6.0 ls motor ran great. now it doesnt run at all - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2012, 01:31 PM   #101
Why use it in multiple? It has the proper pressure and flow ratings as-is.
I don't know why it is so hard. I took my standard YJ sending unit/fuel pickup system and hose clamped a new in tank pump to it. Since I was using a different remote fuel gauge, I used the the old bulkhead electrical connection as my power source.
I needed about 1 1/2" of high pressure rubber fuel line to adapt the outlet barb of the pump to the bulkhead tube from the old pickup. I attached a filter to the inlet barb and I was done.
I'm no baller 1% er like Erin but I have run my engine WOT on many hill climbs and have run it from a standing start, full throttle acceleration to speeds way beyond where it should be and never have been starved for fuel in either situation.
Old October 5th, 2012, 01:40 PM   #102
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
there is a huge thread on pirate about this topic.
The walbros are a finer mesh then what a stock "Sock pickup" would be and it was believed thats what was causing some of the issues with pumps.
what alot of guys have gone to is a dual intank set up using a stock pick up "sock" with the main pump they want to run. Then on the second pump is where they are running multiple walbros for the low fuel situations and switching to that only when needed to try and not put extra strain on the pumps.
Jim i wasnt bashing your set up. i would think walbros are fine for a trail rig but on a car that gets raced and is burning 100 or more gallons during a race preserving fuel pumps becomes a science i believe. So mine as well learn from others problems and build on it.
Old October 5th, 2012, 02:12 PM   #103
Casey,
I didn't consider you to be bashing, just trying to have a discussion on it. Yeah, for somebody running WOT in a race it might be a problem but we all know Nick is a puss & will never rev his up.
FWIW I used the stock sock that came with the pump. On the other hand, if you want to run an inline fuel filter, why bother with a sock? (assuming you don't have shit in your tank)
Old October 7th, 2012, 11:02 AM   #104
chevotass
chevotass's Avatar
when you buy a new intank pump from autozone does it come with a new sock?
Old October 7th, 2012, 11:39 AM   #105
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
Casey,
I would recommend the sock, even with an inline filter. No need to get trash into the pump.
JohnnyJ is online now   Reply With Quote
Old October 8th, 2012, 08:10 PM   #106
pigfat
GONE COMMANDO
pigfat's Avatar
It does but you may have to seal the hole where the fuel tank pressure sensor goes. as some of them dont come with the sensor.
pigfat is offline   Reply With Quote
Old October 28th, 2012, 03:01 PM   #107
chevotass
chevotass's Avatar
update.
i now have an intank fuel pump. oh and still only 42lbs pressure at the rail. FML
Old October 28th, 2012, 03:18 PM   #108
deerebowtie
Unchained
deerebowtie's Avatar
in the last 9 years I've had 4 walbro/off brand pumps that wouldn't build adequate pressure out of the box. 87-94 TBI and 97-99 vortec.
I'm not a mechanic by trade and don't replace fuel pumps often.
edit: what model pump did they give you?
Old October 28th, 2012, 04:09 PM   #109
chevotass
chevotass's Avatar
i had an inline e2000. just put a 5ca421 in. spec pump for the 6.0 truck motor
Old October 28th, 2012, 04:15 PM   #110
1 ton tj on 40's
1 ton tj on 40's's Avatar
hope this is not a way not to show up
Old October 28th, 2012, 04:48 PM   #111
chevotass
chevotass's Avatar
It runs at 42lbs. Thats how awezome of a motor it is. My swaybar not showing up in time is why i will lose. Im gonna body roll right off the course
Old October 28th, 2012, 05:04 PM   #112
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
come get my pressure regulator
Old October 28th, 2012, 05:41 PM   #113
Bones
Bones's Avatar
try a different pressure gauge?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old February 19th, 2013, 09:01 PM   #114
chevotass
chevotass's Avatar
update.
showing good pressure now. all new 3/8 fuel line. intank pump. with my e2000 frame mount also installed. im using the inline pump with the intank pump.
went to snofari and was running great til about an hour into the trailride. would idle and cruise great. but once you got into the throttle it started to spit and sputter.
did this all day until our ride back into town it got alot worse to where i could barely get down the road and onto the trailer.
came home took it out for 30 min drive and it runs great with out one miss. shows good pressure still. so i ordered an obd2 blue tooth dongle and torque on my phone. thought maybe its not fuel and a sensor or vaccuum issue.
showing zero codes.
now im onto possibly vapor lock? anybody else have some ideas.
Old February 19th, 2013, 09:08 PM   #115
2 fuel pumps?
Old February 19th, 2013, 09:10 PM   #116
chevotass
chevotass's Avatar
yep.. that intank one only runs 42lbs and is loud as hell. I put my inline one back in and as soon as i turn that on it shoots to 60lbs and they both run quiet. anyone see a problem with this?
i like it because if one fails i still have one installed to get me home. unless its pushing to much fuel and flooding the motor. i dunno. im about out of ideas. was really thinking this last issue was sensor related because its so hit and miss. but not looking that way.
Old February 19th, 2013, 09:12 PM   #117
Motorcitydak
Merkin salesman
Motorcitydak's Avatar
Send a message via AIM to Motorcitydak
Probably vapor lock. Just a temporary fix is to back ice packs around the line from the cell to the pump. How far away from the fuel cell is your external pump? Also it should be down hill and as close as possible to the fuel cell. Honestly the best idea is just to stick a single walboro 255 or whatever they are called inside the fuel cell itself, then run an external regulator. Does that engine have a return line? If you need a regulator, use one of those corvette ones that regulate to I think 50psi or something like that. It has a return line and a single feed line
Also I would not spray starter fluid in an intake like those LS ones, if it is one of the ones I am thinking of with the runners drawing off a wide open plenum. They do not actually allow liquid to drain into the cylinders. I have seen pics of intakes that blow apart because it pools, then a back fire and BOOM
Motorcitydak is offline   Reply With Quote
Old February 19th, 2013, 09:27 PM   #118
Toyfish
Toyfish's Avatar
Is this a drive by wire motor? I had a gm car come into the shop and the throttle pedal sensor caused it to stumble and run shitty off idle but had no codes
Old February 19th, 2013, 09:28 PM   #119
chevotass
chevotass's Avatar
yes. drive by wire. how did you fix it?
Old February 19th, 2013, 09:29 PM   #120
Toyfish
Toyfish's Avatar
I would look into the thorttle body and pedal assembly
Page generated in 0.53155 seconds with 83 queries
