31" Bfg Ats ***SOLD*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2012, 11:42 PM   #1
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Default 31" Bfg Ats ***SOLD***
I have a set of 4 31x10.5x15 Bfg all terrains for sale. The tires are mounted on American Racing rims which are 15x7 with a s10 bolt pattern (5x4.75). However I'am including a set of 5x5.5 to 5x4.75 adapters which are bran new, in the sale. The rims have 5.5 inches of backspacing and once you include the 1.25 adapters you end up with 4.25 inches of backspacing.
The Bfg's are mounted with white walls out and include free replacement certificates from Discount Tire. The certificates are transferable and will be given to the new owner. The only down fall to theses tires is some uneven ware from a bad alignment. This caused the outer edge to ware faster than the inside edge. The tire I have pictured is the worst tire and the rest have better ware patterns.
$350 for everything. As for trades, flat screen tv, nice couches, kitchen table, suspension seats, pretty much anything.
***SOLD***
Keep in mind that this is the worst tire
Replacement Cert.
wadey is offline
Old August 13th, 2012, 10:33 AM   #2
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Bump
Other trades considered would be a name brand 110 welder and air bumps
wadey is offline
Old August 13th, 2012, 08:57 PM   #3
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
As requested, the other 3 tires
wadey is offline
Old August 14th, 2012, 09:30 AM   #4
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Bump
wadey is offline
Old August 14th, 2012, 11:02 AM   #5
Mr.Green
I can levitate!
Mr.Green's Avatar
I am not sure that I am interested in the tires / wheels, but I do have a kitchen table that I a want to get rid of. Its in Fenton. Rectangular, wood top with green legs, 5 chairs that match. Interested? It is decent quality, decent shape (one decent scratch on the top).
Mr.Green is offline
Old August 14th, 2012, 07:48 PM   #6
itselliott
itselliott's Avatar
Not wanting the wheels ect,...............just the tires LMK
itselliott is offline
Old August 20th, 2012, 10:53 AM   #7
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thanks, Ill send you a pm tonight
Not looking to separate right now, sorry
wadey is offline
Old August 20th, 2012, 08:20 PM   #8
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
about how much tread is left on the tires? is it just the two that are worn uneven?
wave_crusher is offline
Old August 20th, 2012, 11:53 PM   #9
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
If you'd like I could get you an actual tread measurement. All four are warn on an angle with less tread on the outside edge compared to the inside. That picture is of the worst one the rest are quite a bit better.
wadey is offline
Old August 21st, 2012, 05:02 PM   #10
wave_crusher
I'll Direc your TV
Darn, thanks but i'll pass, I was hoping only two were worn uneven lol
Old August 21st, 2012, 05:13 PM   #11
MiNi Beast
MiNi Beast's Avatar
hell of a deal as basically you buying new tires at $350 with them certs.
MiNi Beast is offline
Old August 23rd, 2012, 12:42 PM   #12
79CJ5 Renegade
79CJ5 Renegade's Avatar
Bump
79CJ5 Renegade is offline
Old September 1st, 2012, 03:10 PM   #13
reptile610
reptile610's Avatar
Send a message via AIM to reptile610 Send a message via MSN to reptile610 Send a message via Yahoo to reptile610
still up for sale?
reptile610 is offline
Old September 2nd, 2012, 06:02 PM   #14
79CJ5 Renegade
PM sent
Old September 5th, 2012, 03:09 PM   #15
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
All pm's replied, thanks for the interest!
wadey is offline
Old September 5th, 2012, 08:01 PM   #16
rentalrider
rentalrider's Avatar
what are the odds you know if or if not the chevy pattern you posted would also fit a 99 tracker? My son's first car is needing a nice set.
rentalrider is offline
Old September 5th, 2012, 08:20 PM   #17
reptile610
reptile610's Avatar
if you want the rims and not the tires i don't want the rims u can buy them from me ;)
Old September 6th, 2012, 10:15 AM   #18
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
A quick google search says that your tracker uses a 5x5.5 bolt pattern. So if you used the spacer/adapters then yes you could use the rims.
As reptile610 said you might be able to buy the rims from him as a deal is currently pending.
wadey is offline
Old September 6th, 2012, 09:06 PM   #19
reptile610
reptile610's Avatar
Picked them up today. Rims and adapters will most likely be up for sale shortly
Old September 6th, 2012, 10:49 PM   #20
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Sold to reptile!
wadey is offline
Page generated in 0.32007 seconds with 83 queries
