Thread Tools
Old August 13th, 2012, 04:05 PM   #1
knaffie
knaffie's Avatar
alternative to carrying a hi-lift on a buggy?
I don't really want to carry one of these on my buggy. I have no good place to put it, and they're huge, heavy, and another thing to rattle.
I don't really see many buggies carrying them, but I assume they all keep a means to change a tire with them. What is everybody carrying instead? One of my friends just drives up on a tree, rock, or whatever until the flat tire hangs, then he changes it.
knaffie is online now   Reply With Quote
Old August 13th, 2012, 04:12 PM   #2
tcxtreme1000
Mud Slut-Hit Every Hole!!
tcxtreme1000's Avatar
Airbag. If you carry a compressor or a power tank.
Sent from my ADR6400L using Tapatalk 2
tcxtreme1000 is online now   Reply With Quote
Old August 13th, 2012, 04:27 PM   #3
Ebs
Ebs is online now   Reply With Quote
Old August 13th, 2012, 04:29 PM   #4
knaffie
knaffie's Avatar
Originally Posted by Ebs View Post
I might as well just get a hi-lift as one of those.
Old August 13th, 2012, 04:35 PM   #5
silveradoboy
Sam Brown
silveradoboy's Avatar
How about one of these? They work awesome!
http://www.tractorsupply.com/powerbu...-stand-1160455
Originally Posted by drunkencityworker View Post
"BREAK HIS FACE"
silveradoboy is online now   Reply With Quote
Old August 13th, 2012, 04:39 PM   #6
jerm97xj
I fixed it!!!
jerm97xj's Avatar
What about one of those ARB air bags u connect to the exhaust hose?
http://www.arb.com.au/products/arb-r...uipment/jacks/
jerm97xj is offline   Reply With Quote
Old August 13th, 2012, 04:40 PM   #7
knaffie
knaffie's Avatar
Never seen anything like that before.
Old August 13th, 2012, 04:41 PM   #8
silveradoboy
Sam Brown
Its cool. We use them all of the time offroad. Size of a standard jackstand as well!
"BREAK HIS FACE"
Old August 13th, 2012, 04:45 PM   #9
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
That's a sweet idea! although you're completely screwed if you have an exhaust leak AND a flat
Mihlfeldl2005 is offline   Reply With Quote
Old August 13th, 2012, 04:46 PM   #10
knaffie
knaffie's Avatar
Obviously I could be concerned about it popping. I never get flats in the sand, but always in the rocks.
Old August 13th, 2012, 04:56 PM   #11
yyj87
yyj87's Avatar
My tool kit always has my ryobi 1/2" cordless impact, last year I took a factory jeep bottle/screw jack abomination and welded a 3/8"" drive 7/16" socket to the little slot deal the factory jack has on it. The impact with an adapter and the jack make lifting/lowering tires/jeep FAST and simple. A 6"x6"x10" chunk of pine gives me plenty of height. All of the above fits in my 12"x12"x24" tool box.
Best of all its cheep and easy to replace if lost broken (except the impact but a regular 3/8 drive ratchet would work fine.
I keep $100 worth of tools in my heep when I wheel (excluding impact) and Im yet to be presented with a broken part on the trail/camping I can replace.
Yes I'm a cheep bastard that spends as little money on things like this as possible!
yyj87 is offline   Reply With Quote
Old August 13th, 2012, 04:58 PM   #12
knaffie
knaffie's Avatar
Spending
I'm thinking a scissor jack is a pretty good idea too. Small, light, lifts pretty high. Thanks for the great idea. That's a great reason to keep a cordless impact on board.
Old August 13th, 2012, 05:06 PM   #13
yyj87
yyj87's Avatar
The impact makes short work of just about anything, best $100 I have spent on tools in the last 5 years. With the lithium batts It has more balls then my craftsman impact at 110 psi.
The only thing I don't like about the jeep scissor jack is that in a precarious situation there easy to bend. The grand Cherokee jack I have is only 1.5" shorter than a scissor jack at full length and its half the size when compressed.
I don't know how far away you are but I have a few of the bottle jacks lying around if you need one.
Old August 13th, 2012, 07:37 PM   #14
cerial
Insomniac
cerial's Avatar
My dad has a 20 ton porta power which I have borrowed a few times. It is actually a fairly expensive one with many attachments. It fits in more spaces then a hy lift jack while giving tons of lifting capability.
I imagine it could be used in a recovery to get someone out of a rolled rig and into someones truck in a pinch also.
Old August 13th, 2012, 07:48 PM   #15
Tab
Tab's Avatar
I've carried one of these for years now and it's awesome. A high lift has its purpose but for changing a tire it sucks, especially on a rig with lots of travel, so then your stuck chain binding the axle to the frame. Not with the jack/jack stand combo. Plus it has a nice big flat base for sand and snow.
Old August 13th, 2012, 09:19 PM   #16
wadey
┌∩┐(ò_ó)┌∩┐
wadey's Avatar
Yup that's the jack our group uses its great! Its base is stable enough that I feel comfortable to work underneath a rig on the trail with it, unlike a high lift.
Old August 13th, 2012, 09:45 PM   #17
Bones
Bones's Avatar
just run Maxxis tires, you don't even need a spare
I use a high lift to change tires inthe pit, but I can put the high lift right on the axle tube.
I carry a small scissor jack and wooden block for a spacer for long races
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 14th, 2012, 06:31 AM   #18
knaffie
knaffie's Avatar
Thanks for all the ideas everybody.
Old August 14th, 2012, 10:18 AM   #19
Any type of small scissor or bottle jack works well. Make it kinda modular for easier storage. Make a stable base, then you have the jack itself, and then also what I like on a bottle jack is to make a slip-on top to make it safer. A piece of tube that slips on over the top of the ram, with a U shape on it to hook nicely on an axle tube or frame rail or body tube, etc.
Old August 14th, 2012, 10:38 AM   #20
yyj87
yyj87's Avatar
I have a little pce of 4" pipe i think ill make a little cradle tonight! Great idea
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.18654 seconds with 50 queries
