overheating question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 3rd, 2012, 08:52 PM   #1
Silver Bullet
Livin the American Dream
Silver Bullet's Avatar
Default overheating question
Vehicle
04 durango 4.7
Started overheating yesterday. I go check it on the side of the road. Fluid in reservoir is a gallon low. I fill it and it still runs hot. I then thought to squeeze the hoses while its hot and they are rock hard. This would indicate a bad thermostat correct? I replaced the stat about 5-6 years ago or 100,000 miles.
Bell tire was the only thing open and she has a line of credit there. I told them to change the t stat. She goes to pick it up and they said they didnt change anything because they couldn't get it to overheat. If it happens again bring it again.
I told them if it overheats and she is stranded again they will pay the tow bill and discount the repairs. I told them to change the tstat.
Silver Bullet is offline   Reply With Quote
Old August 3rd, 2012, 08:54 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
mechanical or electric fans on that? if electric do they come on?
Old August 3rd, 2012, 08:54 PM   #3
Did you pull the little bleeder plug to vent any possible air pockets when filling it back up?
Old August 3rd, 2012, 09:11 PM   #4
Silver Bullet
Mechanical fan.
Did not know of blender screw. The tstat is at the bottom of the motor. Don't these pull from the bottom and dump back in up high. If so there shouldn't be air in the system...........I think..lol.
Old August 3rd, 2012, 09:53 PM   #5
MilwaukeeF350
Dan
How coolant look like in radiator?
How many miles it had now?
Is radiator and AC/tran cooler clean of debris?
Does it had fan clutch on water pump? Can you feel it pulling air harder when hot?
If it still overheat you able have bad head. Had 94 Explorer that did like you describe it turn out bad head.
Old August 4th, 2012, 02:19 PM   #6
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
when you said that the hoses hard as rock, maybe the rad. cap is bad. not letting persure out.
4x4xdodgeman is offline   Reply With Quote
Old August 4th, 2012, 02:46 PM   #7
Ebs
Overheating the 4.7L is bad news.
Old August 4th, 2012, 08:41 PM   #8
hamsmotorsports
hamsmotorsports's Avatar
Sounds like the head gaskets may be bad. Loosing coolant, upper? hose is hard= combustion gas in the cooling system. pretty common problem.
hamsmotorsports is offline   Reply With Quote
Old August 4th, 2012, 11:56 PM   #9
cerial
Direct Drive FTW
cerial's Avatar
This^^
First thing I thought of when you said you were a gallon low. All that fluid needs to go somewhere. If it is not coming out a hose, cap, or broken tube good chance it is going into the engine.
Pull your oil fill cap off that much coolant should give your oil a nice milky glaze of oh fuk my head gasket is shot.
Page generated in 0.31092 seconds with 50 queries
