"Black Foot" CJ-7 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 4th, 2012, 09:06 PM   #21
82cj7ltd
Saved by Grace
also, do you find your gearing to be high enough with the tire size you have, or do you think you could use higher/lower gearing? My gearing is still stock but i'm planning on changin eventually. probably wont run more than 33's on mine though so I think 4:88 will be too high for me. any ideas or advice?
82cj7ltd is offline   Reply With Quote
Old August 6th, 2012, 06:39 AM   #22
0llllll0
JeepJohnson
0llllll0's Avatar
The gearing is low,( numerically higher) it might go 50 mph tops on the expressway... I plan on running the 36's for a while but I will most likely be running taller tires in the future. If you are going to run 33's and you want to drive it on the freeway, I would say 3:73 or 4:11 would be a the way to go.
Jeepjohnson
"Black Foot" my CJ-7 build
Do you have a YJ ? Is the rear Frame rusted ? Check this out YJ Rear Frame Reinforcement Plates
0llllll0 is offline   Reply With Quote
Old August 15th, 2012, 09:14 PM   #23
pigfat
GONE COMMANDO
pigfat's Avatar
Nice Job, thats alot of work you did there, looks great.
pigfat is offline   Reply With Quote
Old August 21st, 2012, 11:55 AM   #24
0llllll0
JeepJohnson
0llllll0's Avatar
Thanks !
It worked out well on Drummond this past weekend, with the exception of it not running that good at a slow crawl. I played with the timing and idle air mixture and it helped some, but it was still not happy running slow on the trails. As soon as it comes off idle it is fine. On the pavement it idles and runs great. I'm going to check the float and ??? Anyone with MC 2100 experince please feel free to chime in as I think its a carb issue.
Jeepjohnson
Old October 4th, 2012, 11:40 AM   #25
0llllll0
JeepJohnson
0llllll0's Avatar
I pulled the jets and found that it had #50 jets, I read that 47's were a good match for the 258 so I ordered up some from Allstate Carburetor in NY, they have every jet for a 2100 in stock. This thing runs incredible now! and will idle down the trail without issue...
I'm ready for Snofari !!!!
Jeepjohnson
Old November 6th, 2012, 11:10 AM   #26
0llllll0
JeepJohnson
0llllll0's Avatar
Well, I was ready for Snofari, but Snofari wasn't ready for me, didn't make the cut....
Jeepjohnson
Old December 14th, 2012, 06:49 PM   #27
gigbag
Rust never sleeps !
gigbag's Avatar
Saweeet !
gigbag is offline   Reply With Quote
Old December 14th, 2012, 09:04 PM   #28
deathbypsi
Brian R.
deathbypsi's Avatar
Wow an amazing build!
Old December 15th, 2012, 04:12 AM   #29
bdavid
bdavid's Avatar
good job
bdavid is offline   Reply With Quote
Old December 15th, 2012, 09:21 AM   #30
threeEs99
threeEs99's Avatar
Wow what a differance, looks great
threeEs99 is offline   Reply With Quote
Old December 15th, 2012, 09:30 AM   #31
DuffMan
Your Message Here
DuffMan's Avatar
I've seen it in person, and it's every bit as great as it looks.
What did you basecoat the axles with? When I did my D44 I used Eastwood Rust Encapsulator (like POR 15, but fewer isocyantes to kill you) and topcoated with Rustoleum Hammered.
Old December 16th, 2012, 06:38 PM   #32
Kaiser42
Kaiser42's Avatar
Love it!! Nice looking rig
Unimogs,LS-1,42's and a few other mod's
Kaiser42 is offline   Reply With Quote
Old December 17th, 2012, 02:49 PM   #33
0llllll0
JeepJohnson
0llllll0's Avatar
Thumbs up
Thanks Duffman and everyone!
For the axles, I just used Rust-oleum Rusty metal primer for the basecoat and then top coated with high gloss Rust-oleum. Both were applied thick with a brush. This way when they get messed up I can re-coat them easily.
Jeepjohnson
Page generated in 0.31826 seconds with 62 queries
