2001 tj no more dd budget rock crawler - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 22nd, 2013, 08:44 PM   #41
Toyfish
Toyfish's Avatar
Got alot of work done tonite pulled the axle out clean it up and welded on my ballistic fab truss.
Then i bolted the shocks and lower arms back on and used tie downs to hold it at ride height. I tacked on the lower frame mounts which need to go about an inch farther forward.
Now i just need to make and mount a upper link and move my lowers then i can move onto the new trans cross member.
Sent from my DROID X2 using Tapatalk 2
Old November 22nd, 2013, 08:51 PM   #42
firehawk
Live Action!
firehawk's Avatar
Ahhhhh yeah, here he comes!!!!!!!!!!!!!!!!!!
You gonnna jump that shit?
Old November 22nd, 2013, 08:52 PM   #43
Toyfish
Toyfish's Avatar
Possibly lol
Old November 22nd, 2013, 08:53 PM   #44
firehawk
Live Action!
firehawk's Avatar
That thing going to fill with mud?
Old November 22nd, 2013, 08:55 PM   #45
firehawk
Live Action!
firehawk's Avatar
And ask me before you spend any more money on that thing, I will tell you what to upgrade. And I will tell you to buy mine asap so I can upgrade. Ok, thanks.
Old November 22nd, 2013, 08:58 PM   #46
Toyfish
Toyfish's Avatar
I hope not... its not welded solid across the bottom so it should drain. The next upgraded will be chromo axles and a cage then i should be good for a long time....
Old November 22nd, 2013, 09:04 PM   #47
firehawk
Live Action!
firehawk's Avatar
Yes it will. You could cut out some arches to drain but a slit will clog with Mounds muck. Or put tube through the holes and weld them and weld the whole bottom.
Old November 22nd, 2013, 09:08 PM   #48
Toyfish
Toyfish's Avatar
Yea i have thought about both of those options ill prolly cut arches in it between the stitch welds holding it on
Old November 23rd, 2013, 09:18 AM   #49
1 ton tj on 40's
1 ton tj on 40's's Avatar
I hope not... its not welded solid across the bottom so it should drain. The next upgraded will be chromo axles and a cage then I should need tons an a set of bead locks an 40's or 42's
fixed
Old November 23rd, 2013, 07:47 PM   #50
Toyfish
Toyfish's Avatar
Just got back in town from picking up a new tcase with a sye already installed!! Hopefully it will get put in the jeep tomorrow.
Old January 13th, 2014, 07:55 PM   #51
Toyfish
Toyfish's Avatar
Havent updated this in a while but i got the sye in and the long arm done and it performed well its first time out. I have since installed a teraflex oil pan skid and pulled the radio out to mount a oil pressure gauge and i will be mounting my cb right next to the oil pressure gauge.
Old January 13th, 2014, 08:05 PM   #52
michigan maniac
michigan maniac's Avatar
Least no body can steal your radio now !!
Old January 13th, 2014, 08:11 PM   #53
Toyfish
Toyfish's Avatar
Haha yea the thing is too loud on the road to really hear it and i never listen to it while i wheel so its gone
Old January 13th, 2014, 10:05 PM   #54
alboy79
Where's your loyalty lie?
alboy79's Avatar
you just need some bigger speakers!
"Skill that is untested does not equate to actual skill." Test yourself!
Don't tell me what you've done.
Show me what you can do.
alboy79 is offline   Reply With Quote
Old March 10th, 2014, 02:06 PM   #55
Toyfish
Toyfish's Avatar
Thanks to big b i now have some wheel spacers so my tires dont rub on my long arms and i got a sweet fuel cell that will fit behind my rear seat!
Old March 10th, 2014, 07:41 PM   #56
1 ton tj on 40's
Old March 10th, 2014, 07:51 PM   #57
firehawk
Live Action!
firehawk's Avatar
Fix that axle yet?
Old March 10th, 2014, 07:56 PM   #58
Toyfish
Toyfish's Avatar
Fix that axle yet?
I have another shaft to put in it but all me and josh did was pull the inner so i could drive it home
Old March 10th, 2014, 08:26 PM   #59
bigbchevy
missmrgreenagain
bigbchevy's Avatar
I have extra shafts
H.o.r.e
Old March 10th, 2014, 08:33 PM   #60
Toyfish
Toyfish's Avatar
Originally Posted by bigbchevy View Post
I have extra shafts
I may need them sooner or later lol
Page generated in 0.40661 seconds with 84 queries
