2001 tj no more dd budget rock crawler - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2014, 07:08 AM   #81
Toyfish
Toyfish's Avatar
Nope that wasnt me
Sent from my DROID X2 using Tapatalk 2
Old March 14th, 2014, 07:25 AM   #82
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Originally Posted by Toyfish View Post
Btw u were right that pump is noisy lol
yes it is
H.o.r.e
Old March 14th, 2014, 12:12 PM   #83
firehawk
Live Action!
firehawk's Avatar
Haha, yup! Could try rubber mounts.
I would run Rubber F.I. hose instead of that aluminum stuff, I foresee it breaking at some point and then kabooom, no mo TJ.
Just because I care
Old March 14th, 2014, 12:20 PM   #84
Toyfish
Toyfish's Avatar
Just because I care
Yea i plan on eventually redoing the lines to make it look nicer
Old March 14th, 2014, 12:34 PM   #85
montecarlo33
The Violator
montecarlo33's Avatar
I would be mounting that filter/pump on the frame rail, instead of in the cab with you. But that's just me.
Old March 14th, 2014, 12:34 PM   #86
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Just because I care
that aluminum worked just fine
H.o.r.e
Old March 14th, 2014, 01:11 PM   #87
buttercr125
I work out
buttercr125's Avatar
Dropped the gas take today and installed my fuel cell.
So much room!
New parts!
Msd inline fuel pump
Corvette fuel filter internally regulated with return line.
You are going to want to change the way that tank is mounted down. Those tabs are just for looks and will break off and/or crack the fuel cell. There are a couple companies that make a mounting kit for that fuel cell.
Old March 14th, 2014, 02:34 PM   #88
1 ton tj on 40's
1 ton tj on 40's's Avatar
mine is mounted the same way. with no issues.
Old March 14th, 2014, 02:44 PM   #89
daxl350
daxl350's Avatar
He wheels like a old lady thay should be fine
daxl350 is offline   Reply With Quote
Old March 14th, 2014, 03:01 PM   #90
1 ton tj on 40's
dam
Old March 14th, 2014, 03:23 PM   #91
Toyfish
Toyfish's Avatar
I do not!
Old March 14th, 2014, 04:23 PM   #92
firehawk
Live Action!
firehawk's Avatar
Hahol
Old March 14th, 2014, 05:42 PM   #93
michigan maniac
michigan maniac's Avatar
It's true tho my brothers fuel cell cracked from mounting it with those beefy "mounting tabs". I would do straps over the top also
Old March 14th, 2014, 05:58 PM   #94
daxl350
daxl350's Avatar
I would use a ratchet strap
Old March 14th, 2014, 06:41 PM   #95
Toyfish
Toyfish's Avatar
Sounds legit
Old March 14th, 2014, 07:42 PM   #96
fordbronco
the ocean called
fordbronco's Avatar
duct tape
Old March 14th, 2014, 08:37 PM   #97
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
I put a ratchet strap on mine temporally after I got done 2 years ago. Still there:)
Old March 14th, 2014, 08:39 PM   #98
Toyfish
Toyfish's Avatar
Ill eventually bend up a set of straps at work. I say that now but it prolly wont happen till i break the tabs off....
Old March 14th, 2014, 09:13 PM   #99
daxl350
daxl350's Avatar
That's where the idea came from
Old March 14th, 2014, 09:28 PM   #100
wilinsonlevi
Team Thumbs Up
I have one strap on it. Across the center, I put rubber under the strap where it touches cell. Nothing has moved at all ever.
Page generated in 0.34026 seconds with 84 queries
