FOUND FOUND ZJ dana 44 parts or complete 35 w/3.73 gears - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2012, 01:30 PM   #1
turtleturtle
turtleturtle's Avatar
Default FOUND FOUND ZJ dana 44 parts or complete 35 w/3.73 gears
have a 98 ZJ with the rear Dana 44 limited slip 3.73, the limited slip came apart gears are good.... so I need ether a new diff (44)or a complete axle dana 35w/ 3.73 gears,am going with a 8.8 later just dont have the time or money right now. thanks Jeff in southern lower MI
turtleturtle is offline
Old August 5th, 2012, 11:04 PM   #2
Wramblerguy
Wramblerguy's Avatar
you need dana 44a parts
if i remeber corectly the internals are not standard dana 44
and i know where there are 2 dana 44a and one might have a posi but i dont think he wants to part them out
Wramblerguy is offline
Old August 5th, 2012, 11:13 PM   #3
turtleturtle
You are correct, it is not normal dana 44 stuff. I have a regular open diff and it is not a wide as this one and diff bearings, so I think it would have to be out of a ZJ with the c clips and all. thanks for the info. (so thats what they call it a 44A??)
Old August 6th, 2012, 07:57 AM   #4
Wramblerguy
The 44a also came in a couple other vehicles like late model isuzus and some other things if that helps
And ya it's called the 44a because the center section is aluminum
Old August 7th, 2012, 12:24 AM   #5
gearedfather
i have a trac-lock for that (oddball) pm sent. 612-309-3999
gearedfather is offline
Old August 7th, 2012, 07:23 AM   #6
mhicks1017
mhicks1017's Avatar
I have a d35 with 3.73's out of a 94 ZJ. Pm me if you are interested, we can work out a price.
mhicks1017 is offline
Old August 10th, 2012, 08:57 PM   #7
turtleturtle
Bump FOUND thank you gearedfather, this fella knows his stuff,and sounds like he has a ton of axle parts . A honest seller!!!
Page generated in 0.25883 seconds with 44 queries
