Need some help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 30th, 2012, 12:11 PM   #1
nesterautogroup
nesterautogroup's Avatar
Default Need some help
So I have a 1971 GMC Jimmy on a 6" lift with 37's, wanting to do a gear upgrade, has stock GM 12 Bolt with 3.08 gears wanted to go to 4.56 gears. Ordered from 4WD online was originally told that a new carrier was not needed for rear axle, as we tried to install new ring and pinion found out this was not the case, called back to 4WD parts they directed me to Randy's Ring and Pinion, ordered another set and was told the same thing that a new carrier is not necessary that the Yukon gears are thicker and will make up the difference, got them here and compared them to the first set I ordered only to find out they are identical. Any assistance in this matter would be much appreciated if anyone has any parts that may help that would be much appreciated. I was trying to do this on the cheaper side since this thing will be a pavement pounder and boat hauler.
nesterautogroup is offline   Reply With Quote
Old July 30th, 2012, 01:58 PM   #3
kevinr839
kevinr839's Avatar
I have used a gear spacer before. It is not the best way to do it, but it worked.
kevinr839 is offline   Reply With Quote
Page generated in 0.19020 seconds with 33 queries
