Ford Sterling Disc Brake Bracket from Ruffstuff! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 25th, 2012, 03:38 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow Ford Sterling Disc Brake Bracket from Ruffstuff!
Here you are, an easy bolt on bracket for the Sterling axles using cheap off the shelf parts! No secret handshakes to get replacement parts:D This one uses the GM Caliper ('73-87 3/4 Ton 4x4 Front) because it is 1/2 the cost of the Ford and way less expensive to put together than the wedge system. the rotor is a '96 Ford E350 Van Rear rotor. These were a long time coming but way worth the wait! $50 a pair!
[SIGPIC][/SIGPIC]
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old August 15th, 2012, 07:26 PM   #2
Gravel Maker
Steel Hauler
Smile Ford Sterling Disc Brake Bracket from Ruffstuff!
A great way to lighten up your rear end and improve your stopping power !!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old September 27th, 2012, 01:54 PM   #3
Gravel Maker
Steel Hauler
This will stop you !!!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Page generated in 0.13195 seconds with 32 queries
