Recommendation on a Gas detector (Sniffer) for the DIY homeowner - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 9th, 2012, 10:55 PM   #1
Denton
Brush Yo Teeth!
Denton's Avatar
Default Recommendation on a Gas detector (Sniffer) for the DIY homeowner
I am ready to purchase a gas detector. I had a couple very slow leaks in my gas lines that took me quite a while to diagnose with the ole bubble/soap trick. It may just be my mind playing tricks, but I sometimes think I still smell gas, but nobody else does. I would like to ask you HVAC guys and anyone else that uses a gas detector what you would recommend? Just something that is accurate and constructed with quality. Not looking to spend a fortune, maybe $100 to $200 if possible. Thanks
Denton is offline   Reply With Quote
Old August 10th, 2012, 04:50 AM   #2
Tizken
If its that small of a leak I just use a lighter. It will just make a small flame.
Tizken is offline   Reply With Quote
Old August 10th, 2012, 06:58 AM   #3
Immortal
NO RELIGION WAT!
Immortal's Avatar
X2
I do this.
However if it is not a small leak we will deny we ever gave you advice.
Seriously though I find the lighter method best for finding small leaks. Make sure to put out the flame once it ignites.
Old August 10th, 2012, 07:05 AM   #4
Immortal
NO RELIGION WAT!
Immortal's Avatar
Btw don't use teflon tape. Use pipe dope. Don't get the dope in the tubing. Only use pipe dope on threads of the pipe. NOT on brass compression or flare fittings!!!
Old August 10th, 2012, 07:09 AM   #5
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I've heard people say not to use tape. I have no idea why. It works just fine. I use a lazy flame on my torch to check for leaks.
Old August 10th, 2012, 07:39 AM   #6
homerdogeo8
booger eatin' moron
homerdogeo8's Avatar
I use this kind:
homerdogeo8 is offline   Reply With Quote
Old August 10th, 2012, 07:43 AM   #7
Immortal
NO RELIGION WAT!
Immortal's Avatar
Just what I was taught at a bbq and fireplace shop I worked at when I was 16yo
Old August 10th, 2012, 08:11 AM   #8
BlooMule
Old School
BlooMule's Avatar
No fart jokes yet?
Disappointed, I am.
-rw-rw-rw
Old August 10th, 2012, 08:48 AM   #9
Rob the plumber
The yellow tape is thicker and required by code in some states. Michigan is not one of them. Regular tape works fine. I just use pipe dope. Household gas lines have less than a half psi, and don't take much to seal. Back when fittings were made in the USA, plumbers didn't use any sealant, only a few drops of oil.
Inspectors here want to see a 5psi air test hold for 15 minutes.
Old August 10th, 2012, 08:49 AM   #10
Rob the plumber
Originally Posted by BlooMule View Post
No fart jokes yet?
Disappointed, I am.
Ever light a fart? That is some funny shit.
Page generated in 0.30955 seconds with 52 queries
