02 sport trac starter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 1st, 2012, 02:06 PM   #1
Bigcore1990
Default 02 sport trac starter
Currently working on R&Ring the starter in a 2002 Ford Explorer Sport Trac, Manual 5 spd., 4.0L, 4x4
Seems to be not enough room to remove the starter through the bottom or the top. Just curious if removing the front driveshaft would give you enough room to pull it out. Im seriously hoping the whole front axle assy. doesn't get dropped.
Anyone done this or replaced on a similar vehicle? If so id appreciate some advice, thanks.
Bigcore1990 is offline   Reply With Quote
Old August 1st, 2012, 02:54 PM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
Been awhile since i've done one, but they will come out. I can't remeber if I pulled the drive shaft or not, but it definatly came out the bottom.
Old August 1st, 2012, 04:30 PM   #3
Bigcore1990
Cant seem to wiggle it out, I read somewhere that the ford service manual says to remove the front shock. I don't see how this helps at all. Doesn't see, to be enough room between the frame and pinion flange.
Old August 2nd, 2012, 08:39 AM   #4
fsumotorhead
N8KVB
If worst comes to worst, you could always lower the center axle section.
I woul leave everything "hooked up" and just remove the three large bolts that hold it in place, should net you a few inches of clearance.
Old August 21st, 2012, 10:43 AM   #5
V3n0mus
anyluck??? should be able to just drop the front shaft and should make its way out. Ford wouldnt make you drop a axle to change a starter.
V3n0mus is offline   Reply With Quote
Page generated in 0.22879 seconds with 38 queries
