speed sensor on a 2000 f350 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 16th, 2012, 06:45 AM   #1
kickstand
circling the drain
kickstand's Avatar
Default speed sensor on a 2000 f350
my cruise stopped working, then I started getting these faint beeps from under the dash, and then the speedo started jumping all over the place, and then the OD "off" light on the shifter started blinking......and then....everything went back to normal.
A few people suggested speed sensor, but it looks like there are more than one? (not sure I just checked rock auto breifly but they looked different).
How do I know which one to replace? Even better, since there are no check engine lights can it be scanned to determine if that is truely the problem?
shpanks
Old August 16th, 2012, 07:12 AM   #2
87mopar
Web Wheeler :(
87mopar's Avatar
My 00 250 did something similar to that with the speedo going crazy, I only have the speed sensor in the rear diff. I have a manual trans. I replaced it and problem solved.
Sent from my iPhone5 using Tapatalk
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old August 16th, 2012, 07:48 AM   #3
kickstand
circling the drain
kickstand's Avatar
That's the one bones said to replace, but not sure why I was seeing different part#'s and hate ti just throw parts at it
Old August 16th, 2012, 08:27 AM   #4
87mopar
Web Wheeler :(
87mopar's Avatar
Hmm, I just got an autozone part because I knew I had only one sensor. It asked a few basic questions. If you have ABS that's a different part number I believe.
Old August 16th, 2012, 08:29 AM   #5
tom77cj5
tom77cj5's Avatar
There's only one in the rear diff its the all plastic one
Old August 16th, 2012, 08:57 AM   #6
Bones
Bones's Avatar
diff.
unplug it and see if your speedo works. It won't. Schedule 4 hours to replace sensor in your garage. Drink a beer, grab one socket, replace sensor, contnue drinking beer for 3.5 hours.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 16th, 2012, 09:01 AM   #7
87mopar
Web Wheeler :(
87mopar's Avatar
10mm socket there now 3.75 hours to drink beer
Old August 16th, 2012, 01:28 PM   #8
Bones
Bones's Avatar
it will take him 20 minutes to find a 10mm socket and wrench.
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 16th, 2012, 02:06 PM   #9
kickstand
circling the drain
kickstand's Avatar
No sir, my shits all fancy pants organized. Beer drinking shall.commence.
Old August 16th, 2012, 02:13 PM   #10
zebrazuk
First day on the job
zebrazuk's Avatar
Yep, same thing on my 99 with auto trans, two sensors and the one in the diff was the one flaking out!
zebrazuk is offline   Reply With Quote
Old August 16th, 2012, 02:20 PM   #11
MilwaukeeF350
Dan
Had 2 sensors on transmission and rear axle.
Previous owner replaced sensor then last week I replaced again on rear axle.
It only $12 buck at advanced. They don't like water and heat.
You watch closely to speedo it will moving but sometime it tick like clock do.
When you see try hit top dashboard did it bounce crazy.
Keep driving with issues will ruin transmission fast.
Old August 18th, 2012, 11:08 AM   #12
kickstand
circling the drain
kickstand's Avatar
yeah the speedo was dancing all over. Started at about west branch, and by the time I got to petoskey the speedo wasn't even working at all just fluttering all over. Got in the truck to come home and the OD Off light blinked for about 10 minutes, then it stopped blinking and everything went back to normal from petoskey all the way back home to fenton. The truck drove as normal the entire time, even when the speedo was acting wonky. Haven't driven the truck since.
Bought the sensor and replaced this morning. we'll assume this will fix it.
Thanks
Old September 12th, 2012, 10:30 AM   #13
14muddn
My speedo was jumping all over the place and then stopped all together about a week ago. I replaced the sensor in the diff and it still jumps around or doesn't work. '00 6 speed. I think I may have some wire issues under the truck with this and my esof though.
Old November 12th, 2012, 10:52 PM   #14
gear_grinder
jump the sensor to a multi-meter and have a friend spin the rear tires or put the truck into drive (back tires off the ground obviously), you should get a fairly smooth voltage signal. if not then sensor/trigger wheel, if you do get a smooth voltage signal then its wiring or something else in the circuit.
gear_grinder is offline   Reply With Quote
Page generated in 0.36650 seconds with 65 queries
