Rebuilding my 318 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2012, 06:21 PM   #1
jwalsh
jwalsh's Avatar
Default Rebuilding my 318
O.k, I plan on rebuilding my 318 for my Dakota this winter, but im not quite sure what i want to do, or the best way to get what i want.. I am looking for a more power, and hopefully better MGP.
My plan as of right now is bore it .30 over, a mid size cam (not sure what yet), possibly forged bottom end, not sure if im gonna leave the crank as is, not sure what to do for heads (I am trying to stick to an affordable build, so no crazy heads, just modifying stock heads, or close to), and then probably a T.B spacer.. and suggestions let me know.
THANK YOU
-Jon-
jwalsh is offline   Reply With Quote
Old July 29th, 2012, 06:10 PM   #2
junkyardjon
what's your budget? might be better off buying a crate engine
junkyardjon is offline   Reply With Quote
Old July 30th, 2012, 05:57 PM   #3
jwalsh
jwalsh's Avatar
I would really like to stay under 1000.. realisticly, the less i spend the better, so i can put money into other areas
Old July 31st, 2012, 08:54 AM   #4
snocross2xtremes
snocross2xtremes's Avatar
I just did mine and I have just over 3k I'n it.
99 mag 318 new stock heads gasket match and decked 30 over comp cam and a sct programer
Old August 4th, 2012, 05:44 PM   #5
jwalsh
jwalsh's Avatar
Well, i plan on using my heads, or getting used ones... did u build it yourself, or have it built?
Old August 26th, 2012, 06:34 PM   #6
jwalsh
jwalsh's Avatar
any other suggestions?
Old September 22nd, 2012, 11:51 PM   #7
jwalsh
jwalsh's Avatar
is there any advantage to using heads from a 360 over the ones from my 318?
Old September 22nd, 2012, 11:52 PM   #8
steveo
In the band!
Why?
Old September 23rd, 2012, 03:42 PM   #9
Coonburger
Coonburger's Avatar
hrm walsh ur gonna be tight getting it done for 1000 grand. All your power increase is mainly your heads ive heard u loose a little compression but if ur putting in a bigger cam its worth it to do. Now some 318 intakes wont fight the 360 heads so ull need a 360 intake. I haven't done any specific research on this just remember seeing it on some dodge forums a while back. i think adding the heads makes the motor into a 340.
Coonburger is offline   Reply With Quote
Old September 23rd, 2012, 03:49 PM   #10
Bo's Cj 7
Bo's Cj 7's Avatar
Don't think changing heads make the cubic inches bigger.
I would find a 360 rebuild it and you will have the power you want and the truck won't be down as long. Then you can sell your motor for something after the new one is in and running.
Bo's Cj 7 is offline   Reply With Quote
Old October 1st, 2012, 08:03 AM   #11
jwalsh
jwalsh's Avatar
i have considered rebuilding a 360, either way i go, i am planning on finding a motor to rebuild while mine is still in my truck.. if i go with a 360, do i need to swap my harness, or just the computer?
Old October 1st, 2012, 09:10 PM   #12
jwalsh
jwalsh's Avatar
well, i think i will stick with my 318, and i am probably going to go with edlebrock heads, if i can afford them when i start the build
Old October 1st, 2012, 09:37 PM   #13
DZWrangler
DZWrangler's Avatar
I'd be interested in how it goes during the build process. I have a 318 I have to rebuild as well
DZWrangler is offline   Reply With Quote
Old October 2nd, 2012, 09:53 AM   #14
v2win
v2win's Avatar
I would pull a motor and trans from a junkyard and rebuild that as you have time. The cost to rebuild is going to be close to the same.
There are some differences between the two if you go with a 360. The 318 is balanced internally and the 360 is balanced externally so the torque converter is different as well as a different flex plate.
The heads on the 360 flow a little better and respond to port matching and cleaning up the bowls really well with a cam swap.
v2win is offline   Reply With Quote
Old November 28th, 2012, 03:19 AM   #15
Ajhawk
Ajhawk's Avatar
as far as stock things go with the heads and such, i suggest a simple port and polish, if youre good with a die grinder and know what youre doing, you can do it yourself in a few hours.
Ajhawk is offline   Reply With Quote
Old November 28th, 2012, 03:29 AM   #16
Ajhawk
Ajhawk's Avatar
http://www.campbellenterprises.com/3...roker-kits.php
also i know its just a bit over your price, but if you want to make a stroker, heres a few options.
Old December 1st, 2012, 07:58 PM   #17
jwalsh
jwalsh's Avatar
as of right now, i started tearing down a 318 from my brothers ram that "blew up" on hime.. found out it was all gummed up and completely nasty inside.. but i have everything freed up for now, and no apparent scarring.. now im looking for a machine shop to drop it off at
Old December 29th, 2012, 01:39 PM   #18
ssgtgaines
ssgtgaines's Avatar
If you are gonna rebuild an engine. You are better off doing everything you want the first time. Save your money and buy good parts. If you cheap out "and settle" you will regret it later. And end up spending more money later. Ive changed my engine in my drag car 4 times. Spent thousands that i didnt have too. If you want good low end. I say stroke it. A 4 inch crank should fit without having to clearance the block. Call comp and get a good low end cam, and that thing ill be a torque monster. All you need are some decent heads. You dont need monster heads unless you are turning a bunch of rpm. Goodluck
ssgtgaines is offline   Reply With Quote
Old December 29th, 2012, 01:41 PM   #19
ssgtgaines
ssgtgaines's Avatar
Ic you are looking for a good machine shop in that area. Call performance engineering. They do all kinds off work from semi truck engines to exotic mountain motor stuff. They are fast, good, and reasonably priced.
Old December 30th, 2012, 07:25 AM   #20
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
Default harmonic ballancer
don't forget the harmonic ballancer will need to be matched tot he 360 as well, if you get a junk yard 360 they may strip it off the 360 and you will be screwed with out it.
harmonic ballancer, tourque converter, flex plate, all direct bolt all need to be swapped out to match the 360,
Supreme Chancellor!
dougstephvoor is offline   Reply With Quote
Page generated in 0.36816 seconds with 83 queries
