Brake pressure loss - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 15th, 2012, 12:34 PM   #1
spiderman32
GETTING THERE
spiderman32's Avatar
Default Brake pressure loss
So i was out at bundy hill this weekend and i started losing my brake pressure intermittently. I stopped to check it out, but there were no leaks and i believe i checked for any vacuum issues. Any ideas? is it my master cyl???
spiderman32 is offline   Reply With Quote
Old August 15th, 2012, 01:45 PM   #2
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
sounds like it. Fluid level wasn't super low and you were way off camber were you?
Old August 15th, 2012, 01:47 PM   #3
montecarlo33
The Violator
montecarlo33's Avatar
if you have rear drums make sure the cylinders arent leaking. Thats where my last truck leaked and it was hard to see.
Old August 15th, 2012, 03:32 PM   #4
spiderman32
GETTING THERE
fluid was good, just redid all my brakes, and yes it happened more and more while i was up and down hills and pitching.
Old August 15th, 2012, 03:37 PM   #5
Rob the plumber
if the fluid was full, I'd suspect the master cylinder.
Page generated in 0.15578 seconds with 38 queries
