#1 |
stacks stacked on stacks
gas vs LP on rig
does any one know if their is a hp gain or loss when running lp?
i have a 351W I'm thinking about doing the conversion on. i don't know any one who has ever ran lp so any info would help. and also if you know. how long average will a tank of lp go? HiLo size tank.
#4 |
Keep on truckin
if your going to build a dedicated LP rig i would look into running higher compression pistons as propane has a relative octane of 110. this would increase the efficiency by a decent amount.
"I don't have pet peeves, i have major psychotic fucking hatreds" -George Carlin |
#6 |
Well this is all good input. I also think I will be building a sbf to run on just Lp. Unless a decent deal comes up on a mild built one.
#7 |
Are we talking like 10-1 or higher still?
What would be best compression for Lp only? |
#8 |
1ton XJ
10 -1 is fine, any higher and you would need a second mixer, for most part, a E-425 mixer will do. I run a E-425 on my 472 caddy BB on my heep and could add a second but for what I do, it gets the job done. prob could run upside down, if you can keep the oil pressure up.
oh- any bigger HP motor, you would need a second Mixer and evap. because it needs more air-flow Last edited by XJcoupe; August 11th, 2012 at 06:12 PM. |
#9 |
1ton XJ
so good readings on LP here
http://fuelsforum.rasoenterprises.co...f1c133cd7859b0 |
#10 |
Not building it big hp. Maby a pair of OTC heads down the road.
#12 | |
I'm starting a buggy build. Gathering parts and info before I'm over my head in it. I've noticed a lot of guys running LP and I figured it was mainly because of off camber situations, and also because of lack of funds to run a nice efi. So it sounds like this fits my needs good!! |
#13 |
Lp burns cleaner, and doesn't build up carbon like gas does, your engine, and oil will stay cleaner longer, I plan on running my 304 on Lp, and my brother is running his 401 on it also, I've heard you get good run times out of a hi-Lo tank, obviously depends on how you wheel, but I've heard guys can.go all.day on a tank if not more, and being its higher octane its cheaper than gas
#14 |
At around 40$ to fill Hilo tank that's cheep compared to 110 for a days worth!
#16 |
I have room for 2 tanks in the rear if my rig.
Is their one kit that is better than another? I've been looking at the kit that jasper sells. http://www.jasperengines.com/rock-crawler.php |
#17 |
1ton XJ
most impco kits are the same, just gotta shop around, or search for used at a cheeper price
http://www.gotpropane.com/p1.html http://www.nashfuel.com/ |
#18 |
Master Cocksman
Unless you have the old style valve on the 20lb tank, that propane places are prohibited from filling, this is not possible.
#19 |
Ridge Runners Offroad
There is a special fitting and adapter for using a grill tank in emergencies. I am 150% satisfied with my propane set up. I didn't notice any power loss. Plus being able to attempt some sketchy lines with out it sputtering is great!
"You don't know anyone, who knows anyone, who knows anyone, who knows anyone that can kick my ass." - Josh Barnett |
| Thread Tools | |
