Winch Issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 2nd, 2012, 07:04 AM   #1
ajmorell
Default Winch Issues
I finally got around to installing my winch (Engo E9000s) but I'm having some issues getting things to work right. Hoping someone may have some advice before I contact Engo.
I hooked up everything per the instructions provided. With the Jeep running at idle if I press in on the controller it kills my Jeep. Revving it to 3k barely keeps it running and the winch barely spools rope in. Initially I thought maybe my battery couldn't support the load, but after it dies it fires right back up like nothing happened. The other oddity is that the positive cable running from the winch to the battery gets really hot. Like hot enough to melt the insulation. I'm out of ideas and a bit frustrated. Anyone think of anything obvious I'm overlooking? Alternator is a brand new 130A unit also.
Old August 2nd, 2012, 07:46 AM   #2
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
Check your grounds.
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old August 2nd, 2012, 08:32 AM   #3
ajmorell
Battery cables are new within the last 6 months, plus I went through some issues chasing grounds for an unrelated issue so I know they are all good. Any reason to ground the winch straight to the chassis or block rather than battery?
Old August 2nd, 2012, 08:35 AM   #4
03hemisilver
Google it, "winch cables getting hot" I was looking around and looks like ground to chassis is recommended.
Old August 2nd, 2012, 08:38 AM   #5
ajmorell
Thanks
Old August 2nd, 2012, 08:41 AM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
How are you attaching the winch cable to the battery?
Old August 2nd, 2012, 08:44 AM   #7
curbdog17
Mini Van
curbdog17's Avatar
pics of your wiring
Old August 2nd, 2012, 08:45 AM   #8
ajmorell
Not sure what you mean. Red to postive, black to negative. When I redid my wiring I used mil-spec terminals (like these: http://www.sierraexpeditions.com/ind..._detail&p=1010), the lugs from the winch cables are attached via the clamp screw on the terminals.
Old August 2nd, 2012, 08:45 AM   #9
ajmorell
Pics will have to wait until tonight.
Old August 2nd, 2012, 08:46 AM   #10
bdd1469
bdd
bdd1469's Avatar
A bad ground will cause a hot cable,not cause your engine to die.A cheap china made winch with a dead short inside would cause all kinds of problems.Or if cheap china made winch was trying to power in both directions at once,it would cause problems.
Old August 2nd, 2012, 08:56 AM   #11
Offroadian
seasoned
It's always best to have both positive and negative cables going directly to the battery.
If you ground to the chasis, it has to ground through the frame, and any ground cables to find it's way back to the battery to complete the circuit. Finding resistance all along the way.
What you most likely have going on, is a miss wired solenoid (it is a China made nock-off). Check your wiring diagram that came with the winch. Or better yet, google a Warn diagram. The colors may be different, but all the wires need to go to the same locations.
Is also possible to have a short in your remote ( it's trying to go in and out at the same time). Do a continuity check on the remote.
Offroadian is offline   Reply With Quote
Old August 2nd, 2012, 10:55 AM   #12
ajmorell
The vendor I bought it from suggested I call Engo. I'll try to keep this updated.
Old August 2nd, 2012, 11:15 AM   #13
GREASYHANDS
GREASYHANDS's Avatar
Try hitting it with a hammer
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 2nd, 2012, 11:20 AM   #14
92FleXj
stacks stacked on stacks
92FleXj's Avatar
mine use to kill my jeep as well, i put a red top in it and it has worked great ever sense.
Old August 2nd, 2012, 11:26 AM   #15
fsumotorhead
N8KVB
I meant the mechanical connection.
On mine I have a marine dual purpose battery. The battery cables go to the lugs on the battery while the winch cables connect to the 3/8" threaded lugs.
Old August 2nd, 2012, 11:45 AM   #16
ajmorell
The vendor?
Old August 2nd, 2012, 11:54 AM   #17
92FleXj
92FleXj's Avatar
i also did the same when i switched to to the red top. truck runs off the top posts and winch runs off the side (GM STYLE) posts
Old August 2nd, 2012, 12:09 PM   #18
ajmorell
I read somewhere that you should always go to the post, that a lot of times the threaded lugs are not rated for as high of amperage draw. Either way, they're connected at the posts.
Old August 2nd, 2012, 12:37 PM   #19
ajmorell
Well I'm a fucking idiot (no surprise there). I talked to Joel @ Engo, turns out I've got the negative/ground from the battery on the wrong post on the winch.
Old August 2nd, 2012, 01:03 PM   #20
92FleXj
92FleXj's Avatar
Yes you are
Page generated in 0.34944 seconds with 83 queries
