Is a 3.3" to 3.25" bushing possible? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2012, 10:36 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default Is a 3.3" to 3.25" bushing possible?
Or is that to small to be doable. I had a race spin bad, and the hub isn't available anymore, I'm hoping to find a bigger race with my same bearing to do the fix, but just curious what my options are if I can't find something to work.
booblinker is online now   Reply With Quote
Old August 6th, 2012, 07:23 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
Could you have a new race made with larger OD?
What is it for?
Old August 6th, 2012, 07:37 AM   #3
.025 wall is pretty thin. If you can find someone to make it, you could freeze fit it in. Also check out speedie sleeves from Invetech. The only ones I have ever used are for shafts and not bores but it would be worth a look.
You won't be able to find anyone who will make a single piece tapered bearing outer race.
Do you have the actual part number you need?
Old August 6th, 2012, 07:55 PM   #4
booblinker
Sore and Tired 24/7
booblinker's Avatar
I found a bigger race, with a bearing the same ID. One of my customers is gonna machine the hub to fit the new race. Between bearing, races, and machining ill have under $100 into it. Much easier than tracking down a hub that I will pay more for than the machining.
Page generated in 0.21801 seconds with 35 queries
