Daily Driver gear/tire question???? PLEASE - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 13th, 2012, 10:59 PM   #1
Nicholaswb881
Default Daily Driver gear/tire question???? PLEASE
My I6 F-150 got totaled so its time to upgrade. I found two trucks both 96 one with the 5.0 302 and one with the 5.8 351. Im doing a 6" suspension and possibly a 2" body (still on the fence about that). I will be running 35s and this will be a Daily driver mostly pavement pounder.
My question is what motor would be better for a daily driver. From what i have read i'm going to have to re-gear either way. A little foolin around when i go hunting lol
.................Im also tempted to run 37's since i need to buy new tires either way. Not sure
Nicholaswb881 is offline   Reply With Quote
Old August 14th, 2012, 12:44 PM   #2
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
go with 5.8L
4x4xdodgeman is offline   Reply With Quote
Old August 14th, 2012, 12:46 PM   #3
Elvis13
I've not heard good things about 351 mileage. What transmission do the trucks have?
Old August 14th, 2012, 12:51 PM   #4
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Go with the Windsor. Mileage should be negligible.
Old August 14th, 2012, 01:09 PM   #5
ajmorell
The 302 is a turd in the F150s. Go with the 5.8. If you're worried about MPGs maybe you shouldn't be DDing a truck with 6-8" of lift and 35-37" tall tires
Old August 15th, 2012, 11:54 AM   #6
Fraser
Fraser's Avatar
x2
Old August 16th, 2012, 07:03 AM   #7
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Good advice....they are BOTH "Windsor" engines.
Might as well get go with the 5.8L though. You'll get similar mileage with either engine, but at least the larger displacement justifies the consumption with the power output. The 302 is underpowered for 4x4 trucks and loses much efficiency because of it.
Gear for the road and use Low range if needed off road.
Page generated in 0.28428 seconds with 44 queries
