"The Predator" another YJ build. - Page 22 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 22nd, 2013, 05:18 PM   #421
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
Glad to hear a rebuilt is not required prior to Loonie...
Running low on time.
Cheap Thrills Off Road
Old September 22nd, 2013, 07:50 PM   #422
Grassman
2jz specialist
Grassman's Avatar
Old September 23rd, 2013, 03:48 PM   #423
big86inthestixx
big86inthestixx's Avatar
Well xaust is done..yaay! Sounds gooder, and has a quite a bit more torque than it had with open headers. Idles nicer and doesn't stall when I let off the gas at high speeds.
Runs waaayyy cooler than the ol 360 chevy did. Throttle response is awesome. Cant wait to feel it on the trails.
After xhaust shop I went to scrap a long needed truck load of steel..n well I happened across this gem.
Looks like itll work mighty nice for a hydraulic ram mount with some cutting n drilling.
Piece of 1" steel bout 20" x 8"...
sended frum dis stoopid fone
Old September 23rd, 2013, 05:15 PM   #424
1" thick ram mount?
You planning to use it to ram things?
Old September 23rd, 2013, 05:42 PM   #425
big86inthestixx
Figured itd work to fill the void between the clevis ends..lol
Maybe ill do 2 pieces of 1/4"..lol
Old September 23rd, 2013, 05:42 PM   #426
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
1" thick ram mount?
Mine is 1/2" and all sorts of bent....1" may be a little over kill but the piece of mind would be nice
Old September 23rd, 2013, 06:22 PM   #427
The ram he is using is the same ram as me. The open area between the mount is just over 1". So that fits nicely between the clevis mounts and doesn't allow for alot of slop.
I bounced mine into a rock bending the tie rod and breaking the clevis ears off, the mount didn't move.
Old September 23rd, 2013, 07:00 PM   #428
Gotcha. I was thinking of the typical plate you see under a double ended ram. (which I just discovered I have zero pics of mine ) I stand corrected.
Here is Tab's.
Great Lakes 4x4. The largest offroad forum in the Midwest - View Single Post - 2 ton shit missle *UPDATED ON 8/8/09*
Old September 23rd, 2013, 07:12 PM   #429
big86inthestixx
Ahh I c senior.. (Spanish not old lol)
Na planning on doing SE ram like Ramos. See if I can get that done this winter.
Still cannot believe how awesome it is to go out n fire the jeep up, it sets n idles, stays a descent temp of 170 ish at idle, good 40 psi oil pressure at idle. .
Can't wait to see how mucb fuel it doesn't use compared to the 360..hahaha. ot that it mattered, just curious.
:thumbup:
Thanks for all the help so far guys. .been awesome.
Old September 23rd, 2013, 07:44 PM   #430
big86inthestixx
Gots me sum trim for my holez tonight too.
Thanks
Definitely purdied them up a bit.
:thumbup:
Can't be having me any rusty, sharp holez in my hood yo.
Now I need to git me a lifetime 13.5" dual row LED light bar for under my hood hoop .
Hmmmm
Never ends does it. Lol
Old September 23rd, 2013, 08:02 PM   #431
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I'm running the same type ram....i'm only running 1/2" tabs for clevises....those are not bent and it really doesn't slop around....my 1/2" skid is what is bent.
Old September 23rd, 2013, 08:06 PM   #432
big86inthestixx
Whatd u do for a skid round ur ram?
Old September 23rd, 2013, 08:15 PM   #433
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Ram mount
You kinda see the skid here.....its 1/2" plate welded to the axle tube, ran under the ram/tierod then bent up at an angle.....i did bend it some but to be fair when it bent it was because i fell off a 4' ledge and landed with the entire weight of the truck on just that skid....it only bent minimally so i guess it works
Old September 23rd, 2013, 08:31 PM   #434
big86inthestixx
This is what i was thinking of doing. .if it shows up.
Then simular skid to protect it, but since itll be on my high steer arm I should have less of an iss smashing it..
Old September 23rd, 2013, 09:00 PM   #435
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I like it.
Old September 24th, 2013, 05:15 AM   #436
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I would like to have mine up there but i can't run any sort of high steer due to frame interference
Old October 1st, 2013, 03:17 PM   #437
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Well how was the badlands?
Mr. Beefy is online now   Reply With Quote
Old October 1st, 2013, 03:56 PM   #438
big86inthestixx
Well since ya asked...lol
It was fun, but not as fun as loonie :thumbdown:
Got to spend Friday all by myself bombing around. .had fun tried some shit I probably shouldn't have alone..but did anyway. And succeeded in some not in others.
Jeep worked great, love the wheelbase, Shorter stinger. .lol, new link setup, and absolutely love the 6.0. Had plenty of power, burned less than half the fuel I would've normally.
On Friday...I screwed around and twisted my rear driveshaft so bad it fell apart at the splines. .
Here is the start of the twist, I wheeled it till it really twisted up..lol
Had the guys in town fixer up for me for 55.00..woot! Back wheelin Friday too..
Will be building a new one out of 1/4 wall.
Ripped the heads off my steering box bolts burning from one side of the park to the other on Friday also..damn trees!..haha.
Fixed those with new grade 5s...lol napa didn't have ne grade 8s..wizzzzz
Also sheared the 5/8" heim bolt on my high steer Friday amd Saturday. .had spares fixed em all up and wheeled all day. Saturday 8ish to 7 pm
Full hydro should fix that. Damn trees again!!!
Bent my lower links on the first time out too..
So gunna do aluminum lowers, 2.25" seems good nuff eh?
Tried both these spots..alone in Friday. .almost had spot on right. Got a lil sketchy alone so stopped.
Pond trail was low. ..didn't have to hit any water to drive thru...bummer. .
Things I need to fix. .
Spring bushings in the rear
Trans cooler sucks
Hydro steering
New lower links out of aluminum.
All in all had tons of fun. .most of it alone on Friday, Saturday was all pretty simple stuff..had a small group come down, thats not into trying stuff out of their comfort zone. .
Old October 2nd, 2013, 04:51 AM   #439
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Still laughing about your exhaust pipe drive shaft... Good thinking!
Old October 2nd, 2013, 05:42 AM   #440
big86inthestixx
Odd thing was, the exhaust pipe was thicker wall then the driveshaft tube???
Stoopid. .
Page generated in 0.63310 seconds with 85 queries
