Identify this bearing and seal! Solved! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 1st, 2012, 10:18 PM   #1
03tjsport
Red Dragons!
03tjsport's Avatar
Default Identify this bearing and seal! Solved!
Pulled this from my axle. It is a D60 semi-float. Part of the BOM is ground off. Thinking it may be from a 67 International,but all the bearings I found were not tapered. There are no numbers on the seal and the ones on the bearing are not readable. Thanks!
03tjsport is offline   Reply With Quote
Old August 2nd, 2012, 07:22 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Pull the other shaft and get the bearing number?
Old August 2nd, 2012, 07:35 AM   #3
03tjsport
Red Dragons!
03tjsport's Avatar
Probably going to try that today.
Old August 2nd, 2012, 09:45 PM   #4
03tjsport
Red Dragons!
03tjsport's Avatar
Found out that the ends have been replaced with Ford 9 inch flanges. Uses a set 20 bearing. Yay fixed!
Page generated in 0.46500 seconds with 35 queries
