Thread Tools
Old August 9th, 2012, 09:54 AM   #1
Ford forever
Bought another jeep
Ford forever's Avatar
Easy upgrades to get more HP outta your 4.0
Looking for some easy upgrades to get a few extra ponies from my girls jeep. Got a nice cold air, did a full tune up(dist,plugs,wires,all fluids) looking at bigger injectors kinda wondering what cc would work? besides stock. Ordered a bigger header from flowmaster an 3" all the way back, no cat. Not lookin to do any major motor work it's her dd,for now lol I'm open to Any suggestions.
Ford forever is offline   Reply With Quote
Old August 9th, 2012, 09:56 AM   #2
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
Best HP per dollar is usually spraying it.
JohnL is offline   Reply With Quote
Old August 9th, 2012, 10:01 AM   #3
92FleXj
stacks stacked on stacks
92FleXj's Avatar
Lol
92FleXj is online now   Reply With Quote
Old August 9th, 2012, 10:34 AM   #4
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
I would not go bigger than 2.5 and keep a cat. get a high flow. with that setup you're gonna lose torque.
SlayerXJ is offline   Reply With Quote
Old August 9th, 2012, 10:39 AM   #5
ajmorell
ajmorell's Avatar
3" is too big on the 4.0 unless you're making really high hp. 2.5" is ideal. 99+ intake manifold will net some gains. Where the 4.0 really struggles is with air flow, so some head work will make a nice difference.
ajmorell is online now   Reply With Quote
Old August 9th, 2012, 12:19 PM   #6
Ford forever
Bought another jeep
Thank for the advice on the exhaust, I thought it was a little big myself, glad we only ordered the header. As far as head work I figured when we decide to pull it apart were defiantly going 4.6 stroker. It's not that expensive an like I said it's her dd a v8 is unpractical for her lol
What about a throttle body or spacer? worth the trouble or na ?
Old August 9th, 2012, 01:57 PM   #7
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
I noticed a slight difference, most people talk shit about them, but most have never bolted one on either.
Just don't get the one that whistles!
Old August 9th, 2012, 05:26 PM   #8
ajmorell
ajmorell's Avatar
Snake Oil. If you understand how it's supposed to work you'll understand why. I ran one for a little while before retiring it to a paper weight. Your best bet for gains are:
-99+ Intake
-Header of some sort + 2.5" mandrel bent exhaust (do what you want with the cat/muffler, I run a high flow cat and no muffler)
-Cam (compounding this with the above mods)
Old August 9th, 2012, 06:46 PM   #9
92FleXj
92FleXj's Avatar
I have the whistler.... Gets annoying real quick...
Old August 11th, 2012, 08:22 AM   #10
SlayerXJ
To Live is To Die
SlayerXJ's Avatar
I bought mine used from Hancho for like 30 shipped, so it wasn't a huge investment.
But holy shit, if i knew it whistled, i would have passed.
Every passenger is all WTF is that whistle?
I swear when i first installed it the throttle response felt snappier.
Old August 11th, 2012, 09:08 AM   #11
Why YJ?
Don't be a wuss... HIT IT
Why YJ?'s Avatar
Read up:
http://www.jpmagazine.com/techarticl...ing_true_lies/
Run of the mill YJ with Dana 60's and Irok's..SOLD
97 XJ Family Trail Rig
Paul
www.teamhodges.com
Why YJ? is offline   Reply With Quote
Old August 14th, 2012, 10:19 AM   #12
Ford forever
Bought another jeep
Its a 99 Cherokee so it already has the 99+ intake. I Might have a little head work done idk well decide over the next few months.
Old August 14th, 2012, 10:30 AM   #13
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Head work and a better cam can pick up good power on a 4.0l.
Porting your throttle body helps a little and its free. You can also modify your crankshaft position sensor to gain a little timing too.
Old August 14th, 2012, 10:32 AM   #14
Ford forever
Bought another jeep
Originally Posted by Why YJ? View Post
Read the whole article an all I got was to get any good power gain from bolt on products you first need head, an valve work. Exactly what I figured. Unless the head will allow more flow the ad ons are just a waste of time unless you want better mildly better gas mileage.
Old August 14th, 2012, 10:40 AM   #15
Ford forever
Bought another jeep
Rob- prolly what well end up doing. My new question is how much head work, an what cam will give me that little extra hp I'm looking for? I have been looking an have a few narrowed Down but I'm still taking opinions on what I should end up running.
Old August 14th, 2012, 11:17 AM   #16
Rob the plumber
port match, and cleaning the bowls up is all I'd do. You could have the head machined for larger valves but you will still pick up good power with the basics. I'd also stay mild on the cam. Les chance of wiping a lobe out and better driveability. Replace the springs too while the head is apart. I've also read that the 91-95 head flows the best, so maybe look into that.
Old August 14th, 2012, 12:52 PM   #17
ajmorell
ajmorell's Avatar
When I had my 4.0 rebuilt I had a 3 angle job done on the valves and the head port matched. Gasket/port match the exhaust manifold and intake as well. The intake is easy since it's aluminum, on the exhaust/header I just smoothed up the runners since all I had at my disposal the time was a dremel. As for cams, I'm running Comp Cams 68-232-4 and I'm happy with it.
Old August 14th, 2012, 02:03 PM   #18
Mr.Green again
I can levitate!
Mr.Green again's Avatar
Or you can just bust the distributor clocking location bracket and rotate the distributor. I found this out on accident.
Mr.Green again is online now   Reply With Quote
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.16409 seconds with 46 queries
