Walker Flexas Ranger - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 21st, 2012, 06:25 PM   #21
deathbypsi
Brian R.
deathbypsi's Avatar
Got a little more done today. 2" frame for bed is finished,but not welded to chassis yet. Flared it out near rthe cab to make room for a wide thin radiator.Thinkin about using a 90's F150 radiator.Had to many problems washing mud out of the thick 3 core I had in the B2 so Im thinking a wide 1 core will be easy to flush out to keep core clean and still cool plenty good. Will be mounted with bottem kicked back and dual fans blowing down thru it.
Getting a sheet of #9 expanded metal for the floor of the bed.
Toolbox will get mounted here behind the rad.
Finishing the gas tank mount in morn then starting the 2" body lift.
Old August 21st, 2012, 07:00 PM   #22
texs4x4
texs4x4's Avatar
Looks good man!
Sent from my DROID RAZR using Tapatalk 2
texs4x4 is offline   Reply With Quote
Old August 22nd, 2012, 03:25 PM   #23
deathbypsi
Brian R.
deathbypsi's Avatar
Got the rear bumper finished today and it turned out great. Added a crossmember to mount front of gas tank skidplate and welded nuts into bumper for rear of skid.
Just need to add some LED tail lights.
Skidplate all cleaned up and ready to bolt in. Tank and lines goin tomorrow.
Old August 23rd, 2012, 11:55 AM   #24
stinkpickle
bitter clinger
stinkpickle's Avatar
Looking good Brian. Following closely, keep us posted.
stinkpickle is offline   Reply With Quote
Old August 23rd, 2012, 05:38 PM   #25
deathbypsi
Brian R.
deathbypsi's Avatar
Gas tank and skid all finished. Finished welding up the lower bed frame and its now tacked to the chassis. Picked up a nice Foxbody radiator that fits perfect behind the cab.
Tank is tucked up nicely and is higher than it was in the Bronco2 so it should work great. 23 gallons FTW!
Old August 24th, 2012, 12:53 PM   #26
Chrisholmz
ESTRADA
Chrisholmz's Avatar
Send a message via Yahoo to Chrisholmz
That is some pretty serious ground clearance under that tank. And 23 gallons, thats a lot of fuel!
youtube.com/chrisholmz (wheelin vids)
Chrisholmz is offline   Reply With Quote
Old August 24th, 2012, 01:18 PM   #27
deathbypsi
Brian R.
deathbypsi's Avatar
Yeah I know alot of people questioned why I mounted it there and not up on top of the frame but I knew it would tuck up even better than it did in the B2 and I hardly ever hit the skid in the B2. Plus now I still have all the room I need for the radiator,my "trunk" and even a spare tire.
Hoping this truck will be a little better on the road than the B2 was.A full tank in the B2 with the 5.0,c4,3.73's and 35's would go over 350 miles. Now with only 3.50 gears Im hoping I could get better than that.
Old August 24th, 2012, 08:36 PM   #28
deathbypsi
Brian R.
deathbypsi's Avatar
Foxbody rad and a Taurus fan....nice fit.
Wont make mounts until main hoop is made but this is how it should sit.
Old August 28th, 2012, 07:07 PM   #29
deathbypsi
Brian R.
deathbypsi's Avatar
Didnt get as much done this weekend as I wanted but I did get the 35's mounted up,fuel lines ran,picked up all my tubing and expanded metal,Blacked out engine bay, swapped in my non-a/c heater box,got sliders mocked up and removed all the 2wd steering crap.
Old August 30th, 2012, 05:39 PM   #30
Chef mark
Northwest Ohio Crawlers
Chef mark's Avatar
Originally Posted by deathbypsi View Post
That pic is goin to haunt me for life!! lol
I have one also
Chef mark is offline   Reply With Quote
Old August 30th, 2012, 05:45 PM   #31
deathbypsi
Brian R.
deathbypsi's Avatar
great. lol
Old September 4th, 2012, 02:37 PM   #32
89yjon
89yjon's Avatar
Is it done yet? lol
89yjon is offline   Reply With Quote
Old September 4th, 2012, 02:50 PM   #33
deathbypsi
Brian R.
deathbypsi's Avatar
Gettin there! Got the front clip off and cut up the core support and rebuilt it stronger around the body mounts and raised the bottom so i can mount the winch behind the grill.
Added a 2" body lift,got my shock tabs,figured out my front bumper,did some rust repair under the old battery tray and got the rest of the tools I need to build bed and exo.
Will start bending tube on friday and hope to be finished by monday nite.
Old September 4th, 2012, 03:31 PM   #34
texs4x4
texs4x4's Avatar
Wow. Do you sleep?
Old September 4th, 2012, 05:29 PM   #35
deathbypsi
Brian R.
deathbypsi's Avatar
I wanna wheel more than I wanna sleep! I will sleep when its finished.
Old September 6th, 2012, 03:42 PM   #36
All5ofus
All5ofus's Avatar
That will be what you're going to have to keep telling yourself this weekend for sure!
I sure hope to spend some time over there Sunday helping out.
All5ofus is offline   Reply With Quote
Old September 11th, 2012, 05:41 PM   #37
deathbypsi
Brian R.
deathbypsi's Avatar
Ok good weekend. Got a lot done.
I had to cut out bottom of core support for winch clearance then I had to rebuild the area around the body mounts on the passenger side from battery acid damage. The whole corner under the battery tray was gone so I made some patch panels and rebuilt that area also.
I got the 2" bodylift finished and cab bolted back down and mounted up my rocksliders. Started bending tube and got the main hoop in and the fender tops.
Took some time to think the rest through and added my brace for the main hoop then started running tape.Spare tire will get mounted in this location.
I made hoops to go under the rear of the fenders for my tails and have trailer markers for the side of the frame rails.
All the manual brake crap is off and all the 2wd suspension is cut off, all clean frame up front.
Old September 12th, 2012, 07:32 AM   #38
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Looks good! I want to do something like that with my fuel tank bit i want a smaller tank....~15 gallons.
A couple suggestions....on the cage i would x the part directly behind the cab clear to the frame for the most strength....also on the lights......on mine i only run one rear light per side that does stop/turn/tail.....it is nice having only one to package and it's less stuff to break lol
Old September 12th, 2012, 12:31 PM   #39
deathbypsi
Brian R.
deathbypsi's Avatar
Yeah everytime I look at it I think of a better way to add more tubing. The tape was just a quicky idea which I can obviously change easy. Nothing set in stone yet and you are correct I do need to brace the main hoop better than shown.
I have a set of waterproof LED trailer lights that will do park,brake,turn functions. But Im adding the small side markers on the framerails because where the tails will be they wont be visible from the left or right sides and I really dont want to be harassed by law enforcement for anymore obvious illegal things since its goin to thow up a red flag goin down the road anyway.
Old September 13th, 2012, 07:51 AM   #40
89yjon
89yjon's Avatar
Looking good brian! Is pauls bender finally getting put to good use? lol
Page generated in 0.55471 seconds with 84 queries
