Air compressor qeustion ??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 15th, 2012, 10:37 AM   #1
bjkttr
bjkttr's Avatar
Default Air compressor qeustion ???
I am looking at buying a used air compressor. My question it if I am wanting to run impact tools and maybe a small sandblaster what should I look for as far as specs go? One that I was looking at is a 60 gallon 3hp and the take can hold 200 psi 220v single stage. it is a case brand. please help any info would be great.
bjkttr is offline   Reply With Quote
Old July 15th, 2012, 10:46 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
you want the most CFM at your working pressure. for most tools that is at 90 PSI. for example. the harbor freight 60 gallon compressor makes 15.8 cfm at 90 psi
Old July 15th, 2012, 11:08 AM   #3
bjkttr
bjkttr's Avatar
ok I will have to see if i can get the specs. what would be a good cfm and lets say 90 psi ?
Old July 24th, 2012, 11:30 AM   #4
BOGDOG
BOGDOG's Avatar
10cfm @ 90 psi will run most anything but a you may want something with a 60 gal tank if you are doing a lot of bodywork or running any kind of tool that spins a lot.
Page generated in 0.47142 seconds with 35 queries
