Leaky sidewall repair - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 22nd, 2012, 10:55 PM   #21
joe_jeep
welfare wheeler
joe_jeep's Avatar
for bead leaks, try roof flashing tar, or windshield urethane on the beads.
i used roof flashing tar. worked pretty well. i have no beadlocks, and i never burped air till i was at 3lbs, and pushing hard into a hillside to right a flop. it never lost a bead. i sheared a valve stem at the mounds, and the tire stayed on the rim with zero air. it was a bitch to remove the tire to fix the stem though.
for sidewall pin holes you might try scuffing the inside of the tire and smearing it with vulcanizing glue. it kinda melts into the rubber. kinda like model glue does to a plastic model. that is assuming you can find where the air is escaping from. good luck
Old July 24th, 2012, 05:27 PM   #22
Tab
Tab's Avatar
UPDATE!!! I went out to the barn expecting to have to fill up the leaky tire and it still had five pounds in it! So to recap, tire would go flat in about 36 hours, put in a big bottle slime, lost seven of fourteen pounds I put in overnight, next three days it only lost two more pounds. Good enough for me.
Old July 24th, 2012, 09:52 PM   #23
Good to hear. I'm still mounting them so I haven't done anything yet. You just put in a whole bottle and laid it on the leaky side?
Old July 24th, 2012, 10:32 PM   #24
Tab
Tab's Avatar
No. Since it was already flat I just took out the valve core and squeezed in the whole bottle and filled the tire back up to 14 pounds and drove it a bit. I wasn't going to break down the whole deal to put in slime, if I did I would have patched it from the inside. But the leak in mine is just from a cut, not all over the place like yours.
Old July 25th, 2012, 10:36 AM   #25
michigan maniac
michigan maniac's Avatar
I've tried slime before, it worked ok, but right on the bottle it says something about only working on holes in the tread area, not in the sidewall, prolly cuz of centrifugal force, best bet is to have the tire off the vehicle, so you can lay it on its side, flip and rotate it, I'm curious to try the bars leak,
Old August 1st, 2012, 06:57 PM   #26
pitbull2332
pitbull2332's Avatar
I tried the bars leak mixture in a set of comp cut paddle tires i have a week and a half ago. The tire would go from 10psi to 0 in about 2-3hours. The mix has been in for a week and a half and I have only lost 4psi. It is actually quite impressive for what it is.
pitbull2332 is offline   Reply With Quote
Page generated in 0.17152 seconds with 42 queries
