Thread Tools
Old August 3rd, 2012, 05:44 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
*FIXED* Slight steering wheel shake/shimmy/death wobble.
Over tight wheel bearing in combination with loose steering gear sector shaft caused this.
Driving down the road I can let go of the wheel and it will jerk back and forth. Not to the point where its going to cause me to get into an accident. I can stick my head out and watch the front tire and it looks like i'm turning the wheel very quickly left/right.
I thought it was the gear box so I put in the durango box. Its much better then my old so I'm sure that had some play .
All the heim joints on the steering are good.
Could this be caused by ball joints? I have not replaced them in 5 years since I put the front axle together. It has various off roading trips. How often do you replace?
Just seems odd I had no issues until coming back from Silver Lake.
The tires are IROK 39.5 but before SL i had zero issues.
the frame is not broke as I already redid that where the box connects.
My pitman arm will move UP a little before the tires turn.
Old August 3rd, 2012, 06:23 PM   #2
winters98tj
winters98tj's Avatar
oops!
winters98tj is offline   Reply With Quote
Old August 3rd, 2012, 06:31 PM   #3
Jeeperz Creeperz
Jeeperz Creeperz's Avatar
As in the arm and sector shaft together, or just the arm? The pitman arm should NEVER move separately from the sector shaft.
Old August 3rd, 2012, 06:36 PM   #4
Jeeperz Creeperz
Originally Posted by winters98tj View Post
He lost me when he called the tie rod a drag link and then improperly called his "T" style steering a Y" style.
That's some good info there!
Old August 3rd, 2012, 07:15 PM   #5
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
It moves as one sector and pitman. I thought there should be ZERO play though? You can hear it clunk a bit. Second rebuilt box... first one was horrid!
Old August 3rd, 2012, 07:55 PM   #6
treky67
millwright/jeepwright
treky67's Avatar
Seems like a tire balance issue. Did you by any chance loose a wheel weight, or some thing along those lines. Tires that big can be hard to balance because of how much rubber they loose, and how fast they loose it. Even a balanced tire can become unbalanced in a hurry with on road driving.
treky67 is offline   Reply With Quote
Old August 3rd, 2012, 08:06 PM   #7
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
They have never been balanced. They are mounted on 15" waggy wheels with DIY bead locks. I guess its possible the tire shifted on the rims after having them aired down to 3psi?
I should break them down and put some airsoft BBs in there to see if that helps.
Old August 4th, 2012, 01:00 PM   #8
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
ball joints good. Next up is to put 12oz of airsoft .12 gram BBs in the tires. I'll report back
Old August 4th, 2012, 01:21 PM   #9
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Have you tried putting a set of balanced street tires on and drive down the road? It is an easy way to eliminate that as the problem.
I hate being bipolar, its great!
basic tj turned buggy build
http://www.greatlakes4x4.com/showthread.php?t=175584
chadcooper55 is online now   Reply With Quote
Old August 4th, 2012, 01:29 PM   #10
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
No I don't have any laying around but that is a great idea. I don't have anyone near that shares the same pattern as me either. I'll just put the BBs in... should have them in there anyhow.
Old August 4th, 2012, 01:36 PM   #11
chadcooper55
i bet if you put a thread up somebody close to you would help you out. even if it is just stock tires and rims off a tow rig or something. i dont know what bp you have but if you were closer i would help you out. i got a little bit of everything
Old August 4th, 2012, 06:05 PM   #12
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Thank you Chad. I think I have it nailed down finally.
I added 13 oz of BBs. Took it for a spin and its MUCH MUCH better. Almost gone completely. At slower speeds you can feel it....around 30-35 maybe? No speedo.
However, I noticed I have my wheel bearings to tight so when you spin the rotor, you get that notchy feeling...it spins, stops, spins, stops. So I would suspect that is the cause.
I left the tool in the trailer box which is in waterford. Not about to drive 40 mins for it so it will wait till Monday when I make it out that way.
Even if the bearings are not causing this, I could live with this.
Old August 7th, 2012, 11:47 AM   #13
Jeeperz Creeperz
Do you drive this every day, every few days, or let it sit for long periods of time?
Sometimes, if you let them sit too long, the bearing rollers will start to rust to the race and then when you turn the wheel it peels small amounts of the race off. If this is the case, you'll have to replace your wheel bearings and races.
Old August 8th, 2012, 08:45 AM   #14
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Interesting Jeeperz. It does sit a good bit. I try and drive it once a week just to keep everything lubed up in the engine and battery charged up.
I did manage to figure out the issue though. The pass. side wheel bearing was on WAY to tight. Backed it off and re-torqued it to spec. Problem is gone. I think this issue was a combination of the steering gear box, and the wheel bearing.
Thanks for the help and suggestions guys.
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.15584 seconds with 38 queries
