What to paint axle with? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 23rd, 2012, 09:07 AM   #1
Mihlfeldl2005
Life=Short. Jeeps=Cool
Mihlfeldl2005's Avatar
Send a message via Yahoo to Mihlfeldl2005 Send a message via Skype™ to Mihlfeldl2005
Default What to paint axle with?
Getting to the point in my axle project that I need to start considering what I'm going to finish these things with? Sense they're going to get a little bit of abuse I've been debating finishing them with a bedliner/line-x style paint or maybe POR 15?
Any suggestions?
Mihlfeldl2005 is offline   Reply With Quote
Old July 23rd, 2012, 09:53 AM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Any suggestions?
Black spray paint = easy touch up.
Old July 23rd, 2012, 10:43 AM   #3
Mihlfeldl2005
any experience with the POR 15 stuff? at $150 a gallon I'm somewhat hesitant to try it
Old July 23rd, 2012, 10:46 AM   #4
4x4 jeep
2 tracken in the mud
4x4 jeep's Avatar
Por15 is for rust. Spray paint works, easy to touch up.
4x4 jeep is offline   Reply With Quote
Old July 23rd, 2012, 10:47 AM   #5
Mihlfeldl2005
Since the general consensus is spray paint. Any tips on priming it?
Old July 23rd, 2012, 10:54 AM   #6
Bo's Cj 7
Bo's Cj 7's Avatar
I bought a gallon of gloss black rustoleum and use a spray gun put it on (brush also works) thick easy touch up and it seem to last great and I think it was $25 per gallon
Bo's Cj 7 is offline   Reply With Quote
Old July 23rd, 2012, 10:58 AM   #7
XXXJ
Desert Rat
XXXJ's Avatar
I did the same thing on a frame and axles. Used RMax reducer and the stuff was bullet proof.
I've always had good luck using rustoleum. It's not just for rust.
Old July 23rd, 2012, 10:59 AM   #8
mattt8430
POR is great very tough and a gallon is dam near a lifetime supply, i did my 21ft tow truck bed with about a quart
mattt8430 is offline   Reply With Quote
Old July 23rd, 2012, 11:16 AM   #9
GOLIATH
GOLIATH's Avatar
I use Blitz black, You can get it from John Deere dealers. It's a semi gloss finish and you can get it in Gallon or spray cans. $35 a gallon, my whole mud truck and tow rig is sprayed with it, along with my axles and underbody. The stuff is very tough and easy touch up.
GOLIATH is offline   Reply With Quote
Old July 23rd, 2012, 05:58 PM   #10
skife
skife's Avatar
POR15 is sensitive to UV rays, keep it out of the sun light.
Old July 23rd, 2012, 06:23 PM   #11
DuffMan
Your Message Here
DuffMan's Avatar
POR 15 is not UV stabilized (as stated). It also is really, really sensitive to proper surface prep. Also - do not work from the can - pour it into something else because it's very sensitive to contamination (i.e. a few drops of sweat can ruin a quart). It also needs humidity to cure properly (i.e. don't use a good, dry paint booth).
I did my D44 with POR 15 (after cleaning and wire wheeling the snot out of it) and then topcoating with Rustoleum Hammered. Tough as hell and looks pretty good.
Old July 23rd, 2012, 07:27 PM   #12
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
If it's a wheeling rig, I wouldn't go the POR-15 route. If it's a nice "showy" but sometimes wheeled vehicle, it may be a different story. I have used POR-15 a lot in the past, and have a lot of experience with it.
For your purposes, I'd go with Krylon black.
I'm more into "showy". I used a combination of Eastwood Rust Encapsulator, along with Extreme Chassis Black Primer & Topcoat on this Dana 44. The skull was painted with Duplicolor wheel paint (metallic silver).
Craig
Old July 24th, 2012, 08:56 PM   #13
Mihlfeldl2005
Well I took my knuckles and caliper mounts into work today. Sand blasted the hell out of them. Took my about two hours thanks to the shitty booth we had and the decade old sand. I hit them with a base coat of self etching primer and then a couple of coats of flat black rustoleum. I'll be using the same process for the everything else.
Its a pain in the ass waiting for everything to dry though!
Let me know what you think!
Checking to see if I wanted blac
after a little work
Primed!
Knuckles and calipers drying
Sent from my myTouch_4G_Slide using Tapatalk 2
Old July 24th, 2012, 11:58 PM   #14
Mihlfeldl2005
Rebuild
Old July 25th, 2012, 10:51 PM   #15
Mihlfeldl2005
Got the knuckles, caliper brackets, and spindles back on tonight.
Page generated in 0.28907 seconds with 68 queries
