly 5/16 pushrods, roller rockers, demon 850 carb, headers, chromoly sfi flexplate, new hydraulic flat tappet 286H cam, probably sell my boss hogg 3200-3800 stahl converter with it too...
Kinda hard to crawl with all that..and i dont have enough $$$$ to be a "bouncer" lol
Old January 2nd, 2013, 10:28 PM   #128
big86inthestixx
Well went and got a newer non tilt steering column from FordFlareside yesterday...but nee bearings in,swapped the wheel over, and put it in tonight. Like the solid steering wheel feel...lots better than the floppy tilt..
Crappy pic
Also taking kyle m's advise and sleeving my frame and moving my box 3" forward and 2" up to add a little more clearance for my pitman arm. Now im on the hunt for a factory jeep pitman arm, the drop one isnt necessary.
Old January 3rd, 2013, 06:05 PM   #129
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Oh boy, I took advice from that guy once...look at where it got me....good luck
Old January 3rd, 2013, 10:42 PM   #130
big86inthestixx
Well got box mounted and about 75% installed tonight. Looks like itll work NICE...
Definitely going to need a stock Pitman arm or waggy Pitman arm.
Tucked up nicely into the frame, and tight behind the bumper.
The attachment tubes/sleeves hang down 1.25" from the frame. Going to add a 1/4" plate gusset between the two kind of fish plating them to the frame.
Had to sleeve my steering shaft with a 12" peice of 1" dom. The shaft was 4.5" too short.
In this picture u can see y im going to need a stock pitman arm. Tie rod may make contact with a drop Pitman...dont want that.
Also picked up my intake and headers from the neighbor...which he so kindly blasted for me...tonight i baked the intake with some high temp engine enamel.
Hope to get box wrapped up this weekend 100%, and finish up some wiring inside.
Old January 5th, 2013, 06:39 PM   #131
big86inthestixx
Box is now 100% installed ready to rock..
Front view, the box is almost completely covered by the bumper.
Passenger side view under the rig
Drivers side view of box mount, all boxed in and frame is sleeved with 1/4 wall...looks tougher than stock...
Also got the tie rod completed, need some 3/4x3" gr8 bolts and lock nuts. I drilled and tapped the knuckles for 3/4 bolt so they will be lock nutted and jamb nutted on..
Debating on adding a box brace??? With all the bolts holding my box on sleeved through the frame then boxed in...is it necessary? What r u thoughts?
Old January 5th, 2013, 07:00 PM   #132
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I think it looks fine, but a brace won't hurt. You still have one laying around?
Old January 5th, 2013, 07:07 PM   #133
big86inthestixx
Have to make a new one...how is a normal truck box mounted...do you guys brace your truck boxes? Just curious...
A brace would only make is better/stronger..why not eh..
Old January 5th, 2013, 07:35 PM   #134
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Mines mounted on the frame just line yours without a brace. From what I have seen, braces are mostly a jeep thing. Must be a bad factory set up?
Old January 5th, 2013, 09:19 PM   #135
big86inthestixx
Yeah..bad factory set up is what im assuming, iono maybe ill c how well it works without a brace for a short while.
Old January 5th, 2013, 10:45 PM   #136
big86inthestixx
Well, i guess i wasnt done for the night yet...
Pulled shroud of my radiator...guess what
You couldn't see a streamlight shining through the core....i blew about 1/2 a gallon of dirt out of it. Must be Drummond dried mud..
I know u dont wanna see dirt..but i was shocked...lol
Got radiator cleaned and new fan on the shroud..
Old January 5th, 2013, 10:47 PM   #137
big86inthestixx
Oops
Cleaned up wiring in my engine bay, and that's a rap...
Old January 5th, 2013, 10:53 PM   #138
Grassman
2jz specialist
Grassman's Avatar
Mud on Drummond? No way!
Old January 6th, 2013, 08:40 PM   #139
big86inthestixx
Well...not a LOT of progress today...but i did run and get..all my gaskets etc for the motor re assembly. Hope to get going on that this week.
Slowly getting crap crossed off my winter fixin list. Hopefully its done wayyy early i wanna do some winter wheeling sooooo bad..
Yeah whod a thunk MUD on Drummond....never seen as much in any one place as there..lots of water..but it was still fun.
Old January 6th, 2013, 09:13 PM   #140
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
You can have the picker back whenever you need it.
Page generated in 0.35200 seconds with 84 queries
