"The Predator" another YJ build. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2012, 11:07 PM   #1
big86inthestixx
big86inthestixx's Avatar
Default "The Predator" another YJ build.
This is my first time starting a build thread. Started out as 1990 jeep Wrangler 6cyl auto. Not running. Previous to it i had a 1986 chevy 3/4 ton pickup. The had a head on collision.
Motor, trans, tcase, axles, and YES the chevy emblem were put into the jeep.
Id start at the beginning, but dont know how to upload actual pictures. So ill start with a few years ago. With lots of pictures, every one likes pictures.
Sent from my SPH-D710 using Tapatalk 2
ID:	95625   Click image for larger version
ID:	95626   Click image for larger version
Old August 16th, 2012, 11:19 PM   #2
big86inthestixx
Frame removed for the rear straightening and raising for backwards xj springs.
Pic2
Side view of frame cut and removed, with xj main leaf in there.
Pic3
Body notched and tubes ran through for bumper attachment.
Pic4
Side view of the frame straightened and put through rear of the body. Welded on, but not fish plated yet.
Pic5
Pretty much finished with stretch and xj spring install. Bimper reattached. Puts my wheel base at 100".
Pic6
View of custom stanless fuel cell, moved up through the floor under the rear seat.
Pic7
Rear view of 30 gallon fuel cell..holds LOTS of premium fuel.
Pic8
Bottom view of 3/16" skid plate protecting 30 gallon 14 guage stainless fuel cell.
ID:	95630   Click image for larger version
ID:	95631   Click image for larger version
ID:	95632   Click image for larger version
ID:	95633   Click image for larger version
ID:	95635   Click image for larger version
ID:	95636   Click image for larger version
Old August 16th, 2012, 11:31 PM   #3
big86inthestixx
Pic1
After moving axle back i had to re make traction bar, and its bracket. I used this time to separate my bars more from 6" to 9" to help control ths 39.5s a little better.
Pic2
Old traction bar top, new traction bar bottom..lots stronger 1.5" 1/4" wall dom.
Pic3
Belly shot, needs a skid plate. On the up side after moving my axle back i could move my cross member up 4" from where it was, this should help lots in the trails. No more droopy gut/muffin top.
Pic4
Pic of newly installed, 98 dodge ram 2500 master cylinder. Waaaay better brakes. One of the easiest mods to the jeep with tje best results...so far.
Pic5
At the same time i stretched the rear, may as well shave my 14 bolt, so this is a pre pic..
Pic6
This is an after the 14 bolt shave..
Pic7
This is how much was removed.
Pic8
This is a rear lower shot of the almost finished stretch and shaved jeep...
ID:	95638   Click image for larger version
ID:	95639   Click image for larger version
ID:	95640   Click image for larger version
ID:	95641   Click image for larger version
ID:	95643   Click image for larger version
ID:	95644   Click image for larger version
Old August 17th, 2012, 09:36 AM   #4
big86inthestixx
Pic1
Here is a pic of the stretch, stance after all the work was complete.
Pic2
Next batch of picz are me testing out the flex after the stretch.
ID:	95646   Click image for larger version
ID:	95647   Click image for larger version
ID:	95648   Click image for larger version
Old August 17th, 2012, 09:37 AM   #5
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
looking sweet man!
You should upload you pics to photobucket (get the ap) and link them. Then your pictures will be big.
Old August 17th, 2012, 09:39 AM   #6
big86inthestixx
Now after moving the motor trans, t case up 4", i decided to finally get serious and do a 1/4" skid plate. So here is a pic of the fabrication of it.
The last is a pic of the installed skid plate..love it.
ID:	95650   Click image for larger version
ID:	95651   Click image for larger version
ID:	95652   Click image for larger version
Old August 17th, 2012, 09:48 AM   #7
big86inthestixx
Pic 1
On top of the louvers in the hood,i decided to vent the engine compartment and help kool it a little better.
Pic 2
Disassembled the iroks so i can get to welding all my bead locks on.
Pic 3
Just a quick fitment check.of the DIY beadlocks..
Pic4
Inner rings tacked on
Pic 5
First one welded and cleaned up. Double pass with the mig. Hope they hold air.
Pic 6
Before and after the anti coning rings were on
Pic 7
Outer rings primed ready for paint.
Pic 8
Painted outer rings...look nice
ID:	95654   Click image for larger version
ID:	95655   Click image for larger version
ID:	95656   Click image for larger version
ID:	95657   Click image for larger version
ID:	95659   Click image for larger version
ID:	95660   Click image for larger version
Old August 17th, 2012, 09:53 AM   #8
big86inthestixx
Pic 1
Inner rings painted..
Pic 2
First set bolted..wow thats alot of bolts, all torqued and filling with air. Lets hope no leaks. Turns out they hold air for Very well.
Pic 3
Finished product, all full of air and mounted to jeep. Sweet..now for some carnage. We will c what happens to the 10 bolt front with all that traction.
ID:	95662   Click image for larger version
ID:	95663   Click image for larger version
Old August 17th, 2012, 09:59 AM   #9
big86inthestixx
Did some wheeling at the blessing of the jeeps this weekend, as usual something always blows up. Well here is the pictures of the carnage.
Pic 1
Twisted spring shackle, should have been 3/8" or gusseted.
Pic 2
Blew a usa alloy u joint, and took ears out on the 10 bolt.
Pic 3
Bent chromoly cross shaft
Pic 4
Twisted splines on the chromoly outers for the 10 bolt.
Good weekend..lol i see a dana 60 working its way up front soon.
ID:	95665   Click image for larger version
ID:	95666   Click image for larger version
ID:	95667   Click image for larger version
Old August 17th, 2012, 10:26 AM   #10
big86inthestixx
Pic 1
Got myself a superduty dana 60 front with factory 4.30 gears. Good deal, now for the real work. Going to make this superduty 60 a passenger side drop.
Pic 2
Getting a jig built to hold the axle where i need it..
Pic 3
Tubes all swapped and new 4.88 gearz and spartan locker installed.
Pic 4
Close up of gearz and locker installed...nice
Pic 5
Pic of the 10 bolt removed, niw to remove all my leaf spring hangers..
Pic 6
Hangers removed getting ready for triangulated 4 link.
Pic 7
More with no brackets and no axle.. Getting closer.
Pic 8
60 setting in place, selling whatever i dont need any more for air shocks..
ID:	95669   Click image for larger version
ID:	95670   Click image for larger version
ID:	95671   Click image for larger version
ID:	95672   Click image for larger version
ID:	95674   Click image for larger version
ID:	95675   Click image for larger version
Old August 17th, 2012, 10:36 AM   #11
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Nice rig. I plan on venting my fenders like you did. What did you use for vents on your hood?
RIP FULLSIZE4LIFE
Old August 17th, 2012, 10:44 AM   #12
big86inthestixx
Stamped steel louvers, make em at my work..
Old August 17th, 2012, 10:50 AM   #13
big86inthestixx
They look similar to this. Just not quite as big.
Old August 17th, 2012, 09:30 PM   #14
big86inthestixx
Well made myself a mini press brake for my shoo press so i can get to bending some heavy steel for trusses, frame brackets etc..
Also got some 1/8" wall 1.5" dom for shock hoops. Some pvc for practice fit links, and tore down two turbo 350 trans for some part $...and a third on its way tomorrow..wahoo.
Also stole a really good idea from a friend. A double shear pitman arm..i like it.
Try to get some actual work done on it tomorrow. :thumbup:
ID:	95687   Click image for larger version
ID:	95689   Click image for larger version
ID:	95690   Click image for larger version
Old August 17th, 2012, 10:01 PM   #15
big86inthestixx
Brake works pretty good..for cheap..
Old August 18th, 2012, 03:19 PM   #16
big86inthestixx
I have the app..and all the pics are uploaded there, but my smarter than me phone wont tell me how to link them.
Old August 18th, 2012, 03:37 PM   #17
Select a photo, then hit the menu buttom. Should ask different options, one being view links
then copy the [img] link
Old August 18th, 2012, 03:57 PM   #18
big86inthestixx
Well thinking we got it figured out, thanks.
Blew the cheapo bender apart today trying to bend 3/16"wall DOM...dont ask got it cheap. Was trying to bend shock hoops.. And this os what happened.
Old August 18th, 2012, 04:29 PM   #19
big86inthestixx
Let try a you tube link...
See if i can get a few videos uploaded,
Old August 18th, 2012, 04:30 PM   #20
big86inthestixx
Another you tube..video.
Page generated in 0.56761 seconds with 85 queries
