Leaky sidewall repair - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 21st, 2012, 03:54 PM   #1
Default Leaky sidewall repair
One of my 39.5 Iroks is becoming a nuisance. It keeps losing air over time, maybe 2-3 pounds a day so in a weeks time it's flat. I've sprayed soapy water on it and it seems to be just a thin sidewall and has little bubbles in several places. I'm about to switch the tire over to a different rim and I'm wondering if there is any good product that I can spray on the inside to seal it up.
Any suggestions, personal experiences?
Old July 21st, 2012, 03:57 PM   #2
boggin-machine
boggin-machine's Avatar
slime it up maybe? what about some of the roof repair stuff they have on tv all the time. just a quick even spray of that ?
Old July 21st, 2012, 04:03 PM   #3
tw1st3d5
tw1st3d5's Avatar
I wonder how something like Stan's No Tubes would work? It works wonders on mountain bike tires. You'd need to use probably a whole quart. Just a thought.
http://www.notubes.com/Stans-Tire-Se...rt-P51C14.aspx
Old July 21st, 2012, 04:03 PM   #4
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
What is an equivalent size in a tractor intertube?
ckupq is offline   Reply With Quote
Old July 21st, 2012, 07:28 PM   #5
The Stan's is interesting. Do you just squirt some in your bike tire before you air it up?
Not interested in a tube....... yet.
Old July 21st, 2012, 10:02 PM   #6
tw1st3d5
tw1st3d5's Avatar
You pour a little cup full into the tire then air it up. There are little chunks of a rubbery material in the solution and those are actually what seal the tire in the end. There were a few tires I used to run that were notorious for leaky side walls and it sealed them right up. You may have a few little white spots where the liquid oozed out before it sealed. I may give them a call on Monday and see what they think.
Old July 22nd, 2012, 07:23 AM   #7
Local places carry it or does it have to be ordered? I have a week to get it fixed.
Old July 22nd, 2012, 08:45 AM   #8
Tab
Tab's Avatar
Funny, after our discussion last week I got a 24oz bottle of slime from advanced. The non pressurized one that you just squeeze in when it's flat, and since it's always flat, that wasn't a problem. Same thing, little rubber chunks to seal it up. I figure since the leaks are small, usually shit in the inner bead or a small leak from a small sidewall cut, it should work. I'll report back later to this thread with a 24 hour update. Bottles all say they will seal up to a .25 hole. I think that would be a bit optimistic but we'll see.
Old July 22nd, 2012, 08:46 AM   #9
Tab
Tab's Avatar
Oh and if it works on my worst tire I may get a couple of the small bottles and put it in the rest as a pre emptive strike.
Old July 22nd, 2012, 09:50 AM   #10
sanddude
sanddude's Avatar
Found this on Silverlake sand dune forum. http://www.silverlakeforum.com/index...ic,7891.0.html .Not sure if it will work or not.
sanddude is offline   Reply With Quote
Old July 22nd, 2012, 11:12 AM   #11
Tab
Tab's Avatar
Interesting. I would try this next. The slimes all say they won't harden and is easy to clean up with water. We'll see I guess when I swap these out someday.
Old July 22nd, 2012, 11:47 AM   #12
Well, since I have a bottle of the Bar's leak and some antifreeze in the garage, I think I'll give it a try.
Thanks.
Old July 22nd, 2012, 11:51 AM   #13
Tab
Tab's Avatar
Is it the correct bars leak? Has to be the aluminum stuff.
Old July 22nd, 2012, 11:56 AM   #14
Elusive
Elusive's Avatar
I've had very good luck with slime, But i've never used it in a tire that big.
Elusive is offline   Reply With Quote
Old July 22nd, 2012, 01:47 PM   #15
chevotass
chevotass's Avatar
and bars leaks is a michigan company. just sayin
Old July 22nd, 2012, 03:00 PM   #16
Tab
Tab's Avatar
UPDATE. Tire lost seven pounds overnight I only drove it .3 miles after I put the stuff in so maybe it wasn't enough time to coat everything.
Old July 22nd, 2012, 03:25 PM   #17
Thanks.
Old July 22nd, 2012, 05:36 PM   #18
Bones
Bones's Avatar
I would be worried about the integrity of the tire if it was leaking from the sidewall in the area you described
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 22nd, 2012, 10:02 PM   #19
Naw, a few pinholes don't mean it's going to blow out. I had circle track tires on a buggy years ago that did the same thing. When I called the manufacturer they said that's the nature of the beast for lightweight tires.
Not saying Iroks are lightweight but I don't see them shredding because of this either.
Old July 22nd, 2012, 10:06 PM   #20
liv2mx
i like jungle gym's.
liv2mx's Avatar
i used the black glue they use on car windshields and had real good luck with that for the beads.
Page generated in 1.53541 seconds with 84 queries
