"The Predator" another YJ build. - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 18th, 2012, 04:34 PM   #21
big86inthestixx
big86inthestixx's Avatar
Sum more
Sent from my SPH-D710 using Tapatalk 2
Old August 19th, 2012, 01:33 PM   #22
big86inthestixx
Well, i guess with all the pictures i should atleast give everyone a description of what its built of..
1989 jeep wrangler
Engine!
Merlin 350 nodular iron block bored 60 over into a 360.
KB hyper pistons
Hbeams
Steel crank
Wold products mowtown 220 heads w/2.05 intake forgot exhaust and cc sizes.
Headers
Comp cams 286H w/hydraulic lifters. (should have done solids)
Comp cams full roller rockers, w/ 3/8" push rods
Edelbrock performer intake..(helps keep power band lower)
Demon 800 carb..
High flow aluminum water pump
Psc power steering pump
200A alternator for the winch and dual optimas (which suck btw) can never hold a charge.
Custom shertmetal snorkel/air intake.
Drive train
Custom built turbo 350 trans with manual valve body and 3200 stahl 10" converter
Twin stick np205 with 32 spline front output. 1410 rear yoke, flanged front
1/4" wall drive shafts
Shaved, welded, disc braked, cross drolled rotors, 14 bolt rear with 1410 yoke, and 4.88 gears, sitting under backwards xj springs
Front is a 03 superduty front with Spartan locker and 4.88 gears, soon to be 4 linked
Where i want to be..
Full hydro front, four linked rear, fuel injection. Sounds good for now.
Old August 19th, 2012, 08:23 PM   #23
big86inthestixx
Shape 136
Hopefully that worked, i filled in the four link calculator today, need to find out if these numbers will work or not.
Old August 19th, 2012, 08:32 PM   #24
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I don't see anything.
Old August 19th, 2012, 08:49 PM   #25
big86inthestixx
Cant get it to copy to here..
Anti squat: 110%
Roll center height:5"
Roll axis angle:29
Travel axis angle:179
Travel roll center:17.9"
Travel roll axis:22.42
Pinion change:124.34
Dont know if these are good or bad, everything seems good to me BUT the pinion angle change
Ill try to upload the whole excel sheet with all my numbers, hopefully someone will be able to tell me what to change for improvement.
Old August 19th, 2012, 09:17 PM   #26
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
What are the entered link lengths and separation at the frame and on the axle?
Old August 19th, 2012, 09:46 PM   #27
big86inthestixx
Set em both at 40" cause i can make that work..
Old August 19th, 2012, 09:53 PM   #28
big86inthestixx
Frame separation
Upper 28" on center
Lower 32" on center
Axle separation
Upper 4" on center
Lower 44" on center
Ground to c lower frame 26.5"
Ground to c upper frame 30.5
Ground to c upper axle 26"
Ground to c lower axle 18"
Axle c from ground 19.5"
Cg or bellhousing height/center of gravity is 43"
Hope this helps..
Old August 20th, 2012, 05:39 AM   #29
big86inthestixx
4 Bar Linkage Calculator v3.0 = Mess with these cells
Vehicle Specifications: Suspension Geometry: Geometry Summary:
Wheelbase 103.0 in Upper Links x y z Anti-Squat 159 %
Tire Diameter 38.50 in Frame End 40.00 14.00 30.50 in Roll Center Height 5 in Created 2004.12.04
Tire Rolling Radius 19.25 in Axle End 26.00 2.50 19.25 in Roll Axis Angle 28 degrees (Roll Oversteer) by
Vehicle CG Height 43.00 in Lower Links x y z Instant Center X-Axis 26 in Dan Barcroft
Vehicle Mass 4,000 lb Frame End 40.00 15.50 26.50 in Instant Center Z-Axis 19 in & Greg Blanchette
Front Unsprung Mass 950 lb Axle End 18.00 22.00 15.00 in
Rear Unsprung Mass 700 lb
Old August 20th, 2012, 09:37 AM   #30
big86inthestixx
Anti-Squat 39 %
Roll Center Height 20 in
Roll Axis Angle 13 degrees (Roll Oversteer)
Instant Center X-Axis -125 in
Instant Center Z-Axis -22 in
Upper Links x y z
Axle End 26.00 2.50 26.00 in
Lower Links x y z
Frame End 48.00 15.50 26.50 in
Axle End 18.00 22.00 18.00 in
Wheelbase 103.0 in
Reworked some numbers this morning, these numbers seem lots better.
Old August 20th, 2012, 10:18 AM   #31
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Wish I knew what all that ment....lol
Old August 20th, 2012, 10:41 AM   #32
unleashed
unleashed's Avatar
Nice jeep. Love the pics. Love the name. Predator. Pretty original. Good job. As they say "you don't buy a jeep, you build it" and you did....
unleashed is offline   Reply With Quote
Old August 21st, 2012, 05:35 PM   #33
big86inthestixx
Got my links today. Nice..good used ones, thanks to "151 proof buggy"
Get to throw them on tomorrow night, hope to be done and ready for Rocks anf Valleys on the 1st..
Old August 22nd, 2012, 08:15 PM   #34
big86inthestixx
Got new 18" fox shocks today, along with ruffstuff upper axle link bracket, and made the rest if my link brackets today. Taking tomorrow off going to get as much done as possible. Still need lockouts,drive slugs, and a 48"stick of 2" 1/4" wall DOM.
Thats about it.
Old August 22nd, 2012, 08:48 PM   #35
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Done yet?
Old August 22nd, 2012, 09:09 PM   #36
big86inthestixx
Not tilk tomorrow..lol..or Thursday..
Old August 23rd, 2012, 10:15 PM   #37
big86inthestixx
Shortened upper links and got all my brackets welded on tonight. No adjustment so lets hope it works,
Going to make new shock tabs tomorrow, i want to connect them to the top of my lower axle link bracket.
The ruff stuff bracket fit NICE, wish i had the $ to buy all the brackets from them.
More to come tomorrow, hope to be completly ready for shock oil, and nitrogen. I dont see any reason for not making it that far. :D
Getting pretty excited..
Old August 25th, 2012, 09:37 PM   #38
big86inthestixx
Got the hoops installed. They are solid. Going to try to secure grill to the hoops, as well as tie my stinger into the hoops, trying to make it as solid as possible.
Pic of the axle at full droop, i set it for 11" down and 7" up. Looks like every thing clears good. The extra inch the axle moved forward helped with clearances.
Got the brakes, installed on one side so i had to throw a tire on to see what it looked like...
Love it..cant wait to do the rear..
Old August 26th, 2012, 08:47 AM   #39
jhnyquest
goof ball
jhnyquest's Avatar
Looks good....for a jeep.
Old August 26th, 2012, 08:57 AM   #40
big86inthestixx
Give it time, if i keep cutting and whacking on the frame..someday ill.have to make it a buggy.
Besides that's what all the "cool" kids have. Now im gunna have to get some sweet aluminum beadlocks too..
The wife says sell the jeep and build a buggy.
Page generated in 0.37037 seconds with 85 queries
