lock bolts / washers that work the best? Atlas cover bolts keep coming loose - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2012, 10:09 AM   #1
knaffie
knaffie's Avatar
Default lock bolts / washers that work the best? Atlas cover bolts keep coming loose
Apparently the bolts on the cover of my Atlas came loose because I have a puddle of oil on my skid and nothing showing in the sight tube. :shaking:
Unfortunately, getting to these bolts means pulling the tcase out, which means taking the floor and seats out - not a fast job.
I want to use whatever is most effective to keep the bolts from coming loose. I've never had any luck with normal split washers. I've had the best luck with this style. I'm thinking these style bolts and red Loctite. Any other input?
Old August 16th, 2012, 10:13 AM   #2
Do you realize that if applied properly, red loctite requires heat to get them loose? I prefer blue.
Old August 16th, 2012, 10:16 AM   #3
knaffie
knaffie's Avatar
The blue is useless to me. I gave up on it years ago. I've never yet had to apply heat to get the red apart. Its definitely a lot tougher than blue, but I can always get it out with a ratchet or wrench. And once it "breaks the seal" of the initial bond, they turn out increasingly easier.
I want to overkill the hell out of this. I'll use red Loctite AND.........
Old August 16th, 2012, 01:35 PM   #4
TopHeavy
Yikes!
TopHeavy's Avatar
..... Safety wire.
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old August 16th, 2012, 01:36 PM   #5
knaffie
knaffie's Avatar
I did learn that AA swited to the serrated bolts shown above. I ordered them. I'm actually considering safety wiring it too.
Old August 16th, 2012, 02:07 PM   #6
firehawk
Live Action!
firehawk's Avatar
I will take that atlas problem off your hands, just ship it to me.
Those serrated bolts and red should do it.
Old August 16th, 2012, 02:51 PM   #7
If you are using red loctite and you don't need heat......... you are not applying it properly. Go through a loctite class and learn about the solvents and cleaning required to make it work as designed. Most people just dab some on the bolt and screw it into an oily hole accomplishing nothing.
My covers haven't come loose "yet". I don't understand why you are having the problem. Seems odd to me.
Old August 16th, 2012, 03:11 PM   #8
firehawk
Live Action!
firehawk's Avatar
Originally Posted by deerebowtie View Post
loctite class, is this for people who pay for friends? err, i mean club members only?
1%ers of course
If you can't fix it with a hammer you got an electrical problem is my motto.
Want me to fix that car for you?
Old August 16th, 2012, 03:36 PM   #9
Obviously you are not involved in building robust, precision equipment.
Old August 16th, 2012, 05:48 PM   #10
I don't know. Do you have issues with bolts coming loose on your components? Are they subjected to high heat, loads, vibrations? Do your employees slop stuff together or do they know how to actually use the products properly?
I thought I knew a lot about fastener containment till I sat in a session. I was surprised at how much I did not know. Now, back on topic, if you can loosen red loctite without heat, you are not applying it right.
Page generated in 0.22601 seconds with 53 queries
