"The Predator" another YJ build. - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 26th, 2012, 08:04 AM   #41
jhnyquest
goof ball
jhnyquest's Avatar
Originally Posted by big86inthestixx View Post
Give it time, if i keep cutting and whacking on the frame..someday ill.have to make it a buggy.
Besides that's what all the "cool" kids have. Now im gunna have to get some sweet aluminum beadlocks too..
The wife says sell the jeep and build a buggy.
Sent from my SPH-D710 using Tapatalk 2
You should make the wife happy then.
Old August 26th, 2012, 08:53 AM   #42
big86inthestixx
big86inthestixx's Avatar
I'll try, but after i get back on the trails and after the barns done.
The hood actually closes, i was all excited i was going to have to put holes in it..but nope.
Old August 26th, 2012, 09:59 PM   #43
thrill20
thrill20's Avatar
Looks good Andrew!
thrill20 is offline   Reply With Quote
Old August 28th, 2012, 09:14 PM   #44
big86inthestixx
Thanks..wish it were finished. Soon, got some wheeling and dealing to do, to finish up, just down to drive slugs.
Old August 28th, 2012, 09:42 PM   #45
big86inthestixx
Well there is all the squish i have for the drivers side and 1.5" short of full droop on the passenger side. Hope to be ready for paint tomorrow night, then drive slugs.
Old September 1st, 2012, 08:12 PM   #46
big86inthestixx
Well HUGE bummer i didnt make it to club challenge today. BUT on a good note i have got the jeep finally pieced back together good enough to drive, bleeding brakes right now.
It got all final welded today, shocks put in place, links tightened up adjusted, lengthened front drive shaft, made tie rod, set drag link up so tires wont rub my lower links, cleaned up all my under hood stuff from hoop locations. Now Tuesday itll get loaded up to take to the shop, to set my limits and bumps, easier to do with a forklift.
Oh yeah, shocks are filled with 380 cc 5w synthetic shock oil, and 450 psi nitrogen...seems pretty squishy, but its also a little higher in the front..maybe ill let em down a little..
Old September 1st, 2012, 08:59 PM   #47
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
looks good
Old September 1st, 2012, 09:21 PM   #48
big86inthestixx
Thanks.
Old September 2nd, 2012, 08:49 AM   #49
hellspawn
hellspawn's Avatar
Good looking jeep
hellspawn is offline   Reply With Quote
Old September 2nd, 2012, 05:43 PM   #50
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Saw it in person today.....quality stuff. Can't wait to see it roll by.
Old September 2nd, 2012, 05:55 PM   #51
jhnyquest
goof ball
jhnyquest's Avatar
Slacker.
Old September 2nd, 2012, 06:01 PM   #52
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I think he just drove by....
Old September 2nd, 2012, 07:45 PM   #53
big86inthestixx
Yeah..i am getting lazy and slow in my old age..hah...took it for a slow ride today, seems good. Going to keep pennies pinched for full hydro...steers ok, no worse than my leaf springs, actually a little better.
Yes i did crawl bu your house today kyle..
Here are a fea pics of my rti..
Had to raise the rti, from 60" to 72" 60" wasnt quite enough.
Old September 2nd, 2012, 08:59 PM   #54
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
How did it feel?
Old September 2nd, 2012, 09:10 PM   #55
big86inthestixx
Felt awesome to drive it again. Rides smoother than my leafs, little roll around corners, but i had that with my leaves. Maybe not quite as bad. Doesn't nose dive that bad, but without a center limit strap it lifts quite a ways under hard acceleration..to be expected.
As far as the rti ramp, i had to lift it farther, and i could have kept going up the ramp all tires stayed on the ground.
Steering doesnt feel that bad..could be better. Still not as bad as it was with leafs.
Overall im really happy with it, cant wait to wheel it.
Need drive slugs..and 8 misalignment spacers. Those will be here mid week.
Old September 7th, 2012, 09:21 PM   #56
big86inthestixx
Well finally got my misalignment bushings today, threw them in. Got my dang optima charged..i think. Been on 2 amp trickle steady for almost a whole week. Also got my drive slugs today, took it for a spin.
Have a little finishing up. Need to fix exhaust leaks, tighten up steering. Has a little death wabble at about 40 mph. The tires are toed in about 1/4" in the front..should i go more..or less.
Nice having a dana 60 front...front wheel drive burn outs rock. :D
Also wouldn't mind finding a serpentine set up for a sbc..dang power steering pump wont stop slipping the belt..
Still waiting for my custom covers..that have "predator" cut into them..cant wait..
Old September 7th, 2012, 09:43 PM   #57
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Can you adjust your caster? If thats what its called or pinion angle adjustment, adjust you upper links, I took some caster out of mine and it fixed the death wobble.
Old September 9th, 2012, 08:19 PM   #58
big86inthestixx
Well i adjusted my tow/toe of the steering. Adjusted it so tires are parallel to eachother. Fixed the death wabble. Steering was acting up, just needed to snug the belt up witn 36" of pry bar.
Definitely needs hydro. But as long as the belt stays snug itll do for now. Gotta try to work all the bugs out before i beat it up at turtle ridge the weekend of October 13,14. Getting more and more excited.
Batteries are still sh!t, cant start the jeep without a jump.
No new pics today.
Old September 14th, 2012, 08:33 PM   #59
big86inthestixx
Got my bump stops in and limit straps on. Taking it out and wheeling it tomorrow.
Used the hi lo at the shop to flex it out today. It flexes nice. Loving the four link.
Wheeling pics, and limit strap pics tomorrow
Old September 15th, 2012, 04:38 AM   #60
jhnyquest
goof ball
jhnyquest's Avatar
Nice
Page generated in 0.50003 seconds with 84 queries
