"The Predator" another YJ build. - Page 16 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2013, 05:39 PM   #301
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Sweet!
Old June 9th, 2013, 05:58 PM   #302
Read up on oil pans and traps.
Old June 9th, 2013, 06:09 PM   #303
big86inthestixx
big86inthestixx's Avatar
Was planning on a hummer or a trans am oil pan, I like Hummer bc it still keeps the 6 quart capacity or more. But its not as shallow as the trans am. Oils more important then pan depth! .
Any recommendations for cheaper headers? Or just keep the manifolds?
sended frum dis stoopid fone.
Old June 9th, 2013, 06:13 PM   #304
I would read more on oil pans and traps
Old June 9th, 2013, 06:22 PM   #305
big86inthestixx
Will do. Thanks feva..
Old June 9th, 2013, 06:38 PM   #306
There's a long ass thread on pirate about it but I can't find it from my phone.
Old June 9th, 2013, 06:55 PM   #307
big86inthestixx
Yeah. .ive read and printed most of it..but it gets longer every day. .lol
Old June 15th, 2013, 09:30 PM   #308
big86inthestixx
Whoot! Got my RuffStuff LS motor mounts today!!!.
Almost ready to send my computer and harness to "waynehartwig" over 9n pirate to do the harness work and re program the computer. Another short week and ill have enough $$$ to get it.
Getting a VSS and tone ring from a np241 to put on the output of the np205 so the computer can use it.
Having the emissions removed, the vats removed, keeping everything else. Asking for the highest hp tune he offers. Says its 80+ hp? Fingers crossed ill have as much or more power than I have now.
Keeping the stock oil pan until I can buy a kevko pan. Keeping the stock truck intake for torque.
Debating on spinning the intake so its on backwards to put the air cleaner in the cab of the jeep.
Also found out I have the 218 heads...which are a lower compression ratio, going to put the motor in and decide if I need the extra power.
Here's tye the motor mounts
Here's the pan I plan to get
Still trying to decide what to do for fuel. .LKQ?? Otherwise its gunna b a 400.00 bill for pump regulator lines etc..
Old June 15th, 2013, 10:10 PM   #309
Oh yes, the 80 HP tune
Old June 15th, 2013, 11:35 PM   #310
big86inthestixx
Kinda what I thought, but I personally can't diss him till in know. Giving him a chance seems everyone on pirate is happy with his work.
Feva do u have a ls? If so whatd u do for power adders?
Old June 16th, 2013, 01:13 AM   #311
I know nothing
Old June 16th, 2013, 07:35 AM   #312
disturbedsledneck
disturbedsledneck's Avatar
Awesome build just got awesome.
I will be relying on you to do all the research and get that 6.0 in with all of the bugs worked out. I tried reading the thread on Pirate and my head was spinning from information overload.
Keep up the good work.
disturbedsledneck is offline   Reply With Quote
Old June 16th, 2013, 09:06 AM   #313
big86inthestixx
Thanks sled neck. ..
U local to me, I see a jetta with "slednecks" sticker on it all the time. If so, swing on in.
Feva: who did ur work? Thought about doing the harness myself, and having a local guy do computer work. But seems wayne has good reviews, jims performance is also supposed to be a good choice...whod u recommend. ..obviously u know SOMETHING. HAHAH
Old June 16th, 2013, 07:45 PM   #314
My harness was done by Jim's Performance. He pinned 2 things wrong but it was fine other than that. You can probably do your own harness, I was on a time crunch. I tune with HP tuners. People are happy with wayne but do you really think gm left 80 HP on the table on a 325hp engine? 20-30 with added timing and leaning it out, maybe.......my suggestion is to find someone to tune it in your rig on a dyno, TJ @ baker engineering maybe. Mail order tunes are like mail order shocks, if you want your moneys worth the person needs to work directly on the vehicle. Most people will spend $4000 on an engine swap and try to save $150 on getting their moneys worth out of said swap. My $.02.
Old June 17th, 2013, 01:56 PM   #315
Intake info. Basically, stick with whatever works with your accessories so the truck intake in this case.
http://ls1tech.com/forums/12945651-post4.html
Old June 17th, 2013, 02:46 PM   #316
big86inthestixx
Yep..planned on that, especially to keep some torque.
Pondering doing some port/polish work to the heads while its out.
BUT I think ill put it in, see if im un happy with the power, then change it.
Got my starter and intake set today, to spin er around.
Looked at 1.8 roller rockers, if they gave a little more power itd b worth the 300.00, but It seems with an ls, head work and camshaft are really the only way to go for more power..
Ready to go wheeling, bummed my next available date isnt till july 13th...rocks n valleys. .then the 10th again to watch bounty hill! Whoot.
Still need to get some seats. .but cant find anyone whos got em on the shelf to set in..hate to spend 300 bux on seats that suk.
Old June 17th, 2013, 03:05 PM   #317
It's negligible between the two if you read the link I posted
Unless you know wtf you're doing, don't.
BUT I think ill put it in, have it tuned by someone that knows wtf they are doing, put it on the chassis dyno and see if im un happy with the power.
This
Forget you even seen them.
You always leave power and driveablity on the table with a mail order tune so why even look at performance stuff for 15-30 hp gains until you've done the first correctly?
I'll leave it alone now
Old June 22nd, 2013, 10:59 PM   #318
big86inthestixx
Well..
Intake is off n back on backwards! Cleaned it up, new gaskets and back together. Whoot!
Got tue the harness and computer pkgd up ready to ship out..maybe early next week!
Got tye the old manifolds off, and got all but one broken off bolt off out of the heads. Started with 5..Pisser. ..
Also got old motor mounts off, starter is now here.
Plugged the tb coolant ports in the intake and in the block. Left rhe the little crossover tube though.
New plugs n wires next week...maybe headers soon to follow.
Old June 23rd, 2013, 03:28 PM   #319
big86inthestixx
Gave up selling my 1 racing seat, put it in the passenger side of tue the jeep. Wife will like it, now I need to find another even though im not sure I like them, I think I need to just get over it!
Nice n comfy without a big ol steering wheel in the way. .lol.
Maybe a detachable one or a smaller wheel? Whats the best idea?
I like the big ol bus wheel cause it makes it easy to steer.
Detachable. .I guess I could get uses to.
Old June 23rd, 2013, 05:03 PM   #320
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I need some fancy seats too.
Page generated in 0.39073 seconds with 84 queries
