"The Predator" another YJ build. - Page 17 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 23rd, 2013, 07:56 PM   #321
I used the trans am pan. I haven't read all the Pirate stuff but I have not had a problem other than losing oil pressure when I flop (DUH) or am straight up on a climb I don't belong on. I run 6 quarts of oil.
I never even considered headers. There is enough heat in the engine bay without headers adding to it. My philosophy was to keep it as close to stock as possible....... I don't need problems out in the trails. We tried a variety of exhaust manifolds, forward facing, etc and ended up using the stock truck manifolds that came with it. (mine is an 03 Escalade installed in a yj)
I also had Jim's performance do mine. Zero issues with it right from the get go. I sent him the harness & ECM. He pulled all the unnecessary wires and everything came back clearly labeled. Was literally plug & play. I wouldn't argue with the dyno tune advice but I'm not sure how much you really need it. The stock 6.0 gives plenty of umph. I have no idea what my HP is over the factory 345 HP. Jim @ Jim's Performance told me that with the minor changes that I could consider I might have another 25 HP but no guarantees. So, I'm definitely south of 400 HP and don't see the need for more. Have there been a couple times where I felt it could use more? Naturally. It's also not a drag jeep so it's fast for a jeep but not fast for a drag jeep. It's good as an all around hill climber and trail rig.
Don't waste your time with fuel delivery. Use a 60 psi minimum in-tank fuel pump & a factory pressure regulator.
I would assume yours is a drive by wire. Make sure you have the EXACT match pedal & module from the donor truck. Just because they plug in doesn't mean they are compatible. (ask me how I know )
I left my intake forward facing. Personal preference IMO, whatever works.
Good luck with it.
Old June 24th, 2013, 09:12 AM   #322
Mail order tunes are like mail order shocks, if you want your moneys worth the person needs to work directly on the vehicle. Most people will spend $4000 on an engine swap and try to save $150 on getting their moneys worth out of said swap. My $.02.
You always leave power and driveablity on the table with a mail order tune so why even look at performance stuff for 15-30 hp gains until you've done the first correctly?
Originally Posted by big86inthestixx View Post
Got tue the harness and computer pkgd up ready to ship out..maybe early next week!
This is why I never bother to comment on anything, if it's $100 cheaper to do it half assed, that's how people will do it every time.
You have one of the best resources in the state, perhaps country 46 miles from you but I'm guessing you're sending it across the country to save $150 instead
There isn't anything magic in the tuning. You have timing and fuel. There are 3 or 4 tables that you actually do work in, the rest is turning stuff on or off and fixing idle/coast issues. If your running 12.8:1 ish and you have your timing set where you make maximum torque or hp(have to be on DYNO or at the track to do this btw), you're done. I don't care who's tuning it, it's no different than a carb in that respect @WOT. I bet your file comes back to you with car timing tables and a 15% increase in fuel during PE with the delay taken out. Shit isn't the magic everyone makes it out to be.
/rant
Old June 24th, 2013, 10:35 AM   #323
Sorry you think I did it half assed.
Old June 24th, 2013, 10:38 AM   #324
big86inthestixx
big86inthestixx's Avatar
Where is this said place?
don't believe ive ever heard of it?
/rant
sended frum dis stoopid fone.
Old June 24th, 2013, 11:32 AM   #325
my suggestion is to find someone to tune it in your rig on a dyno, TJ @ baker engineering maybe.
If only someone would have suggested such a place
Old June 24th, 2013, 11:37 AM   #326
You put a stock engine in without changing much, you're probably getting 80% of what's there, which you said yourself is fine. I don't see Jim going too high with your timing being a LQ9 originally so you're probably running LS2 timing files and a fattened up PE curve to cover the timing increase when it matters. If you're ok with leaving XX% on the table, that's none of my business. I was making a general statement, nothing personal.
Old June 24th, 2013, 11:55 AM   #327
big86inthestixx
My harness was done by Jims performance. TJ @ baker engineering maybe. .
So we differ from you How?
Maybe. ..doesn't sound like a for sure thing to me. ..
Just sayin..:thumbup:
Old June 24th, 2013, 12:38 PM   #328
I don't claim to be super techy. My observations is that in many cases, when people try to optomize engines right to 100% capability, they often give up some reliability. That said, there's nothing wrong with that, especially in a competition world. But for me, my needs are not competitive so I'm more content with not worring about it. I just took it as you saying that anyone not optimizing 100% was doing it half assed.
All is good. Carry on.
I'll also add that my swap was done in 2007 which at that time was a little more rare. There are certainly more people around now that know more about it.
Old June 24th, 2013, 02:24 PM   #329
Other than tuning my own and understanding the benefits of having someone work on the specific vehicle in person, not a thing.
Old June 24th, 2013, 03:01 PM   #330
big86inthestixx
So u "dyno" tuned urs after jim did your original computer burn?
Sorry I am confused...it happens easily:p
I understand the benefits of the dyno tune also and where you are coming from. :thumbup:
But I think I feel the dyno tune would be a simular performance gain as to the roller rockers. .few HP max for +300.00.
And the other performance adders wouldn't do dick if it wasn't dyno tuned.
I figure do the same have my harness and comp done mail order, if im NOT happy with performance then ill dyno tune it. Or get the program to do it myself for a day. .:D sounds like fun to screw with.
plus after I get it all in I may want MOAR POWAR..if that's the case ill have to get a local guy to tune anyway.
Old June 24th, 2013, 03:09 PM   #331
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I would assume the dyno tune would bring reliability more than the performance.
Old June 24th, 2013, 04:15 PM   #332
I've been making this whole thing up, forget I even mentioned anything.
Old June 24th, 2013, 06:34 PM   #333
Grassman
2jz specialist
Grassman's Avatar
the dyno will make the whole package work as a unit. gears, tires, case, trans and motor. the mail order tunes are a good "base" that is designed to make many customers smile with the same product. both are good and have their place. as far as andy is concerned i think mail order will be fine, but when more tweaks are added to the motor and you want to pull every last drop out of the motor.....a one off tune with a dyno helping you will be the best.
thats the opinion of the not so all knowing grassman
Old June 26th, 2013, 03:19 PM   #334
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Just carb the 6.0....yeah
Old June 26th, 2013, 03:21 PM   #335
big86inthestixx
Hahaha. .
NO!!
Old July 15th, 2013, 06:25 PM   #336
big86inthestixx
So finally got my phone back to post whoot! Gotta love nerds eh. .
Did the sand lake crawl n had a blast! Noticed my tub starting to wrinkle where the fender meets the body.
Fixed with a hammer for the weekend at r and v, now again body is wrinkled?
Going to have to finish tying cage in the front to the frame. Howd u do it? Anybody?
Also got some new to me seats from Don at r and v...thanks!
Thems goin in tonight!
Loving the 7075 alum tie rod, left gitter on some rocks this weekend and its still str8 as an arrow!
Bumps worked well, did some lil bunny hops thru the python with some new wheelers on Sat bumps landed smoothly.
Still happy with height and length, ready for full the 6.0 though!
Itching to sell the sbc carb engine and go FI..
Old July 15th, 2013, 06:31 PM   #337
Wramblerguy
Wramblerguy's Avatar
My dad put a hoop in front of the radiator and bars going from the hoop along the fenders through the firewall right into the windshield hoop
It has help up through multiple roll overs
3rd generation jeeper
Old July 15th, 2013, 08:21 PM   #338
big86inthestixx
Buying some tube this week tomorrow. ..need to beef this thing up! Going to do some sirrius cage work...hope the HF tubing kinker is up for some small bends!
Made a list tonight.
Need get my azz in gear! If im gunna do club comp with anyone I need to bring the beef.
Designed a dana 60 truss for my superduty 60 tonight, get it made on lunch tomorrow!
Shorter pitman arm dbl sheared ready to weld! And the splines aren't stripped on it..yaay
plus iz shrinking the hauler from 28 feet to 16 feet of deck!
Lighting fires and burning tires this week!
Old July 15th, 2013, 08:45 PM   #339
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
You are welcome to borrow my bender.
Old July 16th, 2013, 05:45 AM   #340
big86inthestixx
I may do that! I around Saturday?
Should only need it for a week.
That would b greeeaaat..
Page generated in 0.70350 seconds with 84 queries
