Walker Flexas Ranger - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 11th, 2013, 08:23 PM   #161
Toyfish
Toyfish's Avatar
Use the 1354 case and just pop the motor off the side and fab up a shifter for it then u wont spend days figuring out the electrical part of it. Im not a big fan of the electronic tcase shift motors anyways ive changed way to many of them.
Sent from my DROID X2 using Tapatalk 2
Old April 11th, 2013, 08:30 PM   #162
powerranger33
powerranger33's Avatar
I got one I got off of Kyle a while back. It's 1350m/1354m, can't wait to finish my ranger so I can finally get to use it.
powerranger33 is offline   Reply With Quote
Old April 11th, 2013, 08:37 PM   #163
deathbypsi
Brian R.
deathbypsi's Avatar
Ok a 1354 it is. I kept every bit of wiring for the t-case from my B2 so I should be able to make it work pretty easy.Strangely I kinda enjoy a good wiring project.
So if I take the doubler apart I can just swap out the 4 pinion for a 6 pinion out of one of my other 1354's? Its that simple?
Old April 11th, 2013, 08:44 PM   #164
Toyfish
Toyfish's Avatar
The occasional wiring project can be fun but mostly i stay away from wiring and go with the simple mechanical way to make things work.
Old April 16th, 2013, 06:41 PM   #165
89yjon
89yjon's Avatar
When I get home I'll look for a number that a vendor gave me when I was at the bantam jeep festival. He had awesome prices on rcv shafts.
89yjon is offline   Reply With Quote
Old April 16th, 2013, 06:47 PM   #166
deathbypsi
Brian R.
deathbypsi's Avatar
best price I have got so far is 1385
Doubler will be here next Monday!
Old April 16th, 2013, 06:54 PM   #167
Damn....I built mine for next to nothing yes ago. Got some help from a buddy and we built a sweet intermediate shaft. The shaft is the key. Outside if that its easy shit.
Old April 16th, 2013, 06:55 PM   #168
I read that wrong, I thought the doubler was $1385.
Old April 16th, 2013, 07:06 PM   #169
deathbypsi
Brian R.
deathbypsi's Avatar
No I found a DD Machine kit already installed in a box,tig welded up and built by a off road shop. Never installed in a truck. 600.00
Old April 17th, 2013, 01:47 PM   #170
deathbypsi
Brian R.
deathbypsi's Avatar
So are the RCVs the way to go or would Chromos with good joints be fine for me?
Never going bigger than 37's.
About 250hp now,might go up to 400hp if I find a Kenne Bell.
Only 3.50 gears,but will have a doubler.
discuss...
Old April 17th, 2013, 02:29 PM   #171
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
discuss...
When you say good joints... CTM's? Wadey broke a bunch of chromo stuff with his blazer which is heavier and more gear but less power. I don't think he had the really good joints though. I'd say 6 of 1, half dozen of another if you are talking good chromos and joints.
BeaverTown is offline   Reply With Quote
Old April 17th, 2013, 03:03 PM   #172
Deuling
Sand Slut
Deuling's Avatar
Great build. I like the radius arm and coil over setup. Waiting to see how it works out for you
Deuling is offline   Reply With Quote
Old April 17th, 2013, 03:38 PM   #173
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Instead of spending all that money on shafts, sell your half tons, buy a 60/14 bolt and be done with it. You will be money ahead.
Or do a 9" and retro fit the front 60 to a 5.5 on 5 pattern.
Old April 17th, 2013, 04:25 PM   #174
big86inthestixx
big86inthestixx's Avatar
Originally Posted by Kyle M. View Post
Instead of spending all that money on shafts, sell your half tons, buy a 60/14 bolt and be done with it. .
This makes all the sense in tue world. Wish I would have done that. I spent tons of money on mine, hd ball joints, shafts, joints, and in the end. It was knuckles, axle shafts, and cross shafts that made my final decision.
Id do tons and be done with it, if I had to do it all over again.
Sent from my SPH-L900 using Tapatalk 2
Old April 17th, 2013, 08:24 PM   #175
deathbypsi
Brian R.
deathbypsi's Avatar
Im to deep into this truck to switch axles now. Plan is to keep it light duty as I dont think I wheel as hard as you guys anyways. This truck is gona be doing daily driving time split with my turbo Ranger so it will see way more street miles than trail miles.My old Bronco2 with a 5.0 and 35's seen about 30,000 miles over the 3 years I had it.
Gota stick with what I have now if I want to do any wheeling this year.
Old April 17th, 2013, 08:33 PM   #176
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Don't spend the money on rcvs then. I'd just put a new spicer joint in your stock shafts, tack the caps and run those.
Old April 25th, 2013, 10:29 AM   #177
deathbypsi
Brian R.
deathbypsi's Avatar
Update for new parts.
Been on a mad spending spree lately between both trucks but here is the new toys for the truggy.
Got my D&D doubler. Going to replace the stock 4 pinion planetary with a 6 pinion
I also picked up my disc brake brackets,a 9in axle brace,bought a DTS 31spline spool and a 9in pinion guard.
And picked up some Explorer manifolds that will take care of my steering shaft issues. My BBK headers were in the way of the steering shaft so these manifolds will give me all the room I need now.
So as soon as Im done with the turbo swap on the other truck I will be jumpin in with both feet to get the truggy done.
Old April 25th, 2013, 10:36 AM   #178
I want a set of explorer torque monster headers in a bad way.
Doubler looks good.
Old April 25th, 2013, 10:41 AM   #179
deathbypsi
Brian R.
deathbypsi's Avatar
I know these aint the best header for the motor but with the tubes beat up on my BBK's from hammering em flat to try and get steering shaft past them these will be a upgrade for sure.
Old April 26th, 2013, 01:24 AM   #180
deathbypsi
Brian R.
deathbypsi's Avatar
RCV shafts,Warn hubs and RCV outer hub upgrades ordered.
That is all.
Page generated in 0.59196 seconds with 84 queries
