cummins injector swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 31st, 2012, 09:59 PM   #1
davidkassie
davidkassie's Avatar
Default cummins injector swap
Any tricks? Swapping injectors on an 01 24v this weekend.. changing tubes too. Any special tools? Etc.. ty for any help
davidkassie is offline   Reply With Quote
Old July 31st, 2012, 10:36 PM   #2
big86inthestixx
big86inthestixx's Avatar
They sell special tools for removing/installing the crossover tubes, and injectors but as long as you are careful with a screwdriver you can remove them without hurting anything.
If your close to howard city mi I have the tools, you may borrow.
If you dont want to chance it. Ive done it both ways, the proper tools make the job faster. No real tricks, only advise is to keep injector tip covers on until absolutly ready to put em in the hole. One spec of dirt will plug em up. easiest injectors to change as far as diesels go. In my opinion. Im slow, but it usually takes me about 3 hours for removal, installation.
Good luck.
Check out the cummins forum or google "mopar man" either one has very good write upz on all things to do with injectors, as well as valve adjustment that is worth doing while the valve cover is off.
Sent from my SPH-D710 using Tapatalk 2
big86inthestixx is online now   Reply With Quote
Old August 1st, 2012, 06:35 PM   #3
Jiveturkey3
Jiveturkey3's Avatar
Use a small SMALL dab of atf or grease to keep the copper washers on. As far as pulling the old ones, the bolts from the tps (you have to remove them) fit in the top of the injector. Have some rtv on hand to reseal your intake elbow. Number six will cause a few frustrations. Took me about 2-3 hours my first time ever. Nothing hard about it really. The bolt trick will make it easier. Read a right up and keep it near to refer to. I will see if I can find the one I used which includes all sizes and torque specs.
Jiveturkey3 is offline   Reply With Quote
Page generated in 0.22034 seconds with 32 queries
