alternative to carrying a hi-lift on a buggy? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2012, 11:47 AM   #21
It's been years since I have needed a jack to change a tire. Any of the above will work for that. However, I bet my hi-lift gets used 3-4 times per year extracting rigs that are hung up in the rocks. Usually it's due to a long travel suspension that is dropped into some form of crevice. NONE of the above will work for that in leiu of a hi-lift.
I'll stick with my hi-lift
Old August 14th, 2012, 01:00 PM   #22
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Lots of good info. here, thanks for sharing. I just carry a jeep jack, but would like to add a battery impact.
RIP FULLSIZE4LIFE
Old August 14th, 2012, 05:37 PM   #23
yyj87
yyj87's Avatar
I only hope that some day my junk is capable of getting that stuck.....
As of now if I drive over a hole that big my tire just hangs over it like a dark cloud.
yyj87 is offline   Reply With Quote
Old August 14th, 2012, 06:50 PM   #24
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
Originally Posted by yyj87 View Post
I keep $100 worth of tools in my heep when I wheel (excluding impact) and Im yet to be presented with a broken part on the trail/camping I can replace.
Sound like you need more tools. You much get stradned a lot.
JK I know what you meant.
Old August 14th, 2012, 08:45 PM   #25
Bones
Bones's Avatar
A $100 winch on the axle/chassis will fix that
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 14th, 2012, 09:14 PM   #26
Without going into a long drawn out description, no it won't.
Old August 14th, 2012, 09:19 PM   #27
Bones
Bones's Avatar
I'm waiting for the description. I know you have the time. Why won't a suck down winch hooked to one side fix it?
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old August 14th, 2012, 09:49 PM   #28
cerial
Direct Drive FTW
cerial's Avatar
While the porta power only has a 5" stroke I believe I can make it 5' long if need be to fit in the same area as a Hi-lift.
The difference is when I only have room for a 12" jack I can easily fit a porta power in that area also. Or areas where you simply can not use the handle to jack up a hi-lift.
But, a Hi-lift jack does kick butt and is super simple. Keep the thing greased every once and a while and your good. I carried one as the rear bumper of my truck held on with 2 studs mounted to the frame/big azz locking lug nuts. The thing ate salt, dirt, and whatever I could toss at it. Put a little grease or blaster to it and watch it work without issue. Between the radio, exhaust, and poly handle retainer I never heard it rattle.
I am sure there is plenty of room on your rig to shove a hi-lift jack somewhere. Hey you need a rear bumper right? Just make a tri-pod that bolts to the top with extendable legs to hold it upright and you wont need to worry about it kicking out on you.
Old August 14th, 2012, 10:07 PM   #29
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I carry a few cutting boards and an extra watts link...there hasn't been a hole I couldn't plug with that stuff
Old August 15th, 2012, 11:53 AM   #30
cerial
Direct Drive FTW
cerial's Avatar
How about your mouth?
Old August 15th, 2012, 05:17 PM   #31
Since you have still not put your rig to the test in the Woodland Rock Course at the Mounds, you would not know the area I am speaking of.
Anway, I had dropped my entire front end between a couple rocks behind the tires and I was sitting flat on my front bumper on a 4 ft or so big round bumper. I could not back up because my rear dif was bound up. Neither front tire would grab the rock in front because it was just inside of their grip. Winching forward only pulled me harder into the rock. Pulling up on the pull down winch was simply not successful. So, I took my hi-lift and put it into my front wheel. I was able to jack it high enough to get rocks under it and also winch forward a little until my tire grabbed.
On 2 occasions this past year, one for me and one for Jiri, we could not get our rear axle up and over a ledge. I do not have a rear pull down, Jiri does. Again it didn't work for him either. In each case, the right rear was hanging in space and in both cases, we were rubbing our rear driveshaft yokes on the rocks. (not good). I was able to put the hi-lift under the rear axle inboard of the brake caliper and inside the wheel well. 8-10" of lift allowed the tire to get up and grip the rock.
We used it at least once on Tab's POS also in the past year.
In each case, the item being jacked was at least 20" from the ground and in the case of the wheel, inboard of anything to get a traditional jack to catch.
Old August 15th, 2012, 09:30 PM   #32
hamsmotorsports
hamsmotorsports's Avatar
hamsmotorsports is offline   Reply With Quote
Old August 15th, 2012, 09:50 PM   #33
Not in my presence.
Old August 15th, 2012, 10:17 PM   #34
Tab
Tab's Avatar
We used that method on mine? I know we used it on Paul's at r&v.
Old August 15th, 2012, 10:39 PM   #35
Christmas Cookie
Not in my presence.
I was there that day!! And I might have taken that photo
Old August 15th, 2012, 10:42 PM   #36
Christmas Cookie
very few items can plug my mouth
Old August 16th, 2012, 08:23 AM   #37
You're right. Your jeep is too awesome to need a hi-lift. or maybe you just always take the pink route
Old August 16th, 2012, 09:24 AM   #38
BUTLER
Monkey Crawler
BUTLER's Avatar
Was this on Winch Hill a few months ago at R&V?
BUTLER is offline   Reply With Quote
Old August 16th, 2012, 10:12 AM   #39
One of them...... yes. I'm a-thinkin you were there.
Old August 16th, 2012, 02:12 PM   #40
BUTLER
Monkey Crawler
BUTLER's Avatar
Yep I was there, I was ridding shot gun with Nitzpixs
Page generated in 0.93215 seconds with 83 queries
