Walker Flexas Ranger - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 4th, 2012, 08:31 PM   #121
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I'd tuck everything up as far as you can too
Old December 4th, 2012, 09:16 PM   #122
deathbypsi
Brian R.
deathbypsi's Avatar
Its a Canton relocation block. Has two 3/4 NPT fittings out the side. Worked perfect in my B2 with the stock 2.9 mounts and 5.0 adapter plates at block but these Duff 5.0 swap mounts must not put motor in same spot.
Old December 15th, 2012, 08:47 PM   #123
deathbypsi
Brian R.
deathbypsi's Avatar
Been workin alot of hours and kinda slowed down lately but I have a 11 day vacation coming up at x-mas and hope to have it rolling by New Years.
Picked up a 4x10 sheet of aluminum for my bed skins,after a rediculous wait from Ballistic I have my upper coilover mounts,spacers,bolts and tracbar mount. Got some new lights and finished my dash. The GPS speedo is sweet!
Going to raise and move motor back a little bit also to make the room I need for oil relocation block clearance and to get a better driveline angle.
No pix today but starting monday progress will be fast...
Old December 15th, 2012, 08:57 PM   #124
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Looking good
H.o.r.e
Old December 16th, 2012, 08:38 PM   #125
Couple yrs ago when I was working on swapping my 5.8L into my b2/ranger truggy, I looked into the duff mounts and back then they were just mustang convertible motor mounts. One side fit in the stock 2.9L hole and the other needed to be redrilled a couple inches away from the oe hole.
What you doing for the doubler shaft?
Old December 16th, 2012, 08:42 PM   #126
What upper coilover mounts did you go with?
Old December 18th, 2012, 11:50 AM   #127
deathbypsi
Brian R.
deathbypsi's Avatar
THe mounts Im using are not like a factory mustang mount at all. I will try and get a pic later.
These are my lower mounts.
http://www.ballisticfabrication.com/...ts_p_1151.html
These are my uppers. I already have the hoops made.
http://www.ballisticfabrication.com/...et_p_1921.html
Old December 18th, 2012, 11:55 AM   #128
Like I said it was a couple yrs ago when I looked at what they were selling, probably found something better between now and then.
I didn't see those mounts when I looked the other day , I ordered something different from them. I might order those up anyways.
Old December 18th, 2012, 11:43 PM   #129
deathbypsi
Brian R.
deathbypsi's Avatar
Got the panels all cut and installed. Camera was suckin balls for some reason but it looks great in person.
Picked up some Pacer flexy flares and put those on the front fenders.
Old December 19th, 2012, 08:42 AM   #130
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
When you firing it up?
Old December 19th, 2012, 02:06 PM   #131
mantooth
this thing looks beautiful. I want to build a ranger someday when im not a broke ass college student. subscribed.
mantooth is offline   Reply With Quote
Old December 19th, 2012, 02:36 PM   #132
deathbypsi
Brian R.
deathbypsi's Avatar
I have a little bit of wiring to finish yet but it should be running after this weekend.
Old December 19th, 2012, 05:56 PM   #133
stinkpickle
bitter clinger
stinkpickle's Avatar
Very sharp and cool Brian, like all your projects.
stinkpickle is offline   Reply With Quote
Old December 22nd, 2012, 09:27 PM   #134
w5778
Slave to my trucks
Pics do this thing no justice, the truck looks amazing in person. hope you get it going before you go back to work. oh i did and online calculator and that tire was 31x9.50 so im either try to get 3 more, hold on to it, or put it back up for sale. ill try to get pics of those tires tom or mon for sure.
w5778 is offline   Reply With Quote
Old December 22nd, 2012, 09:34 PM   #135
deathbypsi
Brian R.
deathbypsi's Avatar
Thanks bro!
Old December 26th, 2012, 06:49 PM   #136
deathbypsi
Brian R.
deathbypsi's Avatar
well now that the holiday BS is over I can get back after this thing...
Got my radius arms and more front end parts{still waiting for inserts}
1.25 Hiems,brackets,bolts,jams. The stock arms were put in a lathe and the small end was turned down to 1.5" all the way up to where they widen.The tubing is 2" .250 wall chromoly and its all tig welded and when finished they were normalized for strength. These were the 2nd try since the first time around the 2" DOM warped when they went in for the heat treating.
Truck now has a smooth belly.Made some 1" spacers for the motor mounts and that worked perfectly so the oil filter relocation block clears the steeringbox and I was able to get the t-case tucked up above the bottom of the frame rail. Made a new crossmember as well.
Bolted up some front recovery hooks.
I started cleaning up the d44 and got the lower coilover mounts finished.
Goin back out in a few to roll axle back under and bolt up arms and start figuring out the frame brackets...
Old December 26th, 2012, 06:51 PM   #137
texs4x4
texs4x4's Avatar
Looks great man!!!!
Sent from my DROID RAZR using Tapatalk 2
texs4x4 is offline   Reply With Quote
Old December 27th, 2012, 12:30 AM   #138
deathbypsi
Brian R.
deathbypsi's Avatar
Question....
Axle is back under the truck,wheels on,arms on using 7 bushings,truck is sitting at ride heigth.
What caster angle should I shoot for at ride heigth?
Tomorrow Im tacking hoops and upper mounts on and with any luck it will sit without stands for the first time. Looks like the coilovers will be leaned backwards 5 and toward motor 10.
That sound good? Any advice or tips before I get started?
Old December 27th, 2012, 06:35 AM   #139
4-5 degrees imo of caster.
Old January 9th, 2013, 12:39 AM   #140
deathbypsi
Brian R.
deathbypsi's Avatar
Well I got the flu over my vacation like I have never had before so basicly nothing got done on truck until this past weekend.
Turns out the lower coilover mounts wont work. The caster angle was to much for the lower misalignment bushings in the coilovers and they would of had to be mounted leaning back almost 15 to stop them from binding. So I built my own lower mount that uses the top two wedge bolts and one of the coil spring pad bolt holes. Coilovers can now sit at 5 rear and 5 in.
Then I made 4 stands to weld to the frame for the hoops to sit on.
After a whole day of mocking the coilovers up getting the right angles I welded up the hoops.
Just need to make the crossover bar and weld up the radius arm mounts at the frame and looks like she ready for coils.
Page generated in 0.42879 seconds with 84 queries
