*HELP! 350 Warrior Motor Rebuild! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 19th, 2012, 12:47 PM   #1
silveradoboy
Sam Brown
silveradoboy's Avatar
Default *HELP! 350 Warrior Motor Rebuild!
So when I was up in Cheyboygan for the 4th of July my Warrior blew up.
We knew that the bottom end was getting bad and took it to our local shop and they confirmed that it was the crank giving us problems.
I found a rebuild kit online for <$300 and I would like to fix it myself (the shop wanted $1000 for the fix) I am looking for someone who could help me with the fix. I can pull the motor and probably split the case pretty easily but after that I have no idea what I am doing.
Anyone work with small motors and willing to help me out? Your time will be compensated!
I am located in Rochester but my parents live in Waterford, can transport the bike to either location.
Thanks!
Sam
silveradoboy is offline   Reply With Quote
Old July 20th, 2012, 10:14 PM   #2
YFZdude
aka Mike
YFZdude's Avatar
Well pulling it apart is always the fun part.
I suggest getting a manual. If for no other reason, you should follow the torque specs on the jug and head and get the valves and cam(s) back in proper. As a plus, if you are mechanically minded you can put it together without much help. But the exploded diagrams or steps (depending on the type of manual) make it easier to not have 'leftover parts' when you are done putting it back together.
But don't take my advice to mean you shouldn't enlist an experienced helper. That's always a good idea the first time.
YFZdude is offline   Reply With Quote
Old July 21st, 2012, 11:22 PM   #3
chris1044
chris1044's Avatar
Thanks!
Sam
I'd offer, but I'm extremely busy. Do yourself a favor, and search any type of small engine (two stroke included) bottom end rebuild on google. You'll come across some pictures and that's basically all you need to know.
Crank bearings are not hard to replace as long as you have the proper tools, and any crank work you'll still have to have a shop do (likely - rod bearings, balancing, etc.).
I second the above post that you should get the manual. It's probably going to be 40 bucks, but it'll be worth it.
Old July 22nd, 2012, 12:12 AM   #4
90Notch306
90Notch306's Avatar
Before you start spliting the cases get a manual or exploded views of the motor. There are a few washers that you have to be really careful with when taking it apart. As in not knowing they are there and they fall out then you don't know where they go.
If you can, buy oem instead of hot rods or wiseco. What year warrior is it? Since you are opening it up I would strongly recommend replacing the cam chain, cam chain tensioner, and piston/rings, valve seals. Regardless of what they look like. Also inspect everything closely.
One special tool I would invest in is a flywheel puller. You will need a special tool to do the valve seals also but I could possibly do it for you. I'm also in waterford so let me know if you need any advice/help
90Notch306 is offline   Reply With Quote
Old July 23rd, 2012, 10:54 AM   #5
silveradoboy
Sam Brown
I ordered a service manual already, it should be coming in soon. I was going to get a wiseco kit.....is there a reason to turn away from this one?
It is a 97 warrior... Are you willing to help me with this? Ill pay ya!
I can get it out and do all of that but you sound like you know what you are doing and I really just need that experience haha.
Old July 23rd, 2012, 02:17 PM   #6
90Notch306
90Notch306's Avatar
Pm'd ya
Old July 29th, 2012, 09:12 AM   #7
trailbuggy
http://www.yfm350.com/forums/index.php
trailbuggy is offline   Reply With Quote
Old August 9th, 2012, 08:41 AM   #8
motoman3b
Having rebuilt a warrior motor myself, one word of advice make sure you dont set any parts off to the side I got the cases back together and forgot the drum that controls forward and reverse... needless to say I had to tear it down again and install that so just be organized and double check everything and you'll be fine!
motoman3b is offline   Reply With Quote
Old August 9th, 2012, 08:45 AM   #9
silveradoboy
Sam Brown
Thanks,
Well it looks like I will be taking it to a shop this friday. I have the motor out of the quad and the top end off.
A few people said that they would help me and when the day came to start they were/still are MIA.
I called a few other people and cannot get a phone call back so it looks like I am out of options
Page generated in 0.46079 seconds with 50 queries
