Tire pressure - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2012, 08:22 AM   #1
yoopermike
yoopermike's Avatar
Default Tire pressure
Hey guys, newbie here to the Zuk world. I'm wondering what everyone is running for tire pressures on/off road. It's an 88 Samurai, mild lift, front/rear bumper, winch, 31 inch PJ dirt grips on 8 inch rims. Thanks.
yoopermike is offline   Reply With Quote
Old August 16th, 2012, 10:12 AM   #2
trailtwister
Don't Insult My Stupidity
trailtwister's Avatar
You might be a little lighter than my Jeep TJ, but I run 8 to 10 lbs on 33x12.50x15 with no problems.
trailtwister is offline   Reply With Quote
Old August 16th, 2012, 02:34 PM   #3
yoopermike
yoopermike's Avatar
With me in it, and a full tank of gas, I'm assuming I'm somewhere around 2500-2700 lbs. Still haven't checked on a scale yet. I'm assuming 8-10 is for offroad. What about a good and safe pressure for daily driving duties? I have them at 25 now and it feels like I'm driving a rock. Just don't want to go too low on the DD side. Thanks.
Old August 16th, 2012, 07:05 PM   #4
A4X4SPIT
A4X4SPIT's Avatar
I run my rigs around 16 lbs for the street( around town) unless Im going on a long trip then 20lb. lower if needed off road. I go down to 6-10at the dunes and closer to 6 for snow wheelin .and Ive never had a bead come off but I think my rims are narrow I played with different pressure's when I first got my rig road ready and16 seems to be a good pressure(for me anyways ) for the samura'is(5)Ive had too. If I run much lower on the road It feels a little squishsy more than 16 kind like the afore mentioned rock. mabee just play with it till ya find that magic number
<<<<<<<<<<16lbs<<<<
A4X4SPIT is offline   Reply With Quote
Old August 16th, 2012, 07:48 PM   #5
XJcoupe
1ton XJ
XJcoupe's Avatar
25 lbs. is great for gas mileage on the interstate say doing 70 mph, locally just around town 16-20 lbs for a more comfy ride
Old August 17th, 2012, 05:18 AM   #6
yoopermike
yoopermike's Avatar
Thanks everyone. I'm not too concerned about the gas mileage. It's a weekend warrior/fun machine. I'm just looking for a safe, comfortable range to be in without having to worry about losing a bead. I guess I have some experimenting to do, starting with 20 and working my way down....
Old August 17th, 2012, 07:31 PM   #7
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
I would bet you'll run close to 8lbs and still keep the bead.
Cheap Thrills Off Road
Old August 17th, 2012, 10:08 PM   #8
scottie
Eye candy
scottie's Avatar
I have 31's on mine. Run 30ish on the street. I've ran as low as 4 without breaking a bead, but usually i run 5-8 offroad.
much higher than that and it's pretty useless offroad
Old August 22nd, 2012, 03:17 PM   #9
yoopermike
yoopermike's Avatar
16 seems to be the number for the street and mix of trail road driving. Haven't gotten into anything worthy of airing down any further. Yet.
Old August 22nd, 2012, 04:44 PM   #10
BigBird
BigBird's Avatar
For on road, best way is to do the chalk test... Basically find a flat area of pavement or concrete rub chalk across the tread... Drive in a straight line and see where the chalk where's off the most... Lower the pressure if it wears more in the middle, or increase the pressure if it wears more on the outside edges...
Old August 23rd, 2012, 11:23 AM   #11
yoopermike
yoopermike's Avatar
I'll try that, someday. Aired down to 10 just to check it out last night. Loved it for creeping thru the woods. Also went and weighed my rig today. At 2900 lbs even with me in it, 1.6L tracker motor, a full tank of gas, front/rear bumper with winch, no top, aluminum half doors, bare bones tools, recovery gear, and a spare tire. I don't know if the scale is 'certified' or not, ran it over to the local Waste Management center.
Last edited by yoopermike; August 23rd, 2012 at 12:02 PM. Reason: forgot something
Old February 23rd, 2013, 07:02 PM   #12
Freebird01
i typically run mine at 30 on the street (yea im a glutton for punishment)... offroad ive always run around 10-12psi with no issues
Freebird01 is offline   Reply With Quote
Page generated in 0.22171 seconds with 59 queries
