Thread Tools
Old July 31st, 2012, 10:10 AM   #1
Mr. Beefy
Stacks n Boggers
Mr. Beefy's Avatar
Adding an axle
I'm looking at adding a third axle to my wedge trailer.
I'm not sure how to work the leaf springs when doing this.
Anyone have a good pic of how they need to be attached to eachother?
97 Dakota truggy on tons and 43's
07 CTD tow pig MinniMax Tuner 5" turbo back and Egr delete
Screams like a crack whore fucking for a rock.
Mr. Beefy is online now   Reply With Quote
Old July 31st, 2012, 10:14 AM   #2
No pics but it needs to be independant. You should have 2 axles with the common balancer in the middle and one axle traditional fixed at the front with shackles at the back.
GLFWDA member since 1979.
Member Southern Michigan Rock Crawlers.
Old July 31st, 2012, 10:18 AM   #3
Mr. Beefy
Stacks n Boggers
Mr. Beefy's Avatar
Ok I'm going to add it in front of the two already on it. The two behind this already have the balancer on them.
So I can build just a simple hanger in the back and fixed point on the front? Easy enough
Old July 31st, 2012, 10:32 AM   #4
I think so but the ones I have seen, the single axle is in the rear. Why? Not sure if it makes a difference.
Old July 31st, 2012, 10:45 AM   #5
Mr. Beefy
Stacks n Boggers
Mr. Beefy's Avatar
That would also not be too much work and prolly not a bad idea to go through the old leaf spings in the back with new bushings and such
Old July 31st, 2012, 10:45 AM   #6
Mr. Beefy
Stacks n Boggers
Mr. Beefy's Avatar
Any idea how to figure out what my axles are actually rated for?
They look fairly large and are actually trussed already
Old July 31st, 2012, 03:18 PM   #7
Elvis13
I researched the backing plates and drum setup on mine. The brake assembly packages gave me a weight rating or range for the axle, i'm guessing this isn't a foolproof system but may help. Dexter told me they may have #'s stamped on the axle tube.
Old July 31st, 2012, 11:31 PM   #8
Mr. Beefy
Stacks n Boggers
Mr. Beefy's Avatar
Looking up my trailer on the internet found this pic
Wow that hurts
Old August 13th, 2012, 07:47 AM   #9
rideraa
rideraa's Avatar
Here is a dexter triple axle diagram.
The triple equalizer is a different shape then common.
These dim's are for 26" springs, 5200lb axle rating, Tires ST225/75R-15 D Range
rideraa is offline   Reply With Quote
Old August 13th, 2012, 08:33 AM   #10
Route55
Formerly keithshotrodshop
Route55's Avatar
You didn't mention why you plan to do this, but let me add a thought:
Triple axle trailers kinda suck. The front and rear axles scrub hard while turning, burning up those trailer tires quickly. This can be somewhat relieved with torsion axles, but not completely. That is what I have on my triple axle, and 15,000 miles or so is the max for the front axle tires. A spring hung triple axle scrubs even harder.
Most of the hotshot guys like myself are going to heavy duty double axle trailers, usually with 17.5 or 19.5 tires.
I fully plan to either convert my current trailer to double, or sell it to fund another one. As far as I can tell, the only benefit to a triple axle is the "I have to run on a flat for a few miles" situation.
In a wedge trailer design, IMO the perfect combo would be a dual dually axle. That would give tire redundancy with much better turning characteristics.
Route55 is online now   Reply With Quote
Old August 13th, 2012, 08:50 AM   #11
To Keith's point about heavy duty duals, here is Jesse Oliver's dual axle setup. We checked tires & wheels at every stop and they wore great & never got hot.
Old August 13th, 2012, 09:01 AM   #12
Mr. Beefy
Stacks n Boggers
Mr. Beefy's Avatar
Hrmm thats a good idea much more expensive but prolly a better idea.
I'll have to keep my eye out for some new axles.
Thanks guys
Old August 13th, 2012, 09:07 AM   #13
Route55
Route55's Avatar
Your current axles may be somewhat upgradeable. The tubes, knuckles, spindles, brakes, etc. on my Dexter torsion axles in my enclosed are the same through many of the weight ratings with the only difference being the drums and bolt pattern. Same goes for the Dexter sprung axles on my flatbed, six lug drums meant 4,000 lb axles, eight lug meant 6,000 lb axles. Brakes and everything else are interchangeable.
Old August 13th, 2012, 01:01 PM   #14
4x4xdodgeman
Send a message via Yahoo to 4x4xdodgeman
i see you found how to tell the axle weight, but did thay tell you need 60% of the trailer in front of the first axle. or its not going to handle good with a load on.
4x4xdodgeman is offline   Reply With Quote
Old August 14th, 2012, 07:23 AM   #15
rideraa
rideraa's Avatar
FYI
http://stores.ebay.com/Johnsons-Surp...=p4634.c0.m322
These people have alot of axles etc, They are very close to where I live.
If you are looking to buy. Call them 269-483-2814, White Pigeon MI.
Ask what makes an axle 7k rated if your thinking tandem.(may be able to convert yours)
I am coming to the Club Comp @ R&V and could bring axles or etc. up if needed.
Old August 23rd, 2012, 09:05 PM   #16
jeepm715
jeepm715's Avatar
I picked up a set of 17.5 wheels and tires right before this trip, load range h. They wore great as Jim said, after 5000 miles to Cali and back, still like new. The cheapo e rated ones that came on it showed major wear after a summer of double hauling.
jeepm715 is online now   Reply With Quote
Old August 23rd, 2012, 09:50 PM   #17
Mr. Beefy
Stacks n Boggers
Mr. Beefy's Avatar
Hrmm so on that trailer is just the rear axle a dual? Very nice setup you have there
Old August 24th, 2012, 11:28 AM   #18
jeepm715
jeepm715's Avatar
Nope, just a pair of 7000 lb single wheel axles. I'm relying on the truck to carry a bit of weight, thinking about some air bags to help out. A dually truck would help tire wear, 5000 miles of towing smoked about half of the tread off the tera grapplers
Old August 27th, 2012, 07:45 PM   #19
akozman
Chrome Trucker Chicks Rul
akozman's Avatar
That's what I did when I added an axle.
akozman is offline   Reply With Quote
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.17506 seconds with 48 queries
