Walker Flexas Ranger - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 23rd, 2012, 01:30 PM   #81
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Originally Posted by deathbypsi View Post
The jack is in 14" from the outside of the fender. If Im rubbing it on trees I have bigger problems!
I have hit those bars on my cage more than once....you gotta remember as you lean over that 14" transitions from horizontal to vertical putting those bars that much closer to trail obstacles.
As for the harness.....rather than building a cross inside why not cut two holes in the rear of the cab and run two short tubes from the bed cage straight in so you are tied directly to the main cage.....you can use rubber grommets to seal the tubes to the cab. This is how mine are and it works out really well....i can get some pics of what i mean if you want.
Old October 23rd, 2012, 01:44 PM   #82
deathbypsi
Brian R.
deathbypsi's Avatar
I would rather be tied down to the cab instead of the rear cage. If something horrible were to happen like a rollover that seperated the cab from the frame I would hate to get choked out by my harness since its anchored to the rear cage.
Old October 23rd, 2012, 01:49 PM   #83
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Fair enough....with mine being fully exoed that cant really happen.
Old October 23rd, 2012, 01:56 PM   #84
deathbypsi
Brian R.
deathbypsi's Avatar
It will have a full exo before its finished but the way I see it is even with an Exo there is some room between the cab and tubing.If Im strapped in tight and say a rear body mount breaks even a inch or two of movement upward from the cab could make that harness really snug around my chest.
I could be completely wrong in my logic but I at least think in my own head what I plan to do will work ok.
Old October 23rd, 2012, 02:05 PM   #85
texs4x4
texs4x4's Avatar
That damn thing is just crazy Brian. Hell of a nice job!!!!!!
Sent from my DROID RAZR using Tapatalk 2
texs4x4 is offline   Reply With Quote
Old October 23rd, 2012, 04:19 PM   #86
deathbypsi
Brian R.
deathbypsi's Avatar
Thanx Tex......wish it was half as badass as yours is!
Here is the rad mount without the fan on it.
And for fun here is how the sheet metal will look.
Got the chassis harness hooked up today and the lights all work.
Old October 23rd, 2012, 05:33 PM   #87
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Looking great bro
Rule of thumb, attach the harness to what the seat is. That way they can't move independently of each other.
Old October 25th, 2012, 02:33 PM   #88
89yjon
89yjon's Avatar
Looking good brian! Gonna be ready for a shakedown run in 3 weeks? lol
89yjon is offline   Reply With Quote
Old October 25th, 2012, 02:44 PM   #89
deathbypsi
Brian R.
deathbypsi's Avatar
Yeah I dont see that happening...... I wish.
Old October 26th, 2012, 02:27 PM   #90
deathbypsi
Brian R.
deathbypsi's Avatar
Welded in a crossbar for the harness. Plated the floor then added the tubing,feels really solid and should work good with the stock bench.
And I got the cage all painted finally. Scotchbrited the whole thing then wiped it down with thinner.
And mounted up an overflow for the rad.
Old October 28th, 2012, 09:46 AM   #91
Dirthog250r
FORD POWER!!!!!!!!!!!!!!!
Dirthog250r's Avatar
What size tubing did you use on the back of the cage and how sick??
Dirthog250r is offline   Reply With Quote
Old October 28th, 2012, 12:27 PM   #92
stinkpickle
bitter clinger
stinkpickle's Avatar
cage looks awesome Brian. what paint did you end up going with?
stinkpickle is offline   Reply With Quote
Old October 28th, 2012, 11:39 PM   #93
deathbypsi
Brian R.
deathbypsi's Avatar
I used 1.75 HREW .120 wall and painted it with Tractor SUpply gloss black.
Old October 30th, 2012, 03:58 PM   #94
deathbypsi
Brian R.
deathbypsi's Avatar
The harnesses were my best compromise... Thats the highest I could mount the bar and still get the seat to slide all the way back. Im over 6ft tall and 270lbs so I need every click I can get out those seat tracks. For how I wheel I see no reason to worry about how they are mounted since the lap belts will be doin most of holding me in the seat. Major drawback of not having a ex-cab.
Anyway today I finished up the interior for now. Harnesses done,headliner out,auto pedal essembly in,booster in and stock seat belts reinstalled for street driving.Also got chassis wiring done so all lights work,wipers work,overflow/windshield washer bottle works.
And I got the fan mounted up so I can start wiring that.
Old October 30th, 2012, 04:08 PM   #95
caveman
GeoDude
caveman's Avatar
loving this thing
Old October 30th, 2012, 05:51 PM   #96
Ajhawk
Ajhawk's Avatar
wow, this thing looks amazing man! nothing like watching a project come together eh?
Ajhawk is offline   Reply With Quote
Old October 30th, 2012, 07:26 PM   #97
deathbypsi
Brian R.
deathbypsi's Avatar
Thanx guys! Picking up my joints,inserts and brackets this weekend so I can start front end finally
Old October 30th, 2012, 08:15 PM   #98
muddinman56
blood,sweat and beers
muddinman56's Avatar
makes me wanna get a ranger. looks bad ass
Old October 31st, 2012, 12:33 AM   #99
deathbypsi
Brian R.
deathbypsi's Avatar
Since I have the booster in now I need to buy a master cylinder so I can start plumbing. Should I just stick with a stock 83 Ranger master or is something different I should use off another truck since my 9in/d44 has bigger brakes?
Old October 31st, 2012, 12:56 AM   #100
Swampdog02
Wakley Creek Wacos!
Swampdog02's Avatar
Looking real good dude!
Swampdog02 is offline   Reply With Quote
Page generated in 0.39466 seconds with 84 queries
