| Home | Register | iTrader | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Store | Photo Gallery | Chat |
Thread Tools |
#1 |
Saved by Grace
CJ7 steel hard Doors, need a bit of work, $150
I have a set of CJ steel hard doors of a 1982 Jeep CJ7 for sale. They are in fair condition, with some rusting and paint chipping near the bottom of the doors. The drivers side has the worst of the corrosion, but it still isn't that bad. No gaping holes or anything. The driver side door mirror has also been broken off.
The bad is that although both doors have good windows and cranks, only the driver side window can roll up/down. The passenger side will need a new regulator. (Makes a loud popping noise when you try and roll the window up/down. I can't say whether the seals are good or not anymore but you might as well replace them while the door's apart. Hinges are not rusted through but do have surface rust as seen in pics so not sure if those need to be replaced or not. Price is $175 obo These doors aren't perfect, and could definitely use some clean up, but they are a great deal for the price. Feel free to pm or call/ txt 248-828-5219 with offers and questions. Doors do NOT have a key to go with the lock, so that will also need to be replaced. $30 for a tumbler set online. trades of other cj parts could be possible. txt me and let me know what you have and I'll tell you if I need them. for a start, looking for a good gas tank skid plate, bought and never used body mount kits, body lift kits, rear cross member, stainless steel or braided fuel/brake lines. let me know what you have. Thanks tags:doors steel hard doors jeep original willys cj3 cj5 cj6 cj7 cj7 limited cj8 scrambler renegade wranger yj cj tj 4x4 4wd cheap ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Saved by Grace
also, door panels are intact, but I think it's the passenger one that needs to be taken off and put back on again. It's sorta half popped off and half secured. hard to explain but needs re-installation, or at worst, a new panel after you put the regulator in.
#3 |
Saved by Grace
bump
any offers? would be willing to trade for a body mount kit and/or body lift kit for a cj7. not sure if anyone has a set laying around. also trade for stainless/braided fuel & brake lines |
#13 |
Saved by Grace
Fixed. Thanks. Apparently I deleted all the pics in a moment of................ clean up????
in that case.......... do you think $175 is too much?? ![]() If I end up buying some of the parts from you that I plan on........ $25 is another drop in the bucket........ Last edited by 82cj7ltd; August 26th, 2012 at 10:03 PM. |
#17 |
Saved by Grace
k. can u still not see the pics? I couldnt see them last night before I fixed them, but I
ed all the links and could see them last night. still lookin at them now.
#18 |
Saved by Grace
| Thread Tools | |
