Something New, Safety Misalignment! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 25th, 2012, 03:33 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Thumbs up Something New, Safety Misalignment!
Not Safety Washers & not Standard High Misalignment.
I was looking to add Safety Washers to our line up but something kept bugging me. Wouldn’t the mating surface between the High Misalignment and the Safety Washer add more stress to something you are trying to make more safe? Misalignment goes inside the bore of the rod end to remove the stress but a traditional Safety Washer goes on top of the stack and adds an unresolved join right next to the bolt end.
What I came up with doesn’t seem like it should be revolutionary or anything but I couldn’t find another like it so here goes. I combined the Safety Washer with the High Misalignment to eliminate the need for a separate piece. I would only use them where needed because they cost a bit more than a traditional High Misalinment because we have to start with a substantially larger Stainless Rod and Stainless isn’t cheap.
Another benefit is while eliminating the gap between the safety washer, you shorten the bolt overall length which lessens the leverage on the bolt.
[SIGPIC][/SIGPIC]
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old August 24th, 2012, 04:27 PM   #2
Gravel Maker
Steel Hauler
Arrow Something New, Safety Misalignment!
Play it safe and run these !!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old July 16th, 2013, 09:25 AM   #3
Gravel Maker
Steel Hauler
You can't pick these up at your local hardware store!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old July 26th, 2013, 10:18 AM   #4
Gravel Maker
Steel Hauler
Friday! Time to hit the trails!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Page generated in 0.27907 seconds with 35 queries
