6.0 ls motor ran great. now it doesnt run at all - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 18th, 2012, 09:50 PM   #1
chevotass
chevotass's Avatar
Default 6.0 ls motor ran great. now it doesnt run at all
with my current build up i have a fj40 that already had a 2002 6.0 swap done and tuned.
it ran awesome when i got it. but i immidietly wripped out the cage and suspension. its been 9 months and i went to hook all my battary cables back up and grounds. dumped 3 gallons of fuel in the new fuel cell.
turn it over and it just fires and thats it.
I NEEED HELP. i have every ground possible hooked up now. cant find any loose wires. i even tried running a ignition constant hot to the fuel pump and bypass the relay. the pump runs but the truck still wont do anything but fire for about 2 seconds.
the only thing ive changed involving the motor is remove a home made gas tank and put an rci fuel cell in. I put a new fuel filter in as well.
if you put starting fluid to the air cleaner it seems like it would run. so im thinking it has to be a fuel issue.
Old July 18th, 2012, 09:57 PM   #2
tw1st3d5
tw1st3d5's Avatar
Just stating the obvious here but make sure that you have the supply and return hooked to the correct ports on the cell. I only spent about 6 hours the other day trying to get my fuel pump to prime. Tried pouring gas down the line etc. Come to find out I had them swapped.
Old July 18th, 2012, 10:00 PM   #3
Bones
Bones's Avatar
check pressure at the rail?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 18th, 2012, 10:03 PM   #4
chevotass
chevotass's Avatar
not yet billy. i dont have a guage that goes that high. my high tech tool only went up to TBI pressures. sooo sad. unless the guys at rci put the stickers on the wrong ports i should be good. but people are always making mistakes. maybe i should swap them.
Old July 18th, 2012, 10:04 PM   #5
tw1st3d5
tw1st3d5's Avatar
Which cell are you running?
Old July 18th, 2012, 10:07 PM   #6
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
This may sound wired but my old truck with a 5.3 did the same thing when the hose between the air filter and the intake worked itself loose just a pinch. I couldn't figure it out for a month then I saw the clamp wasn't on right. 10 second fix and it ran like a champ.
Old July 18th, 2012, 10:12 PM   #7
tw1st3d5
tw1st3d5's Avatar
On my 2161 looking from the side with the fill connection the port to the left is the pickup. Is the fuel pump pushing air at all? Check at the rail to see if it is.
Old July 18th, 2012, 10:33 PM   #8
chevotass
chevotass's Avatar
i have the 15 gallon 2161a fuel cell. tomorrow ill hit up the zone and borrow a prussure tester. also double check my lines. the intake hose and i might pull my filter. im wondering if my new filter is to restrictive? i just grabbed a generic one off the autozone shelf that looked like the one that was on it.
Old July 18th, 2012, 10:33 PM   #9
firehawk
Live Action!
firehawk's Avatar
Could have a wire that needs constant 12v with key on and not just crank 12v. If it was hooked to 12v crank only then it would fire and die, fire and die, but if that wire were hooked to 12v with key on it would continue to run.
I have been dealing with the wiring on my Bronco for the past couple months and that was one thing I had to deal with.
Old July 18th, 2012, 10:35 PM   #10
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
you have to check pressure at the rail...without that reading you are fighting a losing battle when it comes to fuel issues
also make sure its not hooked to your turn signal!!
Old July 18th, 2012, 10:40 PM   #11
chevotass
chevotass's Avatar
even when hooked to turn signal they idle great. its not til you get into the throttle. not that i have done that or anything. just what ive heard.
Old July 18th, 2012, 10:48 PM   #12
Strangler
Strangler's Avatar
If you depress the valve, does it spray fuel? Crack the fuel line and let her start leaking to bleed.
If all else fails, put a tbi 350 in it.
Old July 18th, 2012, 11:02 PM   #13
Strangler
Strangler's Avatar
Also, after my stupid truck died on my a R&V a couple years back..... triple check the fuses. Just cuz.
Old July 19th, 2012, 06:38 AM   #14
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i cant remember but doesnt the computer control the ground on the fuel pump? i may be talking out my butt.
also you really need to check fuel pressure its a huge factor in these motors.
Old July 19th, 2012, 06:40 AM   #15
Your engine needs 60 psi @ the rail, not 45 or so like older FI systems.
Here's an odd item that happens through the ECM. Your fuel pump only runs for about 3-4 seconds and then shuts off unless the ECM senses that your engine is running. That's why when you turn on the key you will hear the pump prime up and then stop. I don't know anything about the circuitry or how to trouble shoot it. Maybe JohnnyJ or Colville can give you some insight.
Old July 19th, 2012, 09:45 AM   #16
Strangler
Strangler's Avatar
TBI time......
Old July 19th, 2012, 10:00 AM   #17
Manual TB or Electric? have any way to see if the idle air controller is doing anything or not? I'm assuming they didn't fool the VATS instead of disabling it but running and shutting down is a VATS (security) thing too. If it worked before, that shouldn't be an issue. PCV hose come loose?
Old July 19th, 2012, 11:19 AM   #18
bdd1469
bdd
bdd1469's Avatar
Originally Posted by Strangler View Post
TBI time......
That is the dumbest thing I've heard all day.And I work with some real idiots.
Old July 19th, 2012, 11:30 AM   #19
bdd1469
bdd
bdd1469's Avatar
Make sure it shows oil pressure when you are cranking it.What fuel pump are you using.I have seen many aftermarket pumps ruin peoples day.I only run delphi pumps in Gm vehicals.
Old July 19th, 2012, 02:24 PM   #20
IIRC, 58 psi is spec. As they say, need to check the fuel pressure on the rail. Thats first and foremost.
Is your fuel pump in-tank or external. The stock pickups in those 216x tanks suck for fuel EFI with fuel slock issues.
Page generated in 0.49374 seconds with 83 queries
