6.0 ls motor ran great. now it doesnt run at all - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 19th, 2012, 03:56 PM   #21
Why YJ?
Don't be a wuss... HIT IT
Why YJ?'s Avatar
I thought I heard somewhere that the injectors are known to clog up if the motor sits for a while. I would check the fuel pressure and then check injectors.
2005 LJ comp cut, 1 tons, etc...
Paul
www.teamhodges.com
Why YJ? is offline   Reply With Quote
Old July 19th, 2012, 06:39 PM   #22
Have heard of it. If it has pressure at the rail, but won't fire, check the plugs for raw fuel.
Old July 19th, 2012, 09:21 PM   #23
chevotass
chevotass's Avatar
well i fingered it out. 1 my part and one rci part. those fawkers put the stickers on the rong ports. that was the 1st issue. i was getting zero pressure at the rail. so i said ehhhh why not check with a mirror on a stick and see if i have the right port on the cell. NOPE. they labeled it backwards.
sooo i flipped my lines. STILL NO PRESSURE OR FIRE. the only other thing i did was add a new fuel filter because the old one got smashed when i was full stuffing my new suspension. had no part # so i just winged it and got one that looked like it. so I pulled the fuel filter out. WALLA vroooommmm vroooommmm vroooommmmmm
pressure is showing 50psi. Its an external pump. but ran great before. hopefully its good to go. ill know saturday.
thanks for the help everyone
and fawk RCI!
Old July 19th, 2012, 10:38 PM   #24
Strangler
Strangler's Avatar
Originally Posted by bdd1469 View Post
That is the dumbest thing I've heard all day.And I work with some real idiots.
My Jeep runs
Old July 19th, 2012, 10:49 PM   #25
chevotass
chevotass's Avatar
my jeep runs now too
Old July 19th, 2012, 10:52 PM   #26
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Why was the filter no letting it build pressure?
Old July 19th, 2012, 10:59 PM   #27
chevotass
chevotass's Avatar
i have no idea. but i took it off and it worked? maybe to restrictive??? either way im getting the correct one tomorrow and see what happens.
Old July 19th, 2012, 11:36 PM   #28
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Thats odd that it went from nothing to 50 by just removing the filter. You would have thought that it would build build some pressure even if the filter was too restrictive.
Old July 19th, 2012, 11:40 PM   #29
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
You sure you had it flowing the right direction for the filter?
Old July 20th, 2012, 10:29 AM   #30
1 ton tj on 40's
1 ton tj on 40's's Avatar
Originally Posted by Strangler View Post
My Jeep runs
mine runs to
Old July 20th, 2012, 10:34 AM   #31
It might fun 'fine' but 50 psi isn't correct for the motor. It'd be interesting to see if it leans out on the dyno at high rpms...
Old July 20th, 2012, 12:02 PM   #32
chevotass
chevotass's Avatar
I was told all ls series motors were 50-55psi
Old July 20th, 2012, 01:08 PM   #33
dudekcj7
rev limiter racing
dudekcj7's Avatar
50-55 psi is correct is your regulator on the fuel rail and can you here it kicking in when you turn the fuel on?
dudekcj7 is offline   Reply With Quote
Old July 21st, 2012, 07:22 PM   #34
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
security?
Old July 21st, 2012, 11:15 PM   #35
chevotass
chevotass's Avatar
nope. rong labeling on fuel cell.
Old July 22nd, 2012, 07:24 AM   #36
Originally Posted by chevotass View Post
nope. rong reading by installer on fuel cell.
Well that answers it.
Old July 25th, 2012, 08:29 AM   #37
4 bar is the fuel pressure from the factory fwiw. Glad to see you got it figured out. "Jeep" looks good
Old July 25th, 2012, 09:54 AM   #38
liv2mx
i like jungle gym's.
liv2mx's Avatar
i just went through all that nick. glad you have it figured out.i have had to clean my injectors twice now.if you get time it probobly wouldnt hurt to pull all the injectors and clean them.mine just had some crap on the top of them.careful putting them back in so you dont rip the little o ring.what i was told, you should have a pre filter and a after filter running the external pump also.
Old July 25th, 2012, 10:46 AM   #39
no, its not. 58 is spec, and most factory motors run 58-60.
Old August 6th, 2012, 11:04 PM   #40
chevotass
chevotass's Avatar
well i went to da dunes. and only in WOT on a long run it would start popping threw the exhaust. i put gauge on and its at idle 48-50 psi. throttling it jumped to 52 but that was it. wondering if its leaning out at the higher rpms like hagger was saying. i dont want to blow up motor.
im running the RCI cell. ill put up a pic. you can see the fuel pump on the far frame rail. its about 3ft from the tank. im wondering if it being so far from the fuel pickup it could not flow the volume i need. anyone else have better luck moving pump closer?
Page generated in 0.32324 seconds with 83 queries
