Walker Flexas Ranger - Page 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2013, 10:28 AM   #201
kmanxj5011
kmanxj5011's Avatar
I see people mount their reservoirs like that often. Wouldn't the make the fluid in them hot and make the shocks not perform like they should?
kmanxj5011 is offline   Reply With Quote
Old August 14th, 2013, 10:45 AM   #202
deathbypsi
Brian R.
deathbypsi's Avatar
Just like you said..I see them mounted like that on 90% of the trucks I see on coilovers also. Im assuming it must be ok and I really dont have any better option.
Old August 14th, 2013, 02:19 PM   #203
kmanxj5011
kmanxj5011's Avatar
For your application you won't heat up the shocks much anyways, I would see that being more of an issue in somebody running desert type stuff.
Old August 18th, 2013, 11:34 AM   #204
littletrucker
I'd hit that
littletrucker's Avatar
I got a set of these for my reservoirs- mounted mine in basically the same place as you...
http://www.ruffstuffspecialties.com/...ESITD25-4.html
Old November 20th, 2013, 09:48 PM   #205
deathbypsi
Brian R.
deathbypsi's Avatar
Well I actually just got back to workin on this thing everyday again this week. Feels good to be marking stuff off the "to do list".
I been working on finishing the bed so I built a removable bulkhead to protect the fan/rad and make the bed actually useful.
And I made a simple spare tire holder as well. Just need to add one more tube that will be welded to a plate I made that holds the center hub of the rim.
Tomorrow the toolbox will get mounted to the floor of the bed as well and then I can move on to the rear axle
Old November 29th, 2013, 10:58 AM   #206
89yjon
89yjon's Avatar
Bout time! I want to see this thing make it out to wellsville before I die! lol
89yjon is offline   Reply With Quote
Old November 30th, 2013, 09:03 PM   #207
koochman450r
koochman450r's Avatar
I'd like to see this thing wheeling too. Let me know if you wanna test it out. I have a little bit of stuff to mess around on and its prolly closer than Bundy or any other place.
you won this battle.
Old December 1st, 2013, 12:08 AM   #208
deathbypsi
Brian R.
deathbypsi's Avatar
Thanks for the offer. I have plenty of room to test it on my property as well. Plenty of down trees and a nice wide creek that has claimed a few Jeeps over the years. lol
Old December 3rd, 2013, 08:07 PM   #209
deathbypsi
Brian R.
deathbypsi's Avatar
Well I have the rear axle out and tore down for its upgrades.
I started welding the rear brace on the housing and have the third member on the bench so I can start to swap the spool in.
I also put together my whole rear disc conversion and spent just under $200 on everything.
95 Dodge 1500 4wd front rotors
78 Chevy 1500 4wd calipers w/pads and hoses
large Chevy caliper brackets and brake hose brackets from All Star
Picking up all new bearings and seals in morning.
Old December 3rd, 2013, 08:45 PM   #210
You doing a full spool or mini spool? It didn't take me long to strip out a mini spool.
Hope those jack stands are more stable than they look.
Old December 3rd, 2013, 08:54 PM   #211
X2 on mini vs full. I shattered the cross pin onmy 9" with a mini spool in about an hr of wheeling after install. And it was a brand new pin.
Old December 3rd, 2013, 09:18 PM   #212
1TFROT
1TFROT's Avatar
x3 snapped a cross pin n 2 spots in my mini. now only run full spools and not look back (rear axle)
it's lookin pretty good. nice job
1TFROT is offline   Reply With Quote
Old December 3rd, 2013, 09:39 PM   #213
deathbypsi
Brian R.
deathbypsi's Avatar
All the weight is on the stands under the sliders. The ones on blocks are just for a backup,no weight on them.
Yes I have a full spool I bought from DTS right here in Michigan. Did you know they sell like 9 different 31 spline full spools?? I ended up getting the heaviest{strongest} one they made. Think it cost me 101.00
Old December 12th, 2013, 02:49 PM   #214
deathbypsi
Brian R.
deathbypsi's Avatar
Well its back on the ground now.Everything took longer than I thought but turned out great.
Housing brace welded on.
Rebuilt the pig with all new bearings and seals,full spool,reused the factory 3.50 gears and got a perfect pattern.It had .022 backlash before I tore it down and I ended up with .010 after I was done.
Welded brackets on and put disc setup on.
I then installed it under truck,squared it up,bent up all new brake lines and hit it with some fresh paint.
Feels real good to have that huge part checked off my list! Starting on the doubler tonite and maybe pick at some wiring stuff also.
..oh and I picked these up as well.
Old December 12th, 2013, 03:19 PM   #215
Coming along nicely.
Old December 12th, 2013, 03:21 PM   #216
deathbypsi
Brian R.
deathbypsi's Avatar
Thanks for the help a while back on the parts list for the brakes.
Old December 12th, 2013, 03:26 PM   #217
Old December 16th, 2013, 10:56 AM   #218
deathbypsi
Brian R.
deathbypsi's Avatar
Rough weekend but I got another major project almost wrapped up.
Started the doubler build.
I tore open the BW1354e I had to steal the 6 pinion planetary to upgrade the 4 pinion in the doubler but found out pre-93 they are all 4 pinion and my case was a 1990. Oh well.
I tore down the other BW1350 goin in the truck and found the oil pump was messed up. The retainer that holds the pump stationary so it dont spin with the mainshaft got broke some how and that allowed the pump to spin and rip the hose off the pickup.
I really dont see how this would have broke off other than somebody had the case open and didnt install the retainer correctly and it got broke that way. The broke off tab was laying inside the case so I just welded it back together.
So after the BW1350 was all back together I put the doubler together...what a PITA. For some reason the 5 bolts that hold the clocking ring to the main case were the wrong thread right from D&D so I just made it to hardware store to get the correct replacements before they cloesed. Also the 10 allen bolts that go inside to the clocking ring...they can die in a fire{not meant for fat guy hands}. But its all together and I had an extra c4 tail housing so I decided to build all my linkage and shifters on the bench rather than after its installed.
And I replaced the output yoke on the main box to the larger yoke off the BW1354
Should have everything ready to install this evening.
Some things I noticed today that I have never heard addressed before about the D&D doubler...
1. How the hell are you suppose to fill the doubler box? There is no room to even get a allen wrench on the fill plug to remove it.I plan to fill mine through the breather on the bench before I install it.But how much it take?
2.The main case shifter arm hits the doubler and had to be removed to put the two together. You cant reclock the arm to make it work so I just cut it apart and welded it together 90 from where it was.
Old December 16th, 2013, 11:24 AM   #219
koochman450r
I built my doubler using the instructions from the ranger station. In that build it said to drill and tap a hole on top of the doubler. That's what I did I used a 3/8 pipe thread die and plug. Filled it up before I installed it. Because it no longer has the pump it only splash lubricates I filled it about halfway. Also had to put a 90 elbow in back case for breather before assembly.
Old December 21st, 2013, 11:14 AM   #220
89yjon
89yjon's Avatar
Is this gonna be done for a shakedown run to bundy on the 29th brian?
Page generated in 0.35176 seconds with 84 queries
